メインコンテンツにスキップ
iPhone 7 のボリュームコントロールボタンの交換
必要な工具と部品
  1. iPhone 7 のボリュームコントロールボタンの交換, ペンタローブネジ: 手順 1、 1の画像 1
    • 作業開始前にiPhoneバッテリーを25%以下まで消費してください。充電されたリチウムイオンバッテリーは、バッテリーに穴が空いた場合、引火や爆発の恐れがあります。
    • 分解を始める前に、iPhoneの電源を切ってください。
    • iPhone下部底面に留められた3.4 mmペンタローブネジを2本外します。
    • iPhoneのディスプレイを開口するとディスプレイ上の耐水性シールにダメージを与えてしまいます。再組み立ての際、接着シールを交換しなくても通常通り機能しますが、耐水機能を保てないことを留意ください。
    Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
    Cooper Chase - 返信
    Confirmed, the screws have a black ring seal around the head.
    rcheing - 返信
    Can’t get the display front
    Bernadette Pfeifer - 返信
    From personal experience, I highly recommend before doing this procedure or any other, that you do a backup of your phone (preferably local) in case your procedure goes south.
    ballina5ny - 返信
    I purchased the repair tools with the replacement battery from iFixit. The tools include a screw driver and three heads none were labeled 3.4 mm. I think the one that fit the pentalobe screws was labeled Y000. The guide should identify the screw driver head supplied by the kit not 3.4mm.
    Mark Lieberman - 返信
    in the iphone 7 replacement battery kit from iFixit, the screwdriver that fits the 3.4 mm pentalobe screws is labeled P2 (and not Y000)
    Jan-Tijn Oppermann -
    3.4 mm is the height of the screw and is not related to the screw driver code.
    Ahmad Vaziri -
    the screwdriver PH000 does not work i wasted two screws and now they dont have the 4 cross mark they are now a circle, i buyed it all from Paraguay and it doesnt work, had to assembly back the parts because i got stuck like i mention with some screws, well im just going to send to a professional to install, thanks
    Martin Frutos, Nuñez - 返信
    The bottom screws are Pentalobe, not Phillips.
    Bram Driesen -
    Before starting, I would recommend backing up your Iphone’s data just in case.
    Jon Moylan - 返信
    If you managed to make it to this section, just send the phone into apple for 50 + 6 dollars shipping. The ribbon cables on the screen are designed to break. I can literally twist on the rest of the cable and it won’t fall apart but there is a diagonal section where it snaps. This is the fault of apple and the fault of ifixit for misrepresenting the fragility of the cables.
    Ryan Huebert - 返信
    Had to reheat it a few times for a minute each with a hairdryer to get the seal to break after pulling and rocking the suction
    Cynthia Lamb - 返信
    I’m technically challenged. Is there a premier national service who can professionally install a replacement battery got my 7 +?
    Richard - 返信
    Do the screws come out in total?
    YVES THEUGELS - 返信
    They may come out or may not. If you loosen as much as you can and they don't come out you should still be able to pry open the bottom. Once you get the screen off you can then push the screws out from the inside.
    Anthony Falabella -
    Is it the P2 you should use for the bottom??
    YVES THEUGELS - 返信
    I heated the bottom of the phone with a hairdryer and then used a syringe to put a couple of drops of acetone directly into the bottom two screw holes. I GENTLY pulled on the screen with the suction cup and used the pry tool to GENTLY separate the screen. The sealant is applied around the entire display so be very careful pulling it off so you don’t break the fragile display cables.
    Anthony Scaminaci - 返信
    At first it was very difficult to open, per instructions. I used a heat/ice pack and nuked it for 1 minute. The pry tool wasn’t working so I carefully used my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, place the taptic engine before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit. Good job on hosting the video, Gwendyl.
    Klaus Preiss - 返信
    I love the fact that the screw bit and shaft are magnetic! I almost lost a screw and found it attached to the magnet.
    I used a heat/ice pack and nuked it for 1 minute. At first the display cover was very difficult to open with the pry tool, per instructions. The pry tool wasn’t working so I carefully used the blade of my pocket knife to wedge the cover open. The rest of the procedure went well until I cracked the glass while trying to get the top right corner to pop off. Other than that mistake, all went well. Tip: before setting the new battery, attach the battery connector first and leave enough room for the taptic engine, or better yet, see the taptic engine in place before adhering the replacement battery. This way you’ll have a small gap between the two, whereas mine barely fit because I placed it almost too low.
    Klaus Preiss - 返信
    I replaced the lightning connector assembly and reassembled. The old one did not 'click' into the cable and had corrosion inside, it needed the cable to be placed in a specific way to charge. The new part - does not recognize that a charger is plugged in at all.
    I backtracked the assembly - took it apart, put it back again - and find that every thing on the part works - the mic, speakers, taptic engine.
    The original problem with the cable still persists. Any ideas?
    H K - 返信
  2. iPhone 7 のボリュームコントロールボタンの交換, iPhone 7の開口方法: 手順 2、 1の画像 1
    • iOpenerの下側端を温めると、ディスプレイに留められた圧着剤が柔らかくなり開口しやすくなります。
    • ヘアドライヤーもしくはiOpener を準備してiPhoneの下側端に約1分間載せます。下に付けられた圧着剤が柔らかくなります。
    ¿Cuántos segundos son los recomendados?
    joscarlos91 - 返信
    Sesenta segundos
    Krutav Shah -
    It is a process. I heated the lower area of the phone with a hair dryer on and off (1min each) about 3-4 times before I was able to get the provided tool in.
    Dan - 返信
    I suggest using a hairdryer. I used the iOpener for maybe 30 mins to no avail. However, when I used the hairdryer the screen came of much quicker.
    Michael - 返信
    I totally Mr. Myagi’ed it, by rubbing my hands together until they burned, then held the phone un my hot hands. I did this 5-6 times over a couple of minutes. It was a good zen way to get started!
    Ark - 返信
    Can a heat gun be used?
    Lee - 返信
    Absolutely. Just don’t overdo it—the adhesive usually softens up pretty easily. If you are experienced with a heat gun, you’ll have no problem. (If you are inexperienced, it’s easy to cook the display or cause other damage.)
    Jeff Suovanen -
    If i use this process, will iphone 7 still be sealed, water/ splash resist after that?
    Marius Serban - 返信
    Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Angel Hermida -
    Can I use a cpb heating pad to soften the adhesive ? If yes how much time and temperature ?
    davidecongiu - 返信
    Will doing this compromise the screen protector (Zagg) that I have on my phone?
    Eric Nance - 返信
    Hairdryer worked for me but I needed to use a razor to pry it open at the bottom then used the spudger
    Gina Torres - 返信
    Is there a reason why you wouldn’t put the iopener over the entire length of the phone, instead of just the bottom corner?
    BPX - 返信
    The motherboard is extremely sensitive to heat.
    Neal Reasland -
    Hello can the head damage the id touch bottom?
    After heating opening it stoped working.
    Qrizmasex @ gmail . Com
    aratovski - 返信
    It definitely can. That happened to me.
    Steve Naylor -
    mine didnt come with a heat pack do i use a hair dryer
    Shy Rose - 返信
    I just threw a hand towel in hot water, and then stuck it into a plastic bag. Dryers work fine, too.
    hiroo yamagata -
    Thanks for this, the other instructions make it seem SOOOOO simple to open up the case with the suction cup! It actually is hellish. The instruction here about the pre-heating and the required patience really helped!
    hiroo yamagata - 返信
    For those of you who don’t have an iOpener or a girlfriend, I used a ziplock bag with some instant mashed potato inside. It worked perfectly first time and you can fold the bag around the ID button in order to prevent damage to it.
    You also get to celebrate by eating the mash afterwards, HUZZAH!
    Adrian - 返信
    🤣 You made my day Adrian, thank you!
    Jicey -
    I found this to be completely useless. It didn’t help at all. I had to use a heat gun instead. Waste of money.
    David Gordon - 返信
    I’ll experiment with leaving the phone in the sun until the Temperature Warning comes up so the phone tells me when it’s too hot to be safe.
    Maybe it will be hot enough, maybe it won’t—
    edmk5000 - 返信
    I use a rice pack in the microwave. White dry rice in a sock sown or tied, then microwave (1 minute +/-). The dry rice heats and retains heat for a long time. My kids loved them in in bed during cold winter nights.
    Todd Oeftger - 返信
    I have changed now Iphone 5 Battery, IPhone 7 front camera & another iPhone 7 rear camera. The instructions along with the comments are really important. Be patient & read them several times. By using your heated gel pack 3-4 times for 2 mins or so on the bottom end near the touch button you will be able to pry with your razor & then you can use your spudger. Thanks for this great guide.
    Kala - 返信
    I would DEFINITELY recommend to NOT use direct heat (hair drier, etc.) on the phone. I used a hair drier to help heat the phone and ended up damaging the home button (would not work after the replacement and I did not touch or take apart the home button). Note that a damaged home button cannot be replaced so I will end up using the alternative “screen” home button going forward with my phone. Instead I would recommend preheating something else (example - metal / coins / ceramic / beads / glass stones / cookware / etc..) to a warm-to hot (but not burning hot) touch and place the heated items on the IPHONE (or visa versa) to heat and soften the adhesive.
    Ed Scannell - 返信
    I used 1-gallon Ziploc back and poured 1qt of boiling water into it. I placed my iPhone on a corkboard and the bag on top for 120 sec.
    It worked like magic. I just pooled the screen with the suction cup, and it got loose from the case. No heat damage. Everything works.
    it500 - 返信
    I placed the iOpener heat bag over the bottom of the phone, disregarding the home button. Now it doesn’t work. All subsequent procedures went well as I was very careful. I should have read all the posts! Protect the home button from direct heat. Fortunately, now using the Assistive Touch feature is better than buying a new phone or replacing the home button.
    Kurt Bee - 返信
    It’s better to choose an iPhone back case to cover and protect your phone from bumps and scratches. Choosing premium cases is the best option for long-term safety. If you need ***iPhone 7 phone cases*** then you can check them out!
    FLAUNT - 返信
  3. iPhone 7 のボリュームコントロールボタンの交換: 手順 3、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 3、 2の画像 2
    • 吸盤カップをディスプレイアセンブリの下部半分より下、かつホームボタンよりも上の位置に装着します。
    • 吸盤カップがホームボタンに重ならないように注意してください。重なってしまうと吸盤カップとフロントガラスの間に隙間が出来てしまい、しっかりと吸着することができません。
    • ディスプレイ全体のひび割れ程度が大きい場合、吸盤カップが上手く装着しないことがあります。透明な補強テープを使って表面をカバーしてください。もしくは吸盤カップの代わりに強力な梱包用テープなどを使用することもできます。それでも上手くいかない場合は、吸盤カップ上にボンドなどを付けて固まったら引っ張ります。
    The glass is completely cracked and the suction cup doesn't work because it gets air in between. any tip?
    Display is glued and doesn't come off.
    support - 返信
    A wide, single strip of packing tape, well placed, will solve this for you. :)
    Mimic44444 - 返信
    Last comment works well. Thank you !
    Using packing tape for a cracked screen should be included in the description in Step 3.
    Cracked screen is most probably the reason you are replacing it.
    Arni Benediktsson - 返信
    I agree that using packing tape for a cracked screen should be included in this steps description. I don’t have wide but turned mine horizontal and that worked great.
    Mary Knapp - 返信
    Bekomme die Oberschale einfach nicht runter! Trotz mehrmaligem erwärmen durch den iOpener und seitlichen bewegen! Weiß nicht mehr weiter!
    Stephan Lienhard - 返信
    Wouldn’t that screw up the Touch ID?
    Rexx Havok - 返信
    The suction cup that is. supplied with the essentials kit doesn’t work that well.
    Laurence - 返信
    Agreed, the iFixit suction cup was useless. I borrowed one from the sponge holder in my kitchen sink. It lacked a grip so I held it with needle-nose pliers, resting them on a bit of wood to keep pressure off the phone.
    ephraim -
    I am not getting this open at all! Why an I provided with tools that can't help me ??‍♀️
    Bray Joseph - 返信
    I couldn’t get the bottom to lift first, but the left side did, so I started there and worked my way around the horn.
    selimnairb - 返信
    Hold the suction cup provided in almost boiling water with tongs for about 30 seconds, then it will actually work :-)
    AKA - 返信
  4. iPhone 7 のボリュームコントロールボタンの交換: 手順 4、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 4、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 4、 3の画像 3
    • ディスプレイアセンブリと背面ケースの間に小さな隙間が出来るように吸盤カップで引き上げます。
    • スパッジャーの平面側先端を隙間に差し込みます。
    • ディスプレイを留めている耐水性のある接着剤はとても強力です。最初の隙間を作るためにかなりの努力が必要です。もし隙間を作るのが難しい場合は、スパッジャーを内部に差し込めるほどの隙間ができるまで、吸盤カップを上下に動かし続けてください。
    This was SO hard for me to do with the spudger. I couldn’t get a gap to insert it because my phone was so cracked (even though I used tape on the front) to get a solid seal with the suction cup. I ended up taking a VERY thin knife and inserting it straight down to make the initial break that allowed me to insert the spudger.
    jessica harlow - 返信
    I’ve given up using a plastic spudger to try to open any of these phones. I use a metal one with a flat base and a very sharp end…close to a razor. As long as I’m careful, it won’t slip and scratch the base. It’s much easier than using these plastic spudgers.
    mcr4u2 -
    I confirm that the plastic spudger it’s not the best tool for this operation. I suggest to use a larger metal tool like a “Jimmy” or “iSesamo open tool” (I used the first one)
    Cristef -
    Im trying to get the screen off right now and my phone is not cracked and its still a pain
    Jordon Johnson - 返信
    Using a blow dryer was extremely helpful and using the suction cup towards one of the lower edges was also helpful
    Jordon Johnson - 返信
    This is not working for me. How long does the heat need to be applied? Still trying right now…. =/
    Chris Gallego - 返信
    Apply hair dryer for at least 1 minute. I inserted the tip end of a thin mini screwdriver and with some force, pryed it open and inserted my plastic spudger to continue the separation process. It worked, just be patient.
    Please wear protective glasses! My iPhone glass was severely cracked, when separating the glass a corner area of broken glass exploded in my face. Apply transparent tape over the broken glass to contain the shards.
    amberron - 返信
    I second Jessica’s January 8 comment.  I just finished a battery replacement on my iPhone 7 and this step was the most nerve-wracking part.  I ended up using a sharper (but not razor-sharp) metal object to get this done with confidence (tried the spudger and guitar pick but not thin enough).  The tool I used was the exact duplicate of what iFixIt calls “iSesamo Opening Tool” in their tool selection.  I did the heat up with a hair dryer (after attempts with an iOpener hot pad) and the secret (as Jessica also noted)  was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup.  From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture).  I actually used the metal tool for most of the perimeter as well, just don’t go deep (you don’t need to).  Notes: my display was intact, and I was able to pull up fairly hard with a glass screen protector still on it.
    Ted - 返信
    This is frustrating. I heated the lower edge with a hair dryer for 1 min on high about 3-4 times. In between each heat cycle, I rocked the suction cup back and forth. I was eventually able to create significant space for the provided tool. This takes a lot of patience. Once the space was created, it was very easy to remove the screen.
    Dan - 返信
    use a fingernail, then the blue tool, then the spudger
    Therese Peffer - 返信
    The iOpener worked just fine for me. Had to keep it on for a few minutes. I also was able to get the suction cup seal right close to the edge, over top of the home button for added leverage. Used the blue tool and transitioned to the spudger. Slow, steady pressure…and patience. ;)
    johnhall918 - 返信
    Unable to open an iPhone 7 display assembly. Used gell pack at 150 degrees F. The phone wouldn’t budge when I used the iFixit suction cut. Part of the problem is that the cup doesn’t adhere for long before it looses suction. I suspect it would work better on unbroken glass, but that doesn’t help me now. After spending a lot of time at this, I changed heating methods to a hot air heater. I raised the temp of the bottom end of the phone to, ultimately, 175 degrees, and used a variety of tools to try to pry the glass apart enough to get a spudger (or anything) in, but it didn’t even lift enough for a double-edged razor blade to get in. I’ve been trying this for hours now, and about to give up and throw a lot more money at this to have a service perform the work. I figured that 175 was as high as I should need to go to soften the adhesive without damaging the electronics. Should I have gone higher? I see no mention of measured temps in any instructions or comments.
    ted - 返信
    Have you tried applying tape to the broken screen? This will help a lot with keeping the suction cup on it.
    Christian Groothuis -
    It doesn’t need to get very hot; pulling up on the display is mainly what does the trick. Make sure the two pentalobe screws have been removed and then try the tricks in this step. If all else fails, superglue the suction cup to your display and let it cure, and then pull. Keep in mind you only need a tiny gap to insert a plastic pick and start cutting the adhesive. Good luck!
    Jeff Suovanen -
    Just a question. After this operation the impermeability function was compromitted?
    bentek86 - 返信
    The trick I found, was to add packing tape right across the bottom over the home button then use hairdryer on the end, then suction cup on the very bottom and it lifted enough to get a gap. No one mentioned how it would be impossible to handle the phone after the hairdryer ;)
    Andrew Lansdowne - 返信
    Didn’t have an iOpener and 60 seconds on a hairdryer wasn’t doing it for me. Still wouldn’t budge. I had to take a very sharp razor along the seam at the bottom between the speakers. It took about 20 passes for it to separate enough to get the spudger in. Make sure you keep the razor at a 90-45˚ angle and that it goes no more than 1-2mm into the phone. The bottom of the phone is metal, but the casing for the screen is plastic. So if you cut lower than a 45˚ (flat with the phone) you risk cutting into the casing. Apply light pressure when making the passes. I would just do the razor on the flat part on the bottom.
    minimalist - 返信
    I used a hair drier while lifting up at the same time until I could get the too inside. The seal is pretty finicky. Just take your time and you should be fine. Work the hair drier and the tool all the way around before lifting the screen up and off. There will likely be sealant stuck between the screen and phone. You can just break it with the tool.
    Ray Bieze - 返信
    This step was impossible for me despite using a blow dryer and having no cracks on the screen. I finally took it to a local repair place and had them do battery replacements for two iPhone 7’s. The girl let me watch her do it. She used a razor blade (just until she had a small opening that she could hold open with her fingernail) and confirmed that she too would have difficulty opening it with a plastic tool and suction cup. The plastic tool was great for prying the rest of it open once a crack was there, but she said she would never try to use that as the tool to initially open it. The tools provided for initially prying open the screen are inadequate.
    Chad Twedt - 返信
    Hopeless - no chance to get the screen off without any damage. No matter what tools, heat etc.
    Anatole Beams - 返信
    I second what others have said, definitely use a razor blade to break the seal! Heat helps some, but too much direct heat is bad for the screen. Would have been impossible if I hadn’t read the comments, thanks everybody!
    Kit - 返信
    Use extreme caution on this step. I was just replacing my battery and now i’m buying a new screen. The screen was very stuck, I pulled to hard and it popped off suddenly, completely destroying the screen.
    moose - 返信
    When the right heat is reached, the easiest way is to use a metal iFlex to create the initial gap, then insert the Jimmy or iSesamo next to it so the gap gets bigger, at this point you can get in with the flat edge of a plastic spudger and slowly slide it in the borders to cut the adhesive. You will still need to force a bit the upper end to separate the screen by pulling it down while keeping up the screen, and twist to the right. I hope this is clear enough. Never apply too much strength too quickly anyway.
    Stefano Restuccia - 返信
    I used the short blade of my swiss knife to make an initial opening. Using the sharp edge, inserting about 1 mm straight down and twisting down into a 45° angle. Then I was able to insert the spudger.
    John van de Loo - 返信
    This is a difficult step. Fortunately, I had another suction cup from an earlier repair available, so I applied one to each side of the phone. After warming with a hair dryer, I was able to pull the two suction cups far enough away that another person could easily insert the spudger.
    The third hand was essential.
    Mark - 返信
    I found this tactic to be the best solution for us. I used two suction cups, one on each side of the phone, and another set of hands to get a pry tool under the display. We still had to take our time prior while heating the adhesive, but were able to pry the display fairly easily using the two suction cup method.
    Lucas -
    It was a really excruciating process of heating, lifting with the suction cup, trying to slide in the spudger/pick, and repeating the process for 20 times or so. But in the end, my patience paid off!
    hiroo yamagata - 返信
    I used a hair dryer, then used a safety razor blade parallel to the bottom edge to push straight down (from the glass side, towards the back) while lifting with the suction cup. I wiggled the blade (top to bottom) while pressing down gently, until I saw a gap that would accept the spudger. It did not take much force on the blade or much wiggling, just patience.
    Gene Merritt - 返信
    Followed Gene’s approach with heat and a razor blade. I was nervous, but went slow; it was very easy and effective. Great tip. Just be patient and don’t rush yourself.
    Michael J - 返信
    I would skip right to using a single edge razor blade and a hair dryer to create the gap needed for the spudger.
    Logan Brown - 返信
    Think plunging the toilet - it did not work for me for a long time. the suction cup would not stay held on a long pull. I found that tiny push-pull repeated motions, reseating the suction cup with each push slowly overcame the adhesive, and contributed heat :). I had it after about 50-70 cycles
    Andrew Balanda - 返信
    seconding this comment from Ted ~~~ “the secret (as Jessica also noted)  was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup.  From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture).”
    natjpollard - 返信
    I echo what everyone is saying here, the spudger just isn’t good enough for this and neither is a pick. The razor is the best way to go. I tried using a very sharp penknife blade and managed to damage my LCD (somehow!) and the bezel so I ended up having to buy a new screen display as well as a new battery. Think twice before doing this. Be prepared to shell out for a new screen just in case it goes wrong. You’ll also need the heat gun (the iopener was useless). If you do need to buy a new screen, make your life easier and get one with the speaker, forward-facing camera, home button, etc., already attached (you can then replace the home button) or you’ll end up having to transfer all these from your old display.
    David Gordon - 返信
    I finally got the screen up but shattered it in the process. I was replacing it anyway but if the screen is not what you’re replacing, take EXTEME caution. The suction cup and spudger were not working for me to get it started. Thanks to the comments, I used a razor blade and a heating pad and went back and forth, back and forth, between heat and pressure from the blade. Once you get a gap, the spudger works great and the screen comes up easy.
    Nick Nave - 返信
    The suction cups that iFixit sells are crap. They don’t stick at all. Glass on the phone is pristine.
    Nick - 返信
    More feedback on this “guide”:
    “Pull up on the suction cup.” What does this mean? If I just pull up on the suction cup (with a real one that actually sticks) it just lifts the phone off the table. You need a description of what you are pulling against. Do I try to hold the frame of the phone? Do I try to stick something in the lightning port to pull against? Do I try and get something against the edge of the rounded metal on the edge of the phone (this usually just slips off). What am I pulling against???
    Nick - 返信
    I found a combination of iOpener, suction cup and razor blade, all applied at the same time, worked for me and I didn't need to use a hairdryer.
    Peter Gray - 返信
    Dumbly, I thought that with the Spudger I'd had to hold the phone from the charging hole while pulling the screen. .. In the end I inserted the two ends of the tweezers(bends the tweezers and may damage it) in the screwdriver holes and pushed the screen out upwards so that I could insert the sharp side of a knife.
    Claudiu Cezar - 返信
    This was my first iPhone battery replacement and I can say this was the hardest part.
    Be wise, go for a hair dryer and heat up the phone bottom (long enough). iOpener did not work at all for me. Heat up, use the suction cup and push the opening pick under the frame as soon as you see movement along the frame.
    Then use the spudger to wander around the whole frame (leaving the pick where it is). Done!
    Guenter - 返信
    True about sputter i cracked my screen trying to lift it up while using this device back in 2021
    DJSan - 返信
    One little corner at a time. Don't try to do the whole bottom at once. I heated with a hair dryer. Applied the suction cup to one side and worked the corner till it started to give. Took a minute or two. Use a magnifying glass to help see when it's starting to come loose. It's not hard to do.
    Some Idiot - 返信
  5. iPhone 7 のボリュームコントロールボタンの交換: 手順 5、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 5、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 5、 3の画像 3
    • iPhoneの下部端から左側に沿ってスパッジャーを動かします。
    • ディスプレイと背面ケースの間に出来た隙間を広げるために、スパッジャーをひねりながら動かします。
    minimalist - 返信
    I used a hairdryer and a razor
    Gina Torres - 返信
    The photos are a con. You cannot get a spudger in unless you can lift the screen. You cannot lift the screen because of the adhesive. Using a anything metal will damage the paintwork or the glass edge.
    Anatole Beams - 返信
    I agree, these guides are half imaginary idealism it seems. A thin metal edge pushed vertically down just a fraction of a mm will cause the adhesive to weaken better than any amount of heat, but affects the final appearance sadly.
    Jesse de Vries - 返信
  6. iPhone 7 のボリュームコントロールボタンの交換: 手順 6、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 6、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 6、 3の画像 3
    • スパッジャーをiPhone下部端から左側に移して、下から音量ボタンとサイレントスイッチを通って上部に向けて動かしていきます。
    • ディスプレイ上部端をリアケース側から外さないでください。プラスチッククリップで留められているため、無理に外そうとすると壊してしまいます。
    Be VERY careful on this next step going up the right side of the phone. There is a ribbon cable 1/3 of the way up from the bottom that is very close to the edge. Do NOT use the blue triangle!!!! Just lightly rotate the spudger to get separation on the edge.
    Timothy Varvais - 返信
  7. iPhone 7 のボリュームコントロールボタンの交換: 手順 7、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 7、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 7、 3の画像 3
    • デバイス下側の右側角にスパッジャーの平面側先端を差し込みます。
    • ディスプレイアセンブリとリアケースの間の隙間を広げるためスパッジャーをひねりながら動かしていきます。
    • スパッジャーの平面側先端をデバイス右側から上部に向けてスライドして動かします。同時にディスプレイに留められた圧着剤をスパッジャーで切り込みます。
    • デバイス右側端に沿って付けられた、デリケートなリボンケーブルにダメージを与えないよう、留められた接着剤より内側にスパッジャーを差し込まないでください。
    Shoot. I broke the sensitive ribbon cable because I didn’t quite understand what the instructions meant with not to insert the spudger further than the adhesive. It means depth wise, not up the side. Sigh.
    Leo Hwang - 返信
  8. iPhone 7 のボリュームコントロールボタンの交換: 手順 8、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 8、 2の画像 2
    • 吸盤カップを引き上げて、ディスプレイを持ち上げてiPhoneを開けます。
    • 10度以上ディスプレイを持ち上げないでください。デバイスの右端にはリボンケーブルがあり、ディスプレイとロジックボードを繋いでいます。
    do not pull up pull sideways it will brake
    Riley Patterson - 返信
    Made this mistake
    rachael.grime - 返信
    Somehow my phone turned itself back on during the opening. Scared me a little, like a patient coming out of anesthesia during the operation. I was able to turn it back off. Gotta be more careful where you grab this thing.
    Bryant Larsen - 返信
  9. iPhone 7 のボリュームコントロールボタンの交換: 手順 9、 1の画像 1
    • 吸盤カップの小さなノブを持ち上げてフロントパネルから外します。
    very nice
    iPhone 7 back cover
    http://WHITEWINGS.IN/
    Vikash Kumar - 返信
  10. iPhone 7 のボリュームコントロールボタンの交換: 手順 10、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 10、 2の画像 2
    • 開口ピックをiPhoneのリアケースとフロントパネルの間の上端に差し込みます。スクリーンを固定している残りの圧着剤を剥がします。
    • デバイス上端にあるプラスチック製クリップにダメージを与えないようご注意ください。
    The plastic clips mentioned are on the top of the screen being replaced… so not sure why it matters not to break them. Trick here was to pull the screen downwards to open a gap at the top and then insert as shown and raise to break the seal.
    This is relevant for other guides than the display replacement guide.
    jvalaamo -
    プラスチックのクリップという
    表現に混乱しました。
    上部に食い込んでいる
    差し込みのことだったんですね。
    下に引っ張ったら抜けました。
    情報ありがとうございました。
    MARU - 返信
    The opening pick is packaged with the battery, not the tools, so I didn’t find it until I was past this step. Made do with careful use of the spudger and a lot of wiggling the display to break the glue.
    ephraim - 返信
  11. iPhone 7 のボリュームコントロールボタンの交換: 手順 11、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 11、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 11、 3の画像 3
    • デバイスの上端からディスプレイアセンブリをわずかに引き離し、背面ケースに留められたクリップを外します。
    • 本のバックカバーを開くように、左側からディスプレイをめくってiPhoneの内部を開いていきます。
    • ディスプレイを完全に外さないでください。まだリボンケーブルがiPhoneのロジックボードに接続されています。
    I just broke the cable to the battery!
    No Bama - 返信
    same dude im such a freak lol omg haha
    Aiden Polaski - 返信
    Are there replacements ribbons?
    Blax Bently - 返信
    Has anyone else noticed very small squares of rubber with a circle cut through it (I think they fall off into the phone when dismantling)?
    I just replaced my screen and worked out that these are actually a wee pocket that slips over the pentalobe screw holes on the replacement screen. I’m not sure if it’s an additional water resisting mechanism or if it’s to add additional traction for the screws
    richarddillon - 返信
    Thanks, I was wondering where those were from!
    Albert -
    Same, I only had one fall out and I had no idea if important, and didn’t re-add - because I wasn’t sure where it fell from - but it was definitely from the home screen button….watch it be important. -__-
    Nicole Crome -
    I just broke cable connecting camera and earpiece speaker to logic board. Be careful with it.
    Natan Haładyn - 返信
    This section is missing a critical step - to lay some Post-It notes or something below the right half of the phone when you swing it open, so the ribbon cables don’t get sliced by the sharp edge of the phone case. I broke the Home Button ribbon cable because there was no strain relief when I laid it open.
    neila - 返信
    I also broke the home button cable and now I have to use assistive touch.
    Laurencio Gonzalez - 返信
    Keep the suction cup on the display to keep it propped up while you disconnect the ribbon cables.
    minimalist - 返信
    I broke the short ribbon cable that attaches underneath the lower connector bracket. Be SURE when you lift the display, you do it from left to right. I thought I had the phone oriented correctly in my hand, but I was mistaken.
    John Murray - 返信
    Put the suction cup on the right side of the middle of the screen when you rotate it up and out. It serves as a nice stand to take the pressure off the connectors.
    Ray Bieze - 返信
    no mention of what you do once u open the book. are the ribbons long enough to lie flat  or do we have to keep screen raised while removing screws,, like when we hold screen up 45 degrees while removing 5 screw plat when at top of phone. I only realised how fragile the ribbons are and how important it is to use suction  cup to rest screen on an angle so ribbons don't stretch or cut on frame.
    thanks for the above comments and probably the most important section. I just hope I closed t before I fdid any damage. its lke the fragility of iPhone 3’s all over again.
    scallyteacher - 返信
    I just broke one of the cables… yeah, it is not nice… I’m lucky in the sense the screen is still working, but the button is not.
    Trying a cheap screen on Ebay (that contains the cable) do 20$, after that, it’s a new cellphone…
    Vincent Poirier - 返信
    Be EXTREMELY careful when you lift up the screen. I broke 3D touch cable, and the home button stopped working. Had to replace the whole display.
    Sizun Cho - 返信
    Attention ! J’ai cassé la nappe de la caméra avant !
    arnauldjouanny - 返信
  12. iPhone 7 のボリュームコントロールボタンの交換, バッテリー接続の外し方: 手順 12、 1の画像 1
    この手順で使用する道具:
    Tri-point Y000 Screwdriver
    $5.99
    購入する
    • 下部のコネクターブラケットから次の長さの トライポイント Y000 ネジを4本を取り外します。
    • 1.2 mmネジー3本
    • 2.4 mmネジー1本
    • 修理作業中は、各ネジを きちんと管理してください 。再組み立ての際は、iPhoneへのダメージを防ぐため、正しい位置に装着しましょう。
    Ahhh shoot! accidentally ordered tri-wing vs tri-point (must have just looked for y000).. It seems they only did this to annoy repair folks because not everything is tri-point on the phone...
    Steve - 返信
    These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
    Jeff Hurst - 返信
    The Y000 took out one of the screws but not the other 3. I even tried the PH000 as suggested but nothing.
    dbright - 返信
    What driver do I need to remove these screws i’m stuck
    Nasser Nader - 返信
    i cant use, the Y000 it isnt working.
    joscarlos91 - 返信
    What if I stripped a screw what do I do??
    Jacob Ramos - 返信
    Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
    Stephen Babbage - 返信
    It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
    Jim Staples - 返信
    Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
    Magne Eivindson - 返信
    For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
    Erik Fredriksen - 返信
    What do I do if I Stripped one of them?
    Adam Corral - 返信
    Can’t get them removed what to do ?
    cowling_luke - 返信
    Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
    jimpoolio - 返信
    You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
    Kyle Webb -
    The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
    Harmony - 返信
    Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
    Chris Bennett - 返信
    If you can’t get the bit to grip the screw properly, you can use a little bit of the water-proof sealing between the bit and the screw. That worked for me. Hope this helps anyone.
    jvalaamo - 返信
    Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
    Gina Torres - 返信
    I used a bunch of medicine cups to track my screws. You need like 12 if you want them all in cups. I ran out. There are so many different sizes that literally vary by 1mm. The tolerances on these things are tight.
    Ray Bieze - 返信
    I use a 28 day pill box and keep every screw separate and reburn to exact slot because they all vary in length, width and can really damage u phone if too long and nt secure if to small.  use a magnetised screwdriver,  or make the cheap freebees magnetic for a short period by rubbing it up an a magnet. lol
    scallyteacher - 返信
    Absolutely ridiculous had to go get a different one just stupid
    mark golling - 返信
    I couldn’t get the lowest one out and just turned the metal bracket out of the way and replaced battery.
    qwerty77x - 返信
    Was able to get the outer bracket screws out using fine needle nose pliers 90 degrees straight down for the outer ones by pressing down a little and using medium gripping force. Had to take these out first before i could use tweezers on the middle one, for which I had to use tweezers to hold the screw, then rotating the bracket (not the screw) counter clockwise a few mm many times over to slowly unscrew it 1/32th of a turn at a time, repeat. (this loosened middle screw). Think ‘rotating bracket 3minutes/degrees counterclockwise at a time while holding screw in place.) You are gonna need really small/fine pliers and tweezers for this because the heads are countersunk into the bracket.
    Galen Wollenberg - 返信
    The top screw in the step was much longer than 1.2mm. It has the same head as the 1.2mm, but different than the 2.4mm. It’s good to keep track of where they came from.
    All are so small that I thought I’d lost one, when it was still sitting in the phone.
    Mark - 返信
    To help tell if the screw is turning, put a small dot from a marker on the head of the screws.  This helped me to know I wasn't just stripping the head.
    Darren Thibodaux - 返信
    try heating the iPhone with a hairdryer or a bag of rice or about 60 degrees in an oven for 3 minutes . It has worked for me. If the screws don’t come out while hot the will come out as the iPhone cools.
    David Howard - 返信
    A small tapered triangle file using moderate pressure did the trick for me.
    Jack - 返信
  13. iPhone 7 のボリュームコントロールボタンの交換: 手順 13、 1の画像 1
    • 下側のコネクターブラケットを取り出します。
    my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
    Josh Martin - 返信
    This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
    Oscar Moreno - 返信
    So…I forgot to put this bracket back on when reassembling. Now I’ve adhered the display to the case and don’t have another adhesive strip…so I’m wondering: what purpose does this bracket serve? The phone is powering on and seems to work okay.
    Am I going to run into trouble with this bracket missing?
    Ian Fritz - 返信
    Well, that didn’t last long. The phone shuts down without warning. So I guess that plate is important…
    Ian Fritz -
    I also forgot to put the battery shield in, and adhered the display. I’m tempted to leave it like that. However, your negative experience is a good data point telling me to not be cheap.
    Ordered a new adhesive , under $2 shipped from eBay.
    Yishai Sered -
    Thanks, Josh Martin! Mine was stuck too, so I lifted carefully.
    Cynthia Lamb - 返信
  14. iPhone 7 のボリュームコントロールボタンの交換: 手順 14、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 14、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 14、 3の画像 3
    • スパッジャーの尖ったほうの先端を使って、バッテリーコネクターをロジックボードのソケットから外します。
    • バッテリーコネクターがソケットに接触してiPhoneの電源が入らないようにするため、わずかにコネクターケーブルを上に曲げます。
    Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
    Julian Eltrich - 返信
    Reconnecting the battery poorly can cause the iPhone to appear to be properly powered and functional, but then suffer a reboot loop.
    I had difficulty after a screen replacement, and the Console app on my Mac showed that the ‘thermalmonitord’ process was throwing lots of errors from not getting any sensor readings from the battery. It would never charge past 1% and just kept rebooting.
    The contacts on this conector looked fine so even though I had reseated this connector several times already, I reconnected it very firmly using my thumb and a spudger to really press all the corners and middle and really gave it a good massage and then finally it showed the normal dead battery screen and started properly charging and eventually booted back up to normal functionality.
    It seems the battery has to be able to transmit data to the phone to say it’s not overheating or iOS will not allow any current into the battery to recharge it, and the kernel will panic from the null readings and just reboot over and over again.
    jason - 返信
    In my case, the battery connector was attached to the bracket. We just left it connected bracket when we pryed it up.
    Dave Miller - 返信
    Reconnecting the battery connector was a bit difficult in my case. The cable that comes out of the battery was a tiny bit too long, or that I placed the battery a bit too high (i.e., too close to the top of the phone). It took me several frustrating minutes of fiddling with the connector for it to sit right into the socket. I was not sure if that was connected correctly but, alas, the phone came back to life when it was turned back on.
    Tomoharu Eguchi - 返信
    VERY IMPORTANT NOTE: Please READ the reply here by jason.
    It is very easy to knock off or nudge the little pins near the battery socket, see https://guide-images.cdn.ifixit.com/igi/... and https://guide-images.cdn.ifixit.com/igi/....
    Those pins are the data lines to extract battery info: temperature, charge, etc. If you accidentally nudge/knock off them the phone could appear to work normally, even for a few days. But then you will start getting wrong battery reads and then after that it may suffer a reboot loop. If you enter settings > privacy > analytics & improvements and you scroll down you will find panic errors from thermalmonitord that there are missing sensors (TG0B or TGXXX) and you will have to micro solder them. DO NOT NUDGE THEM and double check the socket connector when reconnecting the battery.
    PJM - 返信
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all! Careful removing the lower bracket - mine was stuck to this battery connector, which came up with the bracket. Luckily no cable or connector damage. Be careful. Thank you all!
    dantegd - 返信
    after installing new ifixit battery kit, note the foam on the new battery is thicker than old apple one, managed to remove the old foam and swap to new battery connector, sheild plate now level
    Neil Mills - 返信
  15. iPhone 7 のボリュームコントロールボタンの交換, ディスプレイアセンブリ: 手順 15、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換, ディスプレイアセンブリ: 手順 15、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換, ディスプレイアセンブリ: 手順 15、 3の画像 3
    • この手順でケーブルの接続を外したり再接続する前にバッテリーが切れていることを確認してください。
    • スパッジャーの平面側先端や指の爪を使って、ロジックボード上のソケットから2つのディスプレイコネクタをまっすぐ引き上げて、接続を外します。
    • これらのケーブルを再接続する際は、カチッと音がして装着されるまで、コネクタの先端をソケットに押し込みます。それから反対側のコネクタも同じ作業を繰り返します。コネクタの中央部分を押さないでください。コネクタが僅かでもずれてしまうと曲がってしまい、永続的なダメージの原因となります。
    • もしiPhoneを組み立て直した後に、画面が真っ暗になったり、白い線が表示されたり、タッチの反応が悪い場合は、両方のケーブルを取り外して慎重に再接続し、完全に装着されていることを確認してください。
    To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
    iPhoneディスプレイ用接着剤の交換
    minimalist - 返信
    MAKE SURE you hold the top screen when dislodging the cable connections. I let the screen lie flat down and ended up tearing one of the cable connections, now my touch ID does not work at all! I’m going to have to order a whole new screen.
    Arjun Nagarajan - 返信
    Don’t miss that SECOND CONNECTOR like I did. It will break very easily if not disconnected :(
    garrett peek - 返信
    An earlier comment said to re-apply the suction cup to the right side of the display so that it acts as a stand when the phone is partially opened. That’s a great idea, and helps a lot for this step and the next.
    Mark - 返信
    Hey – I broke one of these flex cables and I cant find them to purchase anywhere. Can somebody help me? It’s the LCD connector first and what is the second flex cable for? Thanks!
    Chan Ty - 返信
    I broke the second (smaller) display connector flex cable.
    1) Is it replaceable or repairable?
    2) Where can I get the replacement?
    Ben Blom - 返信
    Same happened to me. What solution did you find? Could you replace a part to make it work? Thank you!
    Viktoria -
    I replaced the screen and have ended up with a blank screen. Touch control seem to work (touch button works and I can shut down the phone by pressing power button for some seconds and then swipe left to right in the upper part of the screen). But the screen is blank. I’ve tried to disconnect and connect the two connectors in step 16 but with the same result (blank screen). What do I need to do?
    Thanks for advice!
    Bjorn - 返信
    this point is the most important in the whole manual.
    Please pay attention not to strain the flex cables or they will end up breaking
    Jose Joaquín Sanz Iniesta - 返信
    I should have been more careful - the second cable tore off.
    My own fault after having done this replacement about four times previously without any issues, I clearly got cocky and didn’t pay enough attention.
    Be VERY CAREFUL and remember to unplug those cables. Don’t skip steps.
    I’ve now had to order a replacement screen.
    Stuart - 返信
    Echo minimalist’s comment here. Prop the display up and skip to step 19 to save time and remove risk.
    .A. - 返信
    If you replace the screen and there is no display apply io propyl alcohol 99.9 & purse to both connectors on the screen and on the iPhone with a clean toothbrush and let them dry for 45 minutes and then fit the screen and reassemble the iPhone..
    It works for me . when I get a new screen I do t5his before fitting it.
    David Howard - 返信
    I tried to save time by not removing the screen during battery replacement as some comment here, HOWEVER, I ended up having to use a little force to remove the battery and in the process broke the second, lower smaller cable, resulting in loss of home button function and needing to get a new screen. Next time I will follow these steps and completely remove the screen during a battery replacement
    chrislacey - 返信
    I removed the screen and cable still got ripped during reassembling :(
    Viktoria -
    There is a critical fact missing from the steps here, for reassembly: That bottom (underlying) cable is longer than it should be. Loads of people are reporting that the Home button is dead after this repair, but the cables aren't torn. I'm pretty sure this is why. Here is a picture of the problem.
    When reassembling the phone, you must poke this cable back into the body of the phone while you bring the halves together, or you will crush, crimp, and destroy the cable.
    Gavin Stokes - 返信
    I’m only reading your very useful comment now, after the exact thing happened to me and my cable got ripped during reassembling phone. Would you be able helping me naming this part, so I can look for a new one? Thank you very much!
    Viktoria -
    thanks gavin. ifixit should have included this piece of info.
    soupamanx -
    Can somebody help me with the name of the part that these cables belong to? The bottom one got ripped during my battery replacement, I need a new one but unsure what to look for.
    Viktoria - 返信
  16. iPhone 7 のボリュームコントロールボタンの交換: 手順 16、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 16、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 16、 3の画像 3
    • 正面パネルのセンサーアセンブリコネクター上に固定されたブラケットから1.3 mm #000プラスネジを2本外します。
    • あるデバイスによってはY000が使用されています。Appleは製品の製造ラインの途中からY000ネジの使用に切り替えました。
    Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
    It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
    Makana Sylva - 返信
    If you’re having trouble removing these screws;
    the screw on the right goes into a standoff screw that is screwed into the frame.The left one goes into the logicboard.
    If your phone is used most likely it has been repaired in the past and the person that repaired it put the screws in way too tight.
    If your phone is brand new And you know 100% it is then the problem is your screwdriver.Stop before you strip it completely and buy a better screwdriver (EBAY).
    If you already stripped the screw head take the phone to a shop before you break it.
    there are ways to get them out but truthfully it’s extremely dangerous and sometimes your better off quitting while you are ahead.
    Vegeta Barrett -
    The right screw kept spinning, tried different levels of force but didn’t work. I left the screw on and bent the shield to get to the cable.
    s h - 返信
    I used a #1 flat head tip to loosen.
    Peter Pearson - 返信
    I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
    Therese Peffer - 返信
    Use the PH000 and apply a little more force before spinning, should come right out!
    Sierra Scolaro - 返信
    ^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
    Jeff Suovanen -
    the two screw i have are stripped and i have n way of getting either screws off whats my next bet
    Alexis Marie Colon - 返信
    The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
    Ryan Welborn - 返信
    Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
    Jeff Suovanen -
    I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
    rcarswell - 返信
    Use the J00 bit. Worked perfectly
    efazio588 - 返信
    PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
    minimalist - 返信
    I’d do this step before removing the ribbon cables by the battery connector. That way you can disconnect all of them at the same time.
    Ray Bieze - 返信
    i used the little +-shape 30 mm screwdriver (not the Y…but the + shape).
    mason - 返信
    the cable tore. is that it i need a new phone?
    patricia loving - 返信
    You don’t need a new phone, but your selfie camera and phone speaker will not work. You can get replacements for that about $10.
    jack jones - 返信
    Reconnecting this cable and coverplate took a good 20 minutes. O_O
    Nicole Crome - 返信
    What can I do to remove the screw (I stripped it)
    Alex Vu - 返信
    I also had issues to loosen up the screws, in two parts the right side up and the left side down, i think the PH000 is to pointy or something or its too hard for the srews of the iphone, i cannot take it off and know im regreting i bought i order all the way from Paraguay in south america and know so angry it doesnt work
    I skipped this step. Just be really careful not to pull on the screen.
    Takumi Arai - 返信
    The guide says they changed these to the Y000 “at some point in the t middle of the product’s lifecycle”…
    That can’t be true, I have a *day one*, preordered iPhone 7, and mine had, unmistakably, Y000 screws!
    and also, I’m just faithfully following the guide here, but can anyone clarify *why* is is necessary to entirely remove the display AND the Taptic Engine at all? The battery seems accessible just fine… oh well
    PS- I’m doing this on an older backup iPhone 7. My iPhone 12 Pro just went berserk and stopped working completely a little over a year after I got it day one of its release… since the iPhone X I’ve only had easily breakable, overly sensitive phones. I’ve had every numbered iPhone except for the 8 (I got the X released at the same date) and the 11, and man, are these newer iPhones post X fragile!
    Cam F - 返信
    This worked for me! As mentioned use PH000 and apply pressure and then unscrew the screws. They are tiny, adhere to a piece of tape so you don't lose them.
    Rosie J - 返信
  17. iPhone 7 のボリュームコントロールボタンの交換: 手順 17、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 17、 2の画像 2
    • 正面パネルのセンサーアセンブリコネクターの接続をロジックボード上のソケットから外します。
    • 再度接続する際には、この平たいコネクターが曲がるリスクを最小にするために、コネクターを一度に接続してください。
    Das ist sehr mutig, das Kabel dort so zu strapazieren.
    Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
    Detlef Menninger - 返信
    Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
    Victor Bui - 返信
    @victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
    Jeff Suovanen -
    This is the only connector that is quite easily possible to put back in the wrong way. If you do so, the phone will just get into a continuous loop where it shows the boot screen, goes blank and then shows the boot screen again and again. If this happens, do not despair-just put it back in the right way.
    Roy Mathew - 返信
    After putting together, I had a continuous loop boot up (as noted above). I saw articles where this (front panel sensor connection) was the reason. I disconnected this connection and the boot up loop stopped. I tried reconnecting several times but had the same problem (boot up loop). However, it turns out that I needed to apply extra pressure when installing until a heard a (faint) second click when pressing down. Note - before I was using the spudger to press the connection together, which didn’t do the job. I ended up using my finger to press harder to get it to click in. Solved that issue.
    Ed Scannell - 返信
    The ribbon cable on this step is torn. Is this something that can be replaced? Is this only to the earpiece?
    John Daily - 返信
    Sarah Valencia - 返信
  18. iPhone 7 のボリュームコントロールボタンの交換: 手順 18、 1の画像 1
    When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
    Guy Cooley - 返信
    Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
    Victor Bui - 返信
    @victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
    Jeff Suovanen -
    This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
    trent bost - 返信
    @trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
    Jeff Suovanen -
    If the instructions are followed step by step, then adding the adhesive comes before changing the battery.
    If I had to do it all over again, I'd skip adding the adhesive, because you have to disconnect the battery, plus the two lower display connecters and the front panel sensor assembly connector. It was a nightmare trying to marry the components back together without disturbing the wire prongs, and I don't even want to talk about reinserting the tiny screws that kept twirling around on the tip of the screwdriver as well. It wasn't worth the time or aggravation!!
    If you decide to skip this step, just avoid using your iPhone near water.
    Rosie J - 返信
  19. iPhone 7 のボリュームコントロールボタンの交換, SIMカード: 手順 19、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換, SIMカード: 手順 19、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換, SIMカード: 手順 19、 3の画像 3
    • SIMカードの取り出しツールや紙クリップをSIMカードトレイの小さな穴に差し込みます。
    • トレイが出てくるまで押し込みます。
    • この作業はかなりの力が必要です。しかしながら、取り出し用ツールを正しく位置合わせしているか確認してください。デバイス内部のエジェクト機能を損傷しないようにするためです。
    • SIMカードトレイをiPhoneから取り出します。
    • SIMカードを再挿入する際は、トレイに対して正しい方向に差し込んでいるか確認してください。
    Received a sim card tray from IFIXIT for my iphone 7. I can’t seem to get it to close flush no matter how hard I try. Any suggestions?
    AJ Dereume - 返信
    Why would it require a significant amount of force? Is it because the iPhone 7 is water resistant? When I removed my tray it was like it was stuck in goop inside the phone and the tray had a glue like sticky substance on it? It did not ‘click’ back in smoothly like my other iPhones, I had to push it against the ‘goop’. Is this normal for iPhone 7??
    Rebecca Diakun - 返信
    I used the tip of the super pointy tweezers, and it worked well.
    Cynthia Lamb - 返信
  20. iPhone 7 のボリュームコントロールボタンの交換, ロジックボードのコネクタ: 手順 20、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換, ロジックボードのコネクタ: 手順 20、 2の画像 2
    • スパッジャーの平面側先端を使って、背面カメラのコネクターの接続を外します。
  21. iPhone 7 のボリュームコントロールボタンの交換: 手順 21、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 21、 2の画像 2
    • 背面ケースと背面カメラブラケットを固定している次のプラスネジを外します。
    • 1.3 mm ー1本
    • 2.5 mmー1本
    I couldn’t get my 1.3mm screw out. It’s not required thankfully as you can just bend the cover up and out of the way to complete the rest of the steps.
    Ray Bieze - 返信
    i removed them with PH000
    Flavien - 返信
  22. iPhone 7 のボリュームコントロールボタンの交換: 手順 22、 1の画像 1
    • ブラケットを取り出します。
  23. iPhone 7 のボリュームコントロールボタンの交換: 手順 23、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 23、 2の画像 2
    • スパッジャーの先端を使って、リアカメラのジュールの左隣にあるアンテナバスコネクタの接続を外します。
    There is one Step missing before removing the flash light cable: Remove Camera cable, right?
    Achim Breidenbach - 返信
    I broke this and can’t find it on amazon. Is it part of the volume control flash connector? If not, can you send me a link on where to find this connector,…and possible instructions on how to replace?
    Daniel Buhler - 返信
  24. iPhone 7 のボリュームコントロールボタンの交換: 手順 24、 1の画像 1
    • 上部ケーブルブラケットを固定している1.2 mmトライポイントネジを2本外します。
    these are too tight cant get rid off them from y000
    Narendra Mane - 返信
    ok with Y000 from pro tool kit
    Flavien - 返信
    Had to push down to get the Y000 in place
    Cynthia Lamb - 返信
  25. iPhone 7 のボリュームコントロールボタンの交換: 手順 25、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 25、 2の画像 2
    • 上部ケーブルブラケットを取り出します。
  26. iPhone 7 のボリュームコントロールボタンの交換: 手順 26、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 26、 2の画像 2
    • スパッジャーの平面側先端を使って、上部ケーブルコネクターの接続を外します。
    Este cable q funciona tiene porfavor lo desconecte y funciona normal
    Johnny Bolaños - 返信
  27. iPhone 7 のボリュームコントロールボタンの交換: 手順 27、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 27、 2の画像 2
    • Wi-Fiアンテナを固定している次の4本のプラスネジを外します。
    • 1.2 mmネジー3本
    • 1.7 mmネジー1本
    I lost one of these 1.2 mm screws. Will that affect the signal reception?
    Bethany Knaebel - 返信
    There is another screw connecting the antenna to the case.
    tbaiello - 返信
    How do you open the 1.7mm screw? LOL
    Kyle Victor - 返信
    The screws are not threading in for some reason. I measured the screws to be exactly 1.2mm with a caliper.
    Loopy75 - 返信
    Yes there are 4 x screw 3 x 1.2mm and 1x 1.7mm securing the antenna to the case
    ANDREW - 返信
    Yes : 4 screws and not 3 !!
    sirthomasnardin -
  28. iPhone 7 のボリュームコントロールボタンの交換: 手順 28、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 28、 2の画像 2
    • 上部左側のアンテナを取り出します。
    ** also remove the small Phillips screw fastening the WiFi antenna to the top rear casing of the phone
    iBroke - 返信
  29. iPhone 7 のボリュームコントロールボタンの交換: 手順 29、 1の画像 1
    • 次のプラスネジを外します。
    • 1.3 mmネジー1本
    • 2.2 mmネジー1本
    Möglicherweise muss man den Kleber zuerst entfernen!
    Evan Winter - 返信
  30. iPhone 7 のボリュームコントロールボタンの交換: 手順 30、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 30、 2の画像 2
    • ブラケットを取り出します。
    What's this bracket called
    Cris Velasquez - 返信
    %#*@, lost that part during the job, thought it’d be alright without it. Couple days later figured out NFC doesn’t work anymore. Any ideas on where to get this part from, colleagues?
    azowux - 返信
  31. iPhone 7 のボリュームコントロールボタンの交換: 手順 31、 1の画像 1
    この手順で使用する道具:
    Standoff Screwdriver for iPhones
    $5.49
    購入する
    • 接地ブラケットから2.2 mm SO(スタンドオフ)ネジを外します。
    • スタンドオフネジを外すには、 スタンドオフドライバーもしくはビットを使うのがベストです。
    • それらがない場合には、小サイズのマイナスドライバーでも対応可能です。ただし、滑って周囲のコンポーネントにダメージを与えないよう細心の注意を払ってください。
    What bit is this? The link doesn’t use the same name.
    Mike Moran - 返信
    I didn’t even have an eyeglass repair kit flathead, so I hit the end of a paperclip with a hammer to make a flathead, and it works!
    Ark - 返信
    I hate getting the deep into a repair to find there’s a tool missing. This bit should be part of the toolkit!
    Ark - 返信
    Its in the toolkit now. Looks like a Philips head but up close the end is squared off with a point in the middle.
    Jesse de Vries -
    I received two boxes - one box contained the repair part, the other was the tool kit. I only opened the tool kit before disassembling the phone. The standoff screwdriver bit was not in there. Neither was the guitar pick. I used a real guitar pick and a small standard screwdriver from my toolbox. When I was ready to reassemble, I opened the repair part box and guess what was in there - the standoff screwdriver bit and guitar pick. So, I guess if you just order the part it will come with (at least) those two tools. The tool kit contains tweezers, suction cup, three screwdriver bits (tri-point, pentalobe, and phillips) and screwdriver handle, a long black spudger with a flat end and a pointy end, and a smaller, thicker spudger with a wide, flat ends.
    bronyaur - 返信
    The flat end of the spudger works a treat too.
    Robert Trammel - 返信
    Thank you, bronyar. Since there is a box labeled “Repair Tools”, I never would have looked in the parts box for tools. I was able to use the standoff tool to takie the phone apart, not just to put it back together.
    Mike Ruzicka - 返信
    I used standoff bit for iPhone from my pro tool kit
    Flavien - 返信
  32. iPhone 7 のボリュームコントロールボタンの交換: 手順 32、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 32、 2の画像 2
    • ピンセットを使ってロジックボードの接地ブラケットを邪魔にならないように丁寧に曲げます。
    I accidentally broke the grounding bracket, is it very important to get a new one to replace? as I can't seem to find them for sale anywhere
    Mustifa shah - 返信
    I also broke it. Did your phone work after?
    Did you find a replacement?
    Ben Schorr - 返信
    Did your phone work ?
    Emin -
    also broken does it work without?
    Emin - 返信
    I broke mine while doing this step. A bit confusing. You’re just supposed to bend it out the way, not pull on it entirely. Will the phone still work without this?
    Chandler Forrest - 返信
    $@$*, i broke the grounding bracket
    Z1xus - 返信
    I just didnt bend this one.. Ill tell you how it went
    Lauren Campbell - 返信
  33. iPhone 7 のボリュームコントロールボタンの交換, ロジックボード: 手順 33、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換, ロジックボード: 手順 33、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換, ロジックボード: 手順 33、 3の画像 3
    • スパッジャーの先端を使って、2本のアンテナケーブルコネクターを基板上のソケットから引き上げます。
  34. iPhone 7 のボリュームコントロールボタンの交換: 手順 34、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 34、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 34、 3の画像 3
    • ピンセットを使って、基板上のメタル製ブラケットからアンテナケーブルを丁寧に巻き戻します。
  35. iPhone 7 のボリュームコントロールボタンの交換: 手順 35、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 35、 2の画像 2
    • スパッジャーの先端を使って、下側のケーブルコネクターの接続を外します。
    Wat voor kabel is dit? Deze is beschadigd bij mijn IPhone 8 Plus
    Maarten - 返信
  36. iPhone 7 のボリュームコントロールボタンの交換: 手順 36、 1の画像 1
    この手順で使用する道具:
    $5.49
    購入する
    • 次のネジを外します。
    • 1.4 mmプラスネジー1本
    • 2.2 mmスタンドオフネジー3本
    • スタンドオフネジを外すには、スタンドオフドライバーを使うのがベストです。
    • 困ったときには、小サイズのマイナスドライバーも役目を果たします。ただし、滑って周囲のコンポーネントにダメージを与えないよう細心の注意を払ってください。
    Link may be missing or broken!
    Standoff screws are best removed using an [linked product missing or disabled: IF145-343-1] and driver handle.
    Phrase Neither - 返信
  37. iPhone 7 のボリュームコントロールボタンの交換: 手順 37、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 37、 2の画像 2
    • スパッジャーの先端を使って、基板からSIMカードの取り出しプランジャーを押し出します。
  38. iPhone 7 のボリュームコントロールボタンの交換: 手順 38、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 38、 2の画像 2
    • スパッジャーの平面側先端を使って、バッテリーコネクターを基板の先端から持ち上げます。
    • 全てのケーブルを引っ張らないようにご注意ください。何処で抵抗感を感じたら、全てのケーブル、コネクターとコンポーネントが基板から外れていることを確認してください。
  39. iPhone 7 のボリュームコントロールボタンの交換: 手順 39、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 39、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 39、 3の画像 3
    • バッテリーコネクターを基板の先端から持ち上げ、背面ケースから取り出します。
    • 基板にケーブルを引っ掛けないようにご注意ください。
    Très bien pour ces étapes
    Théophile Bita - 返信
  40. iPhone 7 のボリュームコントロールボタンの交換, リアケースのバッテリー: 手順 40、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換, リアケースのバッテリー: 手順 40、 2の画像 2
    • 先が尖っていないピンセットの先を使って、バッテリー下部端の接着ストリップの一部分を剥がします。
  41. iPhone 7 のボリュームコントロールボタンの交換: 手順 41、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 41、 2の画像 2
    • 先の尖っていないピンセットを使って、バッテリ下部の端に付けられた接着ストリップを剥がします。
  42. iPhone 7 のボリュームコントロールボタンの交換: 手順 42、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 42、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 42、 3の画像 3
    • この手順では接着ストリップを水平に保ったまま、シワが寄らない状態で作業を進めてください。シワが入ったストリップは、引き抜く作業中、裂けてしまいます。
    • ゆっくりとバッテリーの接着タブをiPhoneの底側に向けて1本引き抜きます。
    • バッテリーとリアケースの間からストリップが抜け出るまで一定の強さで引っ張ります。一番効率良い方法は、60度の角度で引っ張ります。
    • このストリップは何倍にも伸びます。必要に応じてバッテリー付近までストリップを持ち替えて作業を続けてください。
  43. iPhone 7 のボリュームコントロールボタンの交換: 手順 43、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 43、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 43、 3の画像 3
    • 2番目の接着ストリップも同じ手順を繰り返します。
    • 2番目のストリップを取り出す際にはバッテリーを片手で押さえてください。バッテリーがケースから外れた時に飛び出すことがあります。
    • 2本の接着ストリップを取り出せたら、次の手順に進みましょう。
    • もしくは、接着ストリップのどちらかがバッテリーの下で切れてしまい、ストリップを取り出せない場合は、この下の手順に進んでください。
    The adhesive strips come out easily enough with a constant even slow pull. however once pulled out they are pretty useless. should say you will need these again.
    Where can I get new adhesive strips, or can I just use a bit of thin double sided tape instead to re-secure the battery? Just a small bit or it will make any future battery replacement difficult!
    ANDREW - 返信
  44. iPhone 7 のボリュームコントロールボタンの交換: 手順 44、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 44、 2の画像 2
    • 2本の接着ストリップを取り出せたら、次の手順に進んでください。2本とも取り出せなかった場合は、リアケースからバッテリーを外さなければなりません。
    • iOpener を準備してリアケースの裏側、バッテリーの上に直接当てます。あるいはヒートガンやドライヤーを使用することもできます。
    • 約1分後iOpenerを外して、デバイスを裏返します。プラスチックカードを差し込んで、バッテリーに残っている圧着剤を剥がします。
    • バッテリーが変形しないようにご注意ください。バッテリーにダメージを与えると危険な化学物質が排出されて引火の原因となります。
    • バッテリー上部1/3の底をこじ開けないでください。ここにボリュームボタンのリボンケーブルが接続されており、ダメージを与えてしまいます。
  45. iPhone 7 のボリュームコントロールボタンの交換: 手順 45、 1の画像 1
    • リアケースからバッテリーを取り出します。
    • バッテリーを装着する際には、このガイドを使ってバッテリー用の接着ストリップを交換してください。
  46. iPhone 7 のボリュームコントロールボタンの交換, 電源と音量コントロールケーブル: 手順 46、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換, 電源と音量コントロールケーブル: 手順 46、 2の画像 2
    • 次のプラスネジを外します。
    • 電源ボタンを固定している1.9 mmネジー2本
    • 音量ボタンを固定している 2.3 mmネジー3本
    You need to remove the battery first.
    Jasper Shemilt - 返信
  47. iPhone 7 のボリュームコントロールボタンの交換: 手順 47、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 47、 2の画像 2
    • 次の1.3 mm プラスネジを外します。
    • 背面カメラ付近ー1本
    • 背面ケース上ー1本
  48. iPhone 7 のボリュームコントロールボタンの交換: 手順 48、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 48、 2の画像 2
    • 電話本体の外側から、スパッジャーの先端を使って背面ケースに向けてホールドスイッチを押します。
    • この作業では、ホールドスイッチとガスケットを背面ケースから外します。
  49. iPhone 7 のボリュームコントロールボタンの交換: 手順 49、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 49、 2の画像 2
    • ピンセットを使って、背面カメラを取り出します。
  50. iPhone 7 のボリュームコントロールボタンの交換: 手順 50、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 50、 2の画像 2
    • 開口ピックを使って背面ケースに留められたアンテナフレックスケーブルの接着剤を剥がして、電源ボタンを本体から外します。
  51. iPhone 7 のボリュームコントロールボタンの交換: 手順 51、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 51、 2の画像 2
    • 開口ピックの先端をアンテナフレックスケーブルの下に差し込み、残りの接着剤を剥がしながら電話上部に向けてスライドします。
  52. iPhone 7 のボリュームコントロールボタンの交換: 手順 52、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 52、 2の画像 2
    • ピンセットを使って、背面ケースからネジブラケットを外して電話の先端からアンテナフレックスケーブルを掴みます。
    • アンテナフレックスケーブルを取り出します。
  53. iPhone 7 のボリュームコントロールボタンの交換: 手順 53、 1の画像 1
    • 背面ケースに固定されたフラッシュブラケットから2.3 mmスタンドオフネジを外します。
    • スタンドオフネジを外すには、iPhone用スタンドオフドライバービットとドライバーハンドルを使うのが最善です。
  54. iPhone 7 のボリュームコントロールボタンの交換: 手順 54、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 54、 2の画像 2
    • フラッシュブラケットを取り出します。
  55. iPhone 7 のボリュームコントロールボタンの交換: 手順 55、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 55、 2の画像 2
    • スパッジャーの先端を使って、フラッシュモジュールを丁寧に外します。
  56. iPhone 7 のボリュームコントロールボタンの交換: 手順 56、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 56、 2の画像 2
    • 薙刀タイプのスパッジャーの刃を使って、マイクと背面ケースに留められた接着剤を剥がします。
  57. iPhone 7 のボリュームコントロールボタンの交換: 手順 57、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 57、 2の画像 2
    • 丁寧に背面ケースの端から電源ボタンモジュールを折り曲げます。
  58. iPhone 7 のボリュームコントロールボタンの交換: 手順 58、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 58、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 58、 3の画像 3
    • 薙刀タイプのスパッジャーの刃をボタンケーブルの電源ボタン先端の下に差し込み、背面ケース上に留められた接着剤を剥がします。
    • 続けてブレード(刃)を電話本体上部に向けて動かしながら接着剤を剥がします。
  59. iPhone 7 のボリュームコントロールボタンの交換: 手順 59、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 59、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 59、 3の画像 3
    • 次に、薙刀タイプのスパッジャーの刃を電源と音量コントロールケーブルの下に差し込みます。
    • この作業中、ケーブルにダメージを与えないようにゆっくりと確認しながら差し込んでください。
  60. iPhone 7 のボリュームコントロールボタンの交換: 手順 60、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 60、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 60、 3の画像 3
    • 薙刀タイプのスパッジャーをボタンケーブルの音量コントロール部分の下に差し込みます。
    • 丁寧にブレード(刃)をケーブルの下に差し込んだ後、電話の下側に向けて残りの接着剤を剥がしながらスライドします。
  61. iPhone 7 のボリュームコントロールボタンの交換: 手順 61、 1の画像 1
    • 電源と音量コントロールケーブルを取り出します。
    Thank you very much for this guide, I did the job perfectly, without this guide I would not have succeeded.
    Thanks thanks thanks :-)
    agibru - 返信
  62. iPhone 7 のボリュームコントロールボタンの交換, ボリュームコントロール: 手順 62、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換, ボリュームコントロール: 手順 62、 2の画像 2
    • ボリュームボタンのクリップをデバイス本体の底側に向けて引っ張り、ブラケットから外します。
    Use the small flat end of a screw driver to push up the rt hand side of the bracket once youve removed the wire clip and also use to push up and pre release the lefthand side of the bracket. easier than pliers as it needs a bit of force and its safer as you dont want to break the plastic pins!
    ANDREW - 返信
  63. iPhone 7 のボリュームコントロールボタンの交換: 手順 63、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 63、 2の画像 2
    • 次にクリップをデバイスの上側に向けて引っ張り、取り出します。
  64. iPhone 7 のボリュームコントロールボタンの交換: 手順 64、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 64、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 64、 3の画像 3
    • ボリュームボタンのクリップを電話本体の底側に向けて引っ張り、ブラケットから外します。
    • 次に電話の上側に向けてクリップを引っ張り、取り出します。
    Step 95: It may be helpful to push the Volume buttons in while using the spudger. Otherwise, the bracket may get caught under the rim of the case.
    Mike - 返信
    To re install the clips, it is easier to use very small needle nose pliers than needle point tweezers. As, the clips tend to roll in the tweezers.
    Brian Copeland - 返信
  65. iPhone 7 のボリュームコントロールボタンの交換: 手順 65、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 65、 2の画像 2
    • スパッジャーの平面側先端をボリュームボタンブラケット端の下に差し込み、スライドします。
    • スパッジャーの位置を調整すると、リアケースからボリュームボタン上にある突出した杭に接触せずにブラケットを外すことができます。
    • スパッジャーを反対側までスライドしてボリュームボタン上の杭からブラケットを外してください。
  66. iPhone 7 のボリュームコントロールボタンの交換: 手順 66、 2の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 66、 2の画像 2
    • リアケースからブラケットを取り出します。
  67. iPhone 7 のボリュームコントロールボタンの交換: 手順 67、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 67、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 67、 3の画像 3
    • 同じ手順を繰り返して、2番目のボリュームボタンブラケットを取り出してください。
  68. iPhone 7 のボリュームコントロールボタンの交換: 手順 68、 3の画像 1 iPhone 7 のボリュームコントロールボタンの交換: 手順 68、 3の画像 2 iPhone 7 のボリュームコントロールボタンの交換: 手順 68、 3の画像 3
    • スパッジャーの先端を使って、リアケースから各ボリュームボタンカバーを押し出します。
    • ボリュームボタンカバーを外します。
    Niergends findet man ne info wie der stummtasten hebel ersetzt wird. Baue von schwarz auf rot um aber hier muss ich passen. Ich kann das ding welches man mit dem finger umschwitscht nicht austauschen…
    missing-in-army - 返信
終わりに
デバイスを再組み立てする際はこれらのインストラクションを逆の順番に従って作業を進めてください。
31 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Scott Havard
メンバー登録日: 06/27/16
49,645 ポイント
31のガイドは作成済み
10 件のコメント
Removing the battery is excluded from this repair.
Josh M - 返信
R u able to fix water damage
alex - 返信
Hi r u able to fix water damage for iPhone 7
alex - 返信
Hi Alex, the repairability of water damage varies hugely depending on your unique circumstances, but this guide is a good place to start. If the damage is extensive you may want to take your phone to a local repair professional.
Adam O'Camb -
Bonjour je voudrais savoir si vous avais la même explication mais pour iPhone 7+ s’il vous plaît ??
Lydia David - 返信
Does anyone know where to buy the little wire bars shown in step 62?
Trevor Smith - 返信
Tutoriel parfait juste il manque la partie pour retirer la batterie
Valentin Colmant - 返信
Do you know what the clip is used for is it just extra security?
Eduardo Ruiz - 返信
Can I follow this guide for an iPhone 7 plus? Are they similar enough that I can just use this guide to track what I’m doing?
Menelik Seth - 返信
Does this work for the iphone 8/8 plus too?
Steeve Tañedo - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 36
過去 30 日: 211
今までの合計 56,060
