メインコンテンツにスキップ
iPad Pro 12.9" 4th Gen Logic Board Replacement
必要な工具と部品
  1. iPad Pro 12.9" 4th Gen Logic Board Replacement, Prepare your iPad for disassembly: 手順 1、 1の画像 1
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the right edge: 手順 2、 1の画像 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
  3. iPad Pro 12.9" 4th Gen Logic Board Replacement, Anti-Clamp instructions: 手順 3、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Anti-Clamp instructions: 手順 3、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Anti-Clamp instructions: 手順 3、 3の画像 3
    この手順で使用する道具:
    Anti-Clamp
    $24.95
    購入する
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 4、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 4、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 4、 3の画像 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 5、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 5、 2の画像 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: 手順 6、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: 手順 6、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: 手順 6、 3の画像 3
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
  7. iPad Pro 12.9" 4th Gen Logic Board Replacement, Right edge information: 手順 7、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Right edge information: 手順 7、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Right edge information: 手順 7、 3の画像 3
    • Along the frame's right edge, there are two cutouts for the screen magnets where the adhesive is very thin. As you slice along this edge in the next step, don't insert your opening pick deeper than 2 mm in these locations:
    • One magnet begins 2 cm from the top edge and is 2.5 cm long.
    • The second magnet begins 3 cm from the bottom edge and is 2.5 cm long.
  8. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the right edge adhesive: 手順 8、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the right edge adhesive: 手順 8、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the right edge adhesive: 手順 8、 3の画像 3
    • Slide your opening pick back and forth along the right edge of the screen to slice the adhesive.
    • Angle your pick downward and insert it no more than 2 mm near the magnet cutouts and 5 mm everywhere else.
  9. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: 手順 9、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: 手順 9、 2の画像 2
    • Rotate your opening pick around the bottom right corner of the screen.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
  10. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the bottom edge: 手順 10、 1の画像 1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  11. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the bottom edge adhesive: 手順 11、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the bottom edge adhesive: 手順 11、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the bottom edge adhesive: 手順 11、 3の画像 3
    • Insert a second opening pick in the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to slice the bottom edge adhesive.
  12. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: 手順 12、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: 手順 12、 2の画像 2
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
  13. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the left edge: 手順 13、 1の画像 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  14. iPad Pro 12.9" 4th Gen Logic Board Replacement, Left edge information: 手順 14、 1の画像 1
    • Along the left edge of the screen, there are three cutouts for cables where the adhesive is very thin. As you slice along this edge in the next step, don't insert your opening pick deeper than 2 mm in these locations:
    • The upper cutout begins 4 cm from the top edge and is 2.5 cm long.
    • The middle cutout is exactly in the middle of the frame and is 2.5 cm long.
    • The lower cutout begins 4 cm from the bottom edge and is 2.5 cm long.
    • Everywhere else, don't insert your opening pick more than 5 mm.
  15. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the left edge adhesive: 手順 15、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the left edge adhesive: 手順 15、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the left edge adhesive: 手順 15、 3の画像 3
    • Insert a third opening pick in the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left edge adhesive.
  16. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: 手順 16、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the corner adhesive: 手順 16、 2の画像 2
    • Rotate your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the top edge: 手順 17、 1の画像 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. iPad Pro 12.9" 4th Gen Logic Board Replacement, Top edge information: 手順 18、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Top edge information: 手順 18、 2の画像 2
    • While the top edge adhesive softens, note the following:
    • There are two ambient light sensors near the corners. Only insert the very tip of your pick here to avoid damaging them.
    • There are three strips of heat dispersion tape. Angle your pick upward as you slice here.
    • The front-facing camera assembly is in the center of the top edge. Don't insert your pick here to avoid damaging them.
    • Everywhere else, don't insert your pick deeper than 5 mm to avoid damaging the screen.
  19. iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the top edge adhesive: 手順 19、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Slice the top edge adhesive: 手順 19、 2の画像 2
    • Slide your opening pick 9 cm toward the center of the top edge to slice the adhesive, paying attention to the spots mentioned in the previous step.
    • If you slice farther than 9 cm, you will reach the front camera assembly and risk damaging its components.
    • Leave your pick inserted. You will use another pick to slice the remaining adhesive.
  20. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 20、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 20、 2の画像 2
    • Insert a fourth opening pick to the right of the front camera assembly, 4 cm from the previous opening pick and 9 cm from the right edge of the screen.
    • Slide your pick to the top right corner to slice the remaining adhesive.
  21. iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: 手順 21、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: 手順 21、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: 手順 21、 3の画像 3
    • Grab two opposing corners of the screen and gently shift it around to separate it from the frame.
    • Don't fully remove the screen yet, as it's still attached by several cables.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive components mentioned in the previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
  22. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the upper cable shield: 手順 22、 1の画像 1
    この手順で使用する道具:
    FixMat
    $36.95
    購入する
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use your Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 1.8 mm-long screw
    • One 2.0 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  23. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: 手順 23、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: 手順 23、 2の画像 2
    • Use tweezers or your fingers to grab and remove the upper cable shield.
    • During reassembly, orient the shield so the notch faces up and to the right.
  24. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensors: 手順 24、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensors: 手順 24、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  25. iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: 手順 25、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: 手順 25、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the screen: 手順 25、 3の画像 3
    • Grip the right edge of the screen and fold it open like a book.
    • Don't pull on the screen—the ribbon cables near the bottom are still attached.
    • Lay the screen down over the left edge of the iPad.
  26. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the lower cable shield: 手順 26、 1の画像 1
    • Use your Phillips screwdriver to remove the five screws securing the lower cable shield:
    • Four 1.1 mm screws
    • One 2.0 mm screw
  27. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the lower cable shield: 手順 27、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the lower cable shield: 手順 27、 2の画像 2
    • Use tweezers or your fingers to grab and remove the lower cable shield.
  28. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the battery: 手順 28、 1の画像 1
    • Use your Phillips screwdriver to remove the 1.7 mm screw securing the battery connector to the logic board.
  29. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the screen: 手順 29、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the screen: 手順 29、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the screen: 手順 29、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the upper two display press connectors from the logic board.
  30. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 30、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 30、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 30、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the lower two display press connectors from the logic board.
  31. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the screen: 手順 31、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the screen: 手順 31、 2の画像 2
    • Grab and remove the screen from the frame.
  32. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the USB-C port: 手順 32、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the USB-C port: 手順 32、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the USB-C port press connector from the logic board.
  33. iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: 手順 33、 1の画像 1
  34. iPad Pro 12.9" 4th Gen Logic Board Replacement, Loosen the USB-C port cable: 手順 34、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Loosen the USB-C port cable: 手順 34、 2の画像 2
    • Slide an opening pick under the USB-C port cable to separate it from the logic board.
  35. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the USB-C port: 手順 35、 1の画像 1
    • Use your Phillips screwdriver to remove the two 1.6 mm-long screws securing the USB-C port.
  36. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the USB-C port: 手順 36、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the USB-C port: 手順 36、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the USB-C port: 手順 36、 3の画像 3
    • Grab and remove the USB-C port from its recess in the frame.
    • Use caution not to lose the grounding contacts on either side of the USB-C recess.
    • During reassembly, install the USB-C port underneath the grounding contacts.
  37. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the upper cable shield: 手順 37、 1の画像 1
    • Use your Phillips screwdriver to remove the four screws securing the upper cable shield:
    • Three 1.1 mm screws
    • One 2.0 mm screw
  38. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: 手順 38、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the upper cable shield: 手順 38、 2の画像 2
  39. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the front camera assembly: 手順 39、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the front camera assembly: 手順 39、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the front camera assembly: 手順 39、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the three press connectors for the IR dot-projector, front camera, and Face ID camera.
  40. iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the camera cables: 手順 40、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the camera cables: 手順 40、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the camera cables: 手順 40、 3の画像 3
    • Use blunt nose tweezers to grab and peel the left and middle front camera assembly cables from the logic board.
  41. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the bracket: 手順 41、 1の画像 1
    • Use your T3 Torx screwdriver to remove the two 2.2 mm screws securing the front camera assembly bracket.
  42. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 42、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 42、 2の画像 2
    • Use the flat end of your spudger to pry the front camera assembly bracket from its recess.
    • The bracket is secured by heat-resistant epoxy which requires significant force to weaken. Work slowly and avoid prying against the surrounding components.
  43. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the front camera assembly bracket: 手順 43、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the front camera assembly bracket: 手順 43、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the front camera assembly bracket: 手順 43、 3の画像 3
    • Use tweezers or your fingers to grab and remove the front camera assembly bracket from its recess.
    • Use a spudger to scrape and remove any residual epoxy before reinstalling the bracket.
  44. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the rear camera shield: 手順 44、 1の画像 1
    • Use your Phillips screwdriver to remove the six screws securing the rear camera shield:
    • Three 1.2 mm screws
    • One 2.8 mm screw
    • One 2.6 mm screw
    • One 1.8 mm screw
  45. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear camera shield: 手順 45、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear camera shield: 手順 45、 2の画像 2
    • Use tweezers or your fingers to grab and remove the rear camera shield.
    • During reassembly, insert the tab on the left of the shield first.
  46. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the power button: 手順 46、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the power button: 手順 46、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the power button: 手順 46、 3の画像 3
    • Use the point of your spudger to pry up and disconnect both of the power button's press connectors.
  47. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the power button assembly: 手順 47、 1の画像 1
    • Use your Phillips screwdriver to remove the two 2.3 mm screws securing the power button assembly.
  48. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button assembly: 手順 48、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button assembly: 手順 48、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button assembly: 手順 48、 3の画像 3
    • Insert the point of your spudger between the left edge of the power button assembly and the frame.
    • Pry the assembly up from its recess in the frame.
    • Grab and remove the power button assembly.
    • Use a spudger to scrape and remove any residual epoxy before reinstalling the assembly.
  49. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button: 手順 49、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button: 手順 49、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the power button: 手順 49、 3の画像 3
    • Push the power button through its recess from the outside of the frame.
    • Remove the power button.
  50. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear cameras: 手順 50、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear cameras: 手順 50、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the wide-angle camera from the logic board.
  51. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 51、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 51、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 51、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the LiDAR sensor and ultrawide camera from the logic board.
  52. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear cameras: 手順 52、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear cameras: 手順 52、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the rear cameras: 手順 52、 3の画像 3
    • Insert the point of your spudger between the top right corner of the rear cameras and the frame.
    • Pry the cameras up until you can grab them with tweezers or your fingers.
    • Remove the rear cameras.
  53. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the Smart Connector cover: 手順 53、 1の画像 1
    • Use your Phillips screwdriver to remove the two 1.9 mm screws securing the Smart Connector cover.
  54. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the Smart Connector cover: 手順 54、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the Smart Connector cover: 手順 54、 2の画像 2
    • Use tweezers or your fingers to grab and remove the Smart Connector cover.
  55. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the Smart Connector: 手順 55、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the Smart Connector: 手順 55、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the Smart Connector from the bottom of the logic board.
  56. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the speaker cable shield: 手順 56、 1の画像 1
    • Use your Phillips screwdriver to remove the 2.0 mm screw securing the lower left speaker cable shield.
  57. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the speaker cable shield: 手順 57、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the speaker cable shield: 手順 57、 2の画像 2
    • Remove the lower left speaker cable shield.
  58. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower speakers: 手順 58、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower speakers: 手順 58、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower speakers: 手順 58、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the lower speaker press connectors.
    • Avoid prying against the sides of the connectors. The sockets on the logic board are delicate and may bend if pried against.
    • Disconnect all four connectors for the lower speakers.
  59. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper speakers: 手順 59、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper speakers: 手順 59、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper speakers: 手順 59、 3の画像 3
    • Use the point of your spudger to pry up and disconnect all four upper speaker press connectors.
  60. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper antenna cable: 手順 60、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper antenna cable: 手順 60、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper antenna cable: 手順 60、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the upper antenna cable from the right edge of the logic board.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
  61. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower antenna cable: 手順 61、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the lower antenna cable: 手順 61、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the lower antenna cable from the left edge of the logic board.
  62. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the remaining antenna cables: 手順 62、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the remaining antenna cables: 手順 62、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the remaining antenna cables: 手順 62、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the remaining two antenna cables from the left edge of the logic board.
  63. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensor cable: 手順 63、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the upper sensor cable: 手順 63、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the upper sensor press connector from the logic board.
  64. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear sensor cable: 手順 64、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the rear sensor cable: 手順 64、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the rear sensor press connector from the right arm of the logic board.
  65. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the volume buttons: 手順 65、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the volume buttons: 手順 65、 2の画像 2
    • Use the point of your spudger to pry up and disconnect the volume press connector from the right arm of the logic board.
  66. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the upper antenna cable: 手順 66、 1の画像 1
    • Apply a heated iOpener to the upper antenna cable and right arm of the logic board for two minutes.
  67. iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the upper antenna cable: 手順 67、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the upper antenna cable: 手順 67、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the upper antenna cable: 手順 67、 3の画像 3
    • Use blunt nose tweezers or your fingernail to peel the tape securing the upper antenna cable to the right arm of the logic board.
    • Don't try to fully remove the cable—one more piece of tape secures it to the logic board.
    • If the tape feels stuck, pull the body of the cable with your fingers as you peel the tape.
  68. iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the upper antenna cable: 手順 68、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the upper antenna cable: 手順 68、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Reposition the upper antenna cable: 手順 68、 3の画像 3
    • Peel the second strip of tape securing the upper antenna cable to the logic board near the rear camera cutouts.
    • Reposition the cable away from the logic board.
    • Don't twist or rotate the antenna cable—it's still connected to the antenna.
  69. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the lower antenna cable: 手順 69、 1の画像 1
    • Apply a heated iOpener to the lower antenna cable, located along the left edge of the logic board, for two minutes.
  70. iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the lower antenna cable: 手順 70、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the lower antenna cable: 手順 70、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Peel the lower antenna cable: 手順 70、 3の画像 3
    • Grab the lower antenna cable, just below its metal connector head.
    • Peel the cable from the left edge of the logic board.
  71. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 71、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 71、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 71、 3の画像 3
    • Peel the lower antenna cable from the logic board near the battery connector.
  72. iPad Pro 12.9" 4th Gen Logic Board Replacement, Heat the logic board cover: 手順 72、 1の画像 1
  73. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board cover: 手順 73、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board cover: 手順 73、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board cover: 手順 73、 3の画像 3
    • Use your fingers to grab a corner of the logic board cover.
    • Peel and remove the cover from the logic board.
    • Work slowly to avoid tearing the cover.
    • The cover has many layers. Make sure the copper tape doesn't separate from the foam layer.
  74. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the press connector bracket: 手順 74、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the press connector bracket: 手順 74、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the press connector bracket: 手順 74、 3の画像 3
    • Use the flat end of your spudger to slide the bottom right press connector bracket away from the logic board.
    • Use blunt nose tweezers or your fingers to remove the bracket.
    • During reassembly, orient the bracket so the outward-bent wings face the battery.
  75. iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the microphone and Apple Pencil charger: 手順 75、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the microphone and Apple Pencil charger: 手順 75、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Disconnect the microphone and Apple Pencil charger: 手順 75、 3の画像 3
    • Use the point of your spudger to pry up and disconnect the microphone and Apple Pencil charger press connectors.
  76. iPad Pro 12.9" 4th Gen Logic Board Replacement, Unfasten the logic board: 手順 76、 1の画像 1
    • Use your Phillips screwdriver to remove the four 1.8 mm screws securing the logic board.
  77. iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: 手順 77、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: 手順 77、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Soften the adhesive: 手順 77、 3の画像 3
    • Apply several drops of highly-concentrated isopropyl alcohol (over 90%) to the bottom and right edges of the logic board.
    • Elevate the right edge of the iPad to allow the isopropyl alcohol to flow under the logic board.
    • Wait one minute for the isopropyl alcohol to penetrate.
  78. iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 78、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 78、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement: 手順 78、 3の画像 3
    • Apply isopropyl alcohol to the right arm and left edge of the logic board.
    • Elevate the left edge of the iPad to allow the isopropyl alcohol to flow under the logic board.
  79. iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: 手順 79、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Insert an opening pick: 手順 79、 2の画像 2
    • Insert an opening pick between the bottom edge of the logic board and the Smart Connector.
  80. iPad Pro 12.9" 4th Gen Logic Board Replacement, Replace the battery blocker: 手順 80、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Replace the battery blocker: 手順 80、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Replace the battery blocker: 手順 80、 3の画像 3
    • Remove the card strips blocking the battery connector.
    • Gently insert the tip of an opening pick between the logic board and the battery connector.
    • Don't pry on the battery connector or logic board, as the spring connectors are easily damaged.
    • Leave this pick inserted until the logic board is completely removed.
  81. iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the left edge: 手順 81、 3の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the left edge: 手順 81、 3の画像 2 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the left edge: 手順 81、 3の画像 3
    • Use the first opening pick to pry up the left edge of the logic board.
    • Don't forcefully lever against the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • If the logic board feels stuck, apply more isopropyl alcohol.
  82. iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right arm: 手順 82、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right arm: 手順 82、 2の画像 2
    • Use your opening pick to pry up the right arm of the logic board.
    • This arm of the logic board is thin and fragile. Be careful not to bend it.
  83. iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right edge: 手順 83、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Pry up the right edge: 手順 83、 2の画像 2
    • Use your opening pick to pry up the right edge of the logic board.
  84. iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board: 手順 84、 2の画像 1 iPad Pro 12.9" 4th Gen Logic Board Replacement, Remove the logic board: 手順 84、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $8.99
    購入する
    • Grab and remove the logic board from the frame.
    • Be careful not to reinstall the logic board on top of any cables or connectors.
    • During reassembly, apply double-sided tape such as Tesa tape to secure the logic board if the existing adhesive isn't sufficient.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 12.9" 4th Gen Answers community for help.
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
66,727 ポイント
453のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,157のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 31
過去 30 日: 144
今までの合計 1,934
