手順 4を翻訳中
手順4
Removing the Motor
A long Phillips screwdriver is needed to reach into the machine.
Start by unscrewing the four screws that attach the metal plate, located on the end of the motor, to the plastic casing and the black plastic grinder mechanism.
Once the motor has been removed, further unfasten the four screws and remove the corresponding washers on the base plate of the motor.
Then, you will be able to see the mechanism.
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります。
