メインコンテンツにスキップ
iPad Air Wi-Fiモデルの左側アンテナの交換
必要な工具と部品
  1. iPad Air Wi-Fiモデルの左側アンテナの交換, iOpenerの使用方法: 手順 1、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, iOpenerの使用方法: 手順 1、 2の画像 2
    • 電子レンジに付着している汚れがiOpenerに付いてしまうことがあるので、使用前に電子レンジの底をきれいに拭き取ってください。
    • iOpenerを電子レンジ中央に置きます。
    • 回転型の電子レンジ:iOpenerが電子レンジのターンテーブルで回転しているか確認してください。iOpenerが作動中に留まってしまうと、熱しすぎや焦げてしまいます。
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 返信
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 返信
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 返信
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 返信
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 返信
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 返信
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 返信
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 返信
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 返信
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 返信
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 返信
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 返信
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 返信
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 返信
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 返信
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 返信
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 返信
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 返信
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 返信
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 返信
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 返信
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 返信
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 返信
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 返信
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 返信
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 返信
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 返信
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 返信
    Can’t you just use a hair curler instead?
    Aspect22 - 返信
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 返信
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 返信
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 返信
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - 返信
  2. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 2、 1の画像 1
    • iOpenerを30秒温めます。
    • お使いの電子レンジの出力ワット数によって、温めるために必要な時間が異なる可能性があります。iOpenerを使う際は、素手ではぎりぎり触れない程度に温めれば十分です。
    • 修理作業中はiOpenerが冷めてしまいますので、使用毎に電子レンジに30秒入れて温めてからご利用ください。
    • 作業中、iOpenerを温めすぎないようにご注意ください。過熱すると、iOpenerが破裂することがあります。100˚Cを超えるまで加熱しないでください。
    • 膨らんでいる状態のiOpenerは絶対に触らないでください。
    • 適切に温められたiOpenerは約10分間、温かい状態を保ちます。
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 返信
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 返信
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 返信
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 返信
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 返信
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 返信
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 返信
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 返信
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 返信
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 返信
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 返信
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 返信
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 返信
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 返信
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 返信
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 返信
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 返信
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 返信
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 返信
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 返信
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 返信
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - 返信
    I tried 600W microwave for 30 sec and it was nicely warm, did nothing on iPad. Added 10 more sec, bit warmer, another 20 sec and it was finally a bit hot to hot in the hand - but still didn't do anything on iPad. I switched to a hair dryer as I used to work with it before, while being a bit sad about not using this brand new iOpener tool. And I found it short on 12.9 iPad anyway, maybe next time.
    Liibo - 返信
  3. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 3、 1の画像 1
    • 電子レンジからiOpenerを取り出します。iOpenerの中央は熱くなっているため、両端の平面になっている部分を持ってください。
    • iOpenerは大変熱くなっていることがあります。必要であれば、オーブン用のミトンカバーをご利用ください。
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 返信
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 返信
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 返信
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 返信
    This thing melts when placed up side down in the microwave…
    Mark - 返信
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 返信
  4. iPad Air Wi-Fiモデルの左側アンテナの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, iOpenerを使った他の温熱方法: 手順 4、 2の画像 2
    • 電子レンジがない場合は、熱湯の中にiOpener をいれて温める方法もあります。
    • 鍋を十分な量のお湯で満たして、iOpener を完全に沈めます。
    • お湯を沸かして熱くなったら火を止めます
    • iOpenerを熱湯の中に約2−3分間沈めます。iOpener全体が完全に浸かっているか確認してください。
    • トングなどを浸かって、温まったiOpenerをお湯から取り出します。
    • タオルでiOpener全体を拭き取ります。
    • iOpenerが非常に熱い場合は、先端のタブを持って火傷をしないようにご注意ください。
    • iOpenerの準備は整いました。iOpenerを再度温める必要がある場合は、お湯を沸騰させて、火を止めてからiOpenerを2-3分間浸してください。
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 返信
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 返信
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 返信
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 返信
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 返信
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 返信
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - 返信
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - 返信
  5. iPad Air Wi-Fiモデルの左側アンテナの交換, フロントパネル: 手順 5、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, フロントパネル: 手順 5、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換, フロントパネル: 手順 5、 3の画像 3
    • ディスプレイガラスにひびが入ってしまった場合、割れてしまった部分が広がらないようにガラス表面上にクリアテープを貼るなどして、怪我がないようご注意ください。
    • iPadディスプレイ上にクリアタイプのテープを何重にも貼り、全体を覆います。
    • これはディスプレイをこじ開けて引き上げた際に、ガラスの破片が飛び散るのを防ぐことができます。
    • ここに書かれている手順にできるだけ従ってください。しかしながら、ガラスが一旦割れてしまうと、作業を続けていくにつれてひびが広がってしまう可能性があります。この場合、ガラスを取り出すためにはメタル製工具を使用する必要があります。
    • 目を保護するために保護メガネを装着してください。また液晶ディスプレイスクリーンにダメージを与えないようにご注意ください。
    If you add clear packaging tape, it will create bubbles and the suction cup will become inefficient. To me it was impossible to remove the glass with the suction cup. Since the glass was very cracked, I had to resort to some tweaking with strong tape and pull the this off.
    jfmartin67 - 返信
    If your screen is significantly cracked to the left edge, abandon this entire setup, prepare yourself for a 5-6 hour repair, expect a lot of patience, a lot of cursing and some good old American ingenuity. The suction cup and picks will not work. You have to carefully crack the glass yourself (w/out damaging the panel underneath and carefully pull it apart from the inside to the outside edges. Use a hairdryer to soften the glue under the cracked panel along the edges. Then use an exacto-knife to separate the pieces of the glued panel from the frame body, all the way around the device. Watch out for the home button ribbon connector when using the exacto-knife. There will be glue residue left over, carefully apply some goo-gone to a small area of a paper towel and wipe gently around the frame body to loosen the glue. Then use the plastic spudger tool to scrape off the excess glue.
    The iPad repair is VERY difficult. If you are a working adult, hire a pro. This is not for the faint of heart.
    aaroncope - 返信
    The hairdryer option was way faster and easier than the iOpener. Be VERY careful not to damage the LCD- one small mistake will cost you an extra $100!
    Mike Martin -
    but I’m not American
    Andrew Williams -
    If your digitizer is shattered, the tape will help, but you’re going to need extra picks. Or a razor blade. See below.
    Blair Miller - 返信
    Friendly observation that the image on this step is actually of an older ipad model as the side bezels are far too big. I don't know if that matters to anybody but a noob might see it and think this manual doesn't apply to them. : )
    notalawyer - 返信
    Thank you! Yes things like this matter so much. I successfully replaced an iPhone 6LCD&Screen from the guide. Next was my iPad 2 and the guide said nothing about the power flex cable. They were only stressing about not severing the wifi cable. I followed instructions carefully. Got the screen off and bam. Power flex severed because it was left out of the guide. I saw it in the comments after. I’ll never follow a guide here again without reading the comments. I did receive a discount code for my next purchase but it still caused a lot of inconvience.
    Haley Hodges -
    I had the same experience. My glass was cracked all the way to the left side and the suction cup would not pull the glass up. The packaging tape also didn't help. The heat caused it to lift. I finally abandoned the tape, used a heat gun aimed very carefully at each broken piece of the screen. The picks did work with patience, but I just pulled off each broken part of the glass. I also found that pulling up on one broken part while heating in front of me would let the next piece pull up. I continued heating and breaking all the way around. Do the right side last. Took about 1 hour to get it off, and another hour to clean the old glue off the frame. BTW thanks to this web site and all the comments! No way I would have done this without all the help here! I am now clean and waiting for my new digitizer. I couldn't free the battery (below), so I left it powered up, and verified it till worked before throwing away the old glass. Vince
    Vince Asbridge - 返信
    Taping with package tape doesn't work. You'll need a very large piece of tape if you go this route.
    Travis Dixon - 返信
    Just finished successful repair. I would add this: most folks will be here because of cracked screen. This is not easy; believe the 'complex' rating on this repair. I put tape on my screen because it was badly cracked. This made the suction cup useless, because it just sucked the tape off the scree.n. I used the razor blade technique which worked great, it should be used in the demo, and a good blade should be in the kit.
    dale kingsbury - 返信
    I thought this shouldn’t be too hard - I only had some cracks in the glass, but then at every spot I worked on, the glass turned into nothing but tons of tiny shards. I had to use the points of the tweezers plowing along only the outer edge all the way around, sometimes with a razor blade and often using a hair dryer up close (briefly, over and over). After I got every bit of glass out, I used ordinary rubbing alcohol and Q-tips but I had to rub hard and quickly 100 times on each area to slowly dissolve the glue. I only scratched the LCD once slightly with a tweezer slip. The large chucks of display held together by the packing tape needs something under it to protect the LCD while you are working.
    Robin - 返信
    Using Goo Gone to get rid of the adhesive residue is 20 times faster than using rubbing alcohol, even if it is 91% isopropyl alcohol.
    Skipping the iOpener and using a hair blowdryer, and using Goo Gone in place of the rubbing alcohol are 2 simple changes that will make this job much much easier than the default instructions if the screen is shattered.
    Scott Walker -
    I found the hair dryer is far more effective and less dangerous than using the iopener. If you overheat the iopener you end up pulling a hot plastic bag spewing hot glycerine out of your microwave! Not fun!
    Clifford Sullivan - 返信
    Packing tape won’t do anything. You need to use duct tape to prevent glass shards from spraying everywhere. If your screen is only partially cracked (mine was the top only), modify the directions and focus on the areas that aren’t cracked first. I was able to get the lower 90% of the screen off, and then worked the cracked pieces with a heat gun and metal razor spudger. The entire repair took around 3 hours, and prob 2 hours and 30 min of that was getting the shards out and pieces off. And lots of cursing. I also told my kids if they crack another screen they are out of luck. I am not doing this again.
    Janie Hughes - 返信
  6. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 6、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 6、 2の画像 2
    • 温めたiOpenerをiPadのホームボタンアセンブリの左側サイドに当たるように置きます。
    • iOpenerを約1分間置き、ガラスの下に付けられた接着剤を柔らかくします。
    The iOpener doesn't work because the heat isn't strong enough. I used a hair dryer which proved to be much more efficient.
    jfmartin67 - 返信
    The iOpener didnt work for me either. seems like it gets hot enough but it must not. I spent 30 min with the iOpener, then tried a hair dryer.
    kinchma - 返信
    “At least a minute.” Bullshit. Get the iOpener good and hot, place it on the area you’re going to work on clear side down, and cover it with a towel. Walk away for 2 minutes. Make yourself a drink — you’ll need steady hands later.
    Blair Miller - 返信
    I've done this with an iOpener and at least in my case, it worked fine. You may have to modify the heating instructions though, since not all microwaves are created equal.
    Jeff Suovanen - 返信
    ii i just did this and it took a while but i figured it out it is true this thing doesnt get hot enough BUT heat it 2 times and then the 3rd time when u place it on the ipad put the ipad box on top and then maybe a second ipad on top of the box so it kinda smashes i down but not too much for it to break and then wait for it to turn warm THEN use the succion THEN the gap appears. the glue is super strong on the ipads so yea it will take some time lol
    Joel Tyson - 返信
    Doesn't work. Perhaps include more copy on exactly how to do it?
    Travis Dixon - 返信
    The iOpener does not work. It simply it is not hard enough to soften the glue. The heat hair dryer method does not work either.
    Javier Lozada - 返信
    The goal is simply to weaken the glue enough that you can use your suction cup to open up a tiny gap under the glass, so you can insert an opening pick and slice through the adhesive. It doesn't actually take all that much heat; the picks will do most of the work once you get them in there. iOpeners, hair dryers, heat guns all work fine in my experience—the iOpener is just a bit more foolproof because it won't get hot enough to cook the display panel underneath.
    Jeff Suovanen - 返信
    I used iron..surprise!! yeah pretty fast tho…put a layer of fabric (towel in my case) ontop, along the edge of screen and start ironing..
    carvelera - 返信
    If using a hair dryer or heat gun make sure it is not too high heat. My heat gun has two settings, one 750 degree and an 1100. After using it on high I discolored the digitizer and warped the LCD slightly (only shows on pure white backgrounds). Low worked for the rest of the repair just fine. Also using a razor blade or something besides the pick works nice for the initial pry. Once you have a gap big enough, insert the pic and you’re all set.
    Robert - 返信
    I don’t have an iOpener, my heat gun wasn’t handy. The last time I did something like this it was a 90-100 degree day, so I just put it out in the sun for a while, and it worked great. This time it’s fall, so I used a 420W halogen Light that I have for photography. (A standard heat lamp would probably work too, but might take longer.) I held it close to the light until it felt hot to the touch, just a couple minutes, then I left is sitting about 16” below the light for 5-10 minutes to sink in and warm uniformly. It worked great.
    For me, steps 8-31 were basically one step "Carefully pry off the digitizer glass with the plastic tools" took all of 30 seconds.
    Seth Childers - 返信
    Although very hard this does work. The first time opening the ipad after buying it 8+ years ago it took about 3 times of heating the iopener. It did require an amount of pressure I did not expect but it did come open as instructed. I did add a towel and apply pressure to the iopener to make sure the heat transferred.
    hmcarbajal - 返信
    The iOpener didn’t work for me at all, zero, it literally did nothing. I resorted to my heat gun on low and yeah you need to be super careful, but once I started the adhesive came off pretty easy.
    David Yutzy - 返信
    I used a 2-level heat gun, too. Supposedly 707 degrees/923 degrees.
    I kept the heat gun about 1” away from the glass and used only the low setting. Even so, I did alter the digitizer pretty quickly in a few locations around the edge. It still functions fine, and you only see it under certain circumstances, so not a huge deal. But irritating. Be cautious about too much heat. It just looks like sort of a faint, polarized grid.
    Don’t be afraid to put tension on the glue and just hold it. If it is warm enough, the glue will relax under sustained tension. This isn’t a speed event. Don’t try to rush it, or you’ll break something.
    Now that those infrared surface thermometers have become so inexpensive, it would be great if someone posted a target temperature for softening the glue without damage. That would take some of the guesswork out of this process.
    Tim - 返信
    If you heat the iOpener somewhat longer than they recommend, and get it about as hot as your hand can stand, then place it on the iPad and cover with a towel for at least 3 minutes. Then really be patient. I got a bit impatient, and took a chance and slipped a really fine “exacto-type” of blade vertically beside the suction cup as I lifted, and thankfully that worked. That made enough room to get one of the “guitar pick” wedges in. The rest went fine.
    Pete - 返信
    I used the iOpener to soften the adhesive. I was extra careful and it took me about 90 minutes to get to Step 30. With my acquired experience I would say, it may be done in about 30 minutes. Most important: Be patient! You may have to reheat the iOpener a few times until you will be able to do Step 9. Once I had this part done, it was a lot easier. So I would say the first 60 minutes I spent on steps 1 through 9.
    marcelflueeler - 返信
    I’ve been using a heat and isopropyl alcohol combo on iPhone screens with no problem. This specifically says “only” heat. I feel like she’s trying to tell me to keep a lid on my IA. Because I don’t know what other methods some rogue might be trying in their efforts to compromise adhesive.
    Audi Archer - 返信
  7. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 7、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 7、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 7、 3の画像 3
    • iPadは外側から見るとしっかりとした作りに見えますが、フロントガラスの下には壊れやすいコンポーネントが存在しています。これらにダメージを与えないためには、各手順で指定されたエリア以外は温めたりこじ開けたりしないでください。
    • この手順を進んでいく中で、次のエリアはこじ開けたり、接触しないように特にご注意ください。
    • 正面カメラ
    • アンテナ
    • ディスプレイケーブル
    Don't assume anything!! I thought I was pulling on the screen connector and I was pulling on an antenna component instead. Didn't ruin its connection range but I sure remember doing it and now my iPad has a little internal flaw only I'm aware of.
    Travis Dixon - 返信
    Correct me if I’m wrong but the LTE version apparently has 2 antennas on each side of the front-facing camera and it’s not shown on this post to avoid prying. I just scratched one of them following these instructions.
    Pacman - 返信
    A note about the multiple image thumbnails - roll your mouse over them to get an animated effect, rather than clicking on them individually
    Rusty - 返信
    Audi Archer - 返信
  8. iPad Air Wi-Fiモデルの左側アンテナの交換, リバースクランプの使用方法: 手順 8、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, リバースクランプの使用方法: 手順 8、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換, リバースクランプの使用方法: 手順 8、 3の画像 3
    この手順で使用する道具:
    Clampy - Anti-Clamp
    $24.95
    • 次の2つの手順では、デバイスの開講作業を簡単にするために開発されたツール、リバースクランプの使い方を紹介します。リバースクランプを使用しない場合は、この3つの手順をスキップして別の方法をご覧ください。
    • リバースクランプの詳細な使用方法については、 こちらのガイドをご覧ください。
    • 青いハンドルを後方に引き、リバースクランプのアームのロックを解除します。
    • 青いハンドルをヒンジ側に引くと、オープニングモードが解除されます。
    • 吸盤を左端の中央付近に配置し、上下に1つずつ装着します。
    • リバースクランプの下部をしっかりと固定し、上部カップをしっかりと押し下げて吸盤を装着ます。
    • iPadの表面が滑りやすく、リバースクランプがしっかりと装着できない場合は、梱包用テープで表面を覆ってから、強いグリップを作ることができます。
  9. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 9、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 9、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 9、 3の画像 3
    • 青いハンドルを手前に引くと、アームがロックされます。
    • ハンドルを時計回りに360度回転させ、カップが両側をストレッチするまで回し続けます。
    • 吸盤の位置が合っていることを確認してください。装着位置がずれ始めたら、吸盤を少し緩めてアームを装着し直してください。
  10. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 10、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 10、 2の画像 2
    • 青いハンドルをヒンジから離して前方に向かって押し、オープニングモードにします。
    • 画面が十分に熱くなっていない場合は、ドライヤーを使ってiPadの左端に沿って熱を加えることができます。
    • ヘアードライヤーの詳しい使い方は、こちらのガイドをご覧ください。
    • 接着剤がはがれて、底面が開くまでそのまま1分ほど同じ状態を保ちます。
    • リバースクランプで十分な隙間ができたところで、スクリーンのフレームの下にオープニングピックを挿入します。
    • リバースクランプで十分な隙間ができない場合は、その部分にさらに熱を加えて、ハンドルを時計回りに半回転させてください。
    • 一度に半回転以上回さず、1分ほど待ってからさらに半回転、回します。時間をかけてリバースクランプを回していきます。
    • 次の2つの手順はスキップしてください。
  11. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 11、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 11、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 11、 3の画像 3
    • 温めた側の真ん中から少し上辺りに、吸盤カップを取り付けます。
    • しっかりと吸盤がスクリーンに装着されるにはカップがスクリーン上に完全に平らに付いているか確認してください。
    • iPadを片手で押さえながら、背面ケースをフロントパネルのガラスから離すために吸盤カップを上部に向けて引っ張りあげます。
    • iPadのスクリーンの破損がひどい場合は、透明なパッキングテープで表面を覆うと、吸盤がうまく接着します。 または、強力なテープ(ダクトテープなど)を使用して、ハンドルに折りたたんでください。
    In this picture above, the glass isn't cracked at all so it helps the suction cup to be effective as it is hermetic. With cracked display, it won't work.
    jfmartin67 - 返信
    Suction cup would not work for me. No amount of heating with iOpener or hair dryer would allow even the slightest gap to form. I ended up looking at some YouTube videos and used a razor blade. I put the razor blade perpendicular to the top glass, right at the edge of the glass and pushed down until the blade went down 1/4". Then heated some more and pried up the glass enough to put in an opening pick. I spent a lot of time working with the suction cup. Glue was just too strong.
    kinchma - 返信
    It's funny that iFixit changed the image they used. Even they themselves realized how stupid it was to try a suction cup on taped up surface. C'mon guys! You should at least make foot notes for your readers and let them know what to do if the glass is already shattered. It's a slow methodical process that involves working with a iOpener type tool. I personally have one that looks like a prison shank (lol)
    Scott S - 返信
    Not sure what you are referring to there—I see no evidence in the document history of the photos having been changed. Suction cup + packing tape can work, but it depends how badly the glass is broken and the quality of the tape. Sometimes it takes a couple attempts. You can also skip the suction cup and try using tape alone to pull on the panel, if your tape is sticky enough. There are no guarantees though, which is why we have the disclaimer right in Step 4 that the procedure can be pretty fussy if you're working with a shattered panel. Depending on where it's broken and how badly, you're going to have to improvise.
    Jeff Suovanen -
    Jeff, the change is evident from image 4, where all the surface is taped up. In this picture you show a clean not broken surface and yes, the suction cup works...
    Simone Gabbriellini -
    Ah, I see what you're saying! I can understand why you guys would assume that, but in reality the entire guide was originally photographed using an intact panel. We later added a step showing how to protect yourself if you have a shattered panel (with photos to go along with, obviously). I'm afraid it wouldn't be practical to re-shoot the entire guide every time we make a small change like that.
    Jeff Suovanen -
    The suction cup is useless if your glass is shattered. Use a new, sharp razor blade, and insert it vertically between the edge of the glass and the metal back of the iPad. Don’t worry about pressing too hard — there’s a lip that stops the blade from going in too far and damaging anything. You’ll probably have to do this several times, but eventually the blade will “bite” into the edge of the glass well enough for you to pry it up. Insert a pick underneath the razor, then remove the razor and continue as directed.
    Blair Miller - 返信
    After having to read several comments on this screen removal and the clear packing tape, I too have to agree that the tape method does not work well at all if your screen is already shattered. I combined several methods, with lots of patience to remove the screen on my iPad Air 2. What I found it very helpful was the heat gun used for paint removal. The heat gun generates a lot of concentrated heat at lower air velocity, unlike generic hair dryer, so you must be very careful not to ruin the electronics, and risk burning your hands and anything around it. My heat gun that I purchased from Home Depot had a nozzle to direct and focus the heat on a small area. That was helpful in working small area at a time. This method work thoroughly well.
    Taiji Saotome - 返信
    It would work if you leave iopener in microwave for 1 minute.
    Don’t trust the instruction from ifixit.
    you can put iopener in microwave for 1 minute without any harm.
    Note. you have to make sure that it is in cold position before you put it into microwave.
    phongsiri nirachornkul - 返信
    Suction cup didn’t work for me either, went the razor blade route (using an exacto knife blade) with very minimal damage to the aluminum shell. Be warned, if your screen has cracked along the edge (as it almost 100% certainly has if you’re reading this guide), the screen will continue to shatter and splinter as you make your way around the edge. That’s when having the screen taped up well will be to your advantage. There’s also a good chance you’ll have to re-insert the razor blade on the other side of a fracture and start the lifting process again, but keep going, being sure to avoid the points called out in this guide and you should be fine.
    Also, do not apply the suction cup to an area of the screen with cracks and no tape. If you’re near the edge you run the risk of brutally shattering that area of the glass if the glass gives before the suction cup.
    Micah Sledge - 返信
    In order to get this to work for me I had to heat the IOpener to over 104 C - I needed to get the screen over 40 C before the adhesive would loosen.
    Also I had to put the ipad on a towel - the granite countertop it was on was sucking the heat out too fast.
    Jack Williams - 返信
    This step was brutal on my nerves - read about too many people ruining their iOpener and I don’t have a heat gun. I had to keep heating the iOpener incrementally hoping I wouldn’t pop it. … but if you’re patient, persistent, and cautious, you can definitely tell when you’re seeing separation. The iOpener ended up being WAY hotter than 30 seconds was getting me - borderline scorching my hands.
    William Thompson - 返信
    Could not loosen the adhesive using the iOpener. Had to use hair dryer.
    Erwin yi - 返信
    As the others noted, the suction cup is useless on a cracked screen, especially if you’ve applied tape (like the instructions say you should). The screen I was working on was busted up pretty bad, I ended up removing it and then going back to remove the edge glass and adhesive. When you have a really busted screen just take your time and use a heat gun or good hot hair dryer and it will eventually come off.
    I used an iSesame tool vs a razor to pry the edge (from a previous replacement project) but again, the iOpener and suction cup are useless.
    David Yutzy - 返信
    Thank you for the comments above. I was using the iOpener unsuccessfully, then turned to the hair dryer and heated it up for over 3 minutes. This gave me the gap I needed to insert the opening pick and begin the process. So, with patience and a hair dryer, I was able to get the digitizer off.
    0812mgr - 返信
    You really need a lot of patience here (30-45min). But then it works. The best way was with this plastic "crowbar" to get the beginning. You really have to press hard to get in between.
    Arne Meier - 返信
    The suction cup provided in the toolkit didn't work on anything. Tape helped, but I eventually went in through a small cracked shard to create an entry point at the bezel
    Tom Weber - 返信
    I've passed on the iOpener as suggested in these comments and have tried to use a hairdryer. heating on high at medium speed for 1 minute then trying the suction cup. heating for another minute then using the suction cup. Been doing this for 1/2 an hour but it isn't working. Need to take a break because I'm afraid I'm going to hurt in internal components of the iPad 6 (just trying to replace a dead battery) Any suggestions ???
    Just a guy - 返信
    LOL...i tried the pastic clear tape to hold the cracked glass then apply the hairdryer. It melted the plastic tape glue and thus making the handle with the duct tape useless and the duct tape just pulled the melted glue from the plastic packing tape up like butter. But the screen still not budging. I've tried the hair dryer for 5 mins and nothing. I've tried the iOpener and that's useless. I'm heating it up 30 secs a time. I tried 1 min. The screen is welded shut.
    brian -
  12. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 12、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 12、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 12、 3の画像 3
    • 吸盤カップによって引き上げられた際に出来る隙間に開口ピックを差し込みます。
    • 開口ピックをディスプレイ横にある黒い外縁よりも深く差し込まないでください。このピックを深くまで差し込んでしまうと液晶ディスプレイを傷つけてしまうことがあります。
    • 吸盤カップのプラスチック部分の持ち手を引っ張り、吸盤力を緩めてディスプレイアセンブリから外します。
    I found it much easier to use a single edge razor blade instead of the pick. After getting that inserted, it was easy to slip the pick between the blade and the case. Disclaimer - Razor blades are very sharp and you could easily hurt yourself or your iPad if you use one.
    donprius - 返信
    This is an amazing tip! After trying for 10 minutes to use the pick with no luck, I grabbed a small razor blade and that worked perfectly to get me started!! Thanks!!
    Ashley Garner - 返信
    The suction cup also didn’t work to create a gap - it cracked the screen when i tried to lift (the screen was already cracked). This was after rotating between the iOpener and a microwavable hot pack for food. The iOpener was around 175 degrees, it brought the surface of the iPad to 130. I was finally able to lift the glass using a razor blade and then the picks like donprius. I continued to use the iOpener to loosen the glue around the rest of the iPad but I think a heat gun would have been more efficient.
    Marc Ducret - 返信
    You have to heat the glue really much, or you will, as i did, crack the glass.
    Linus Grüne - 返信
    Best bet is to mark the pick with a sharpie line on how far your maximum limit is so you don’t damage the LCD.
    Jon Snyder - 返信
    The iOpener works well, be patient and keep reheating until you can see the screen start to give a little. I kept putting mine in the microwave and it worked faster when the iOpener was hotter. 40 second intervals did the trick for me eventually
    Jackson Taylor - 返信
    I spent an hour trying to lift the screen of an iPad Air first gen. The trick I found was that its a combination of lifting the screen a millimetre and then wiggling a razor blade vertically in the slot between the screen and the metal frame (yes its a microscopic slot). I used a hair drier on a section of the edge of the middle of the screen as above. The middle area allows for a bit of flexibility in the rail - we’re talking 0.5mm which is just enough for the razor.
    So hit a section of the screen edge with the drier till its hot to touch, do the suction cap thing as above, insert the blade vertically and wiggle it *ever so slightly* in the slot as you don’t want to break anything. Keep repeating this until you see even the slightest rise in the screen under the cap. At this point, remove the razor and insert the blue pick. It should easily dig in and under the screen, but no further than the black border.
    Remember, small wiggly steps will avoid breaking anything. Better a number of small heat and wiggles than a lift and snap.
    Rusty - 返信
    for those who need to open more than one iPad, the iflex is safer and more effective than a razor blade. i use it to get started then switch to a pick
    iFlex Opening Tool
    Stow - 返信
    Yea, this suction cup cracked my glass. This made it near impossible to slide the picks around. I may try again another day, but I suspect it’s toast at this point.
    Jason Prothero - 返信
    I should have noted the difficulty rating before thinking I could replace the battery myself. I could have saved myself the cost of replacing a cracked screen, which happened when I attempted this step. I did not want to overheat the iOpener but consequently, I could not get a pick inserted underneath the screen. (I think the glue must take a lot more heat than expected to melt.) So just a warning to more novice tinkerers—this repair wasn't the same as fiddling with screwdrivers and a million small parts.
    mlliu - 返信
  13. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 13、 1の画像 1
    • iOpenerを再び温めて、同じ箇所に置きます。
    • 修理作業中、 iOpenerを温めすぎないようにご注意ください。 iOpenerを再度温める際は、少なくとも前の作業から10分ほど待ってから行ってください。
    This says "Always wait at least two minutes before reheating the iOpener", however the iOpener itself has a warning printed upon it that says wait at least 10 minutes. And that 10 minutes warning is also mentioned in Step 2 above.
    Scott - 返信
    Sorry about that! We fixed the text on this step. The two-minute interval was for an older version of the iOpener—the text printed on your iOpener will have the correct interval, which is indeed ten minutes. It can burst if overheated or reheated too quickly.
    Jeff Suovanen -
    It still says 2 Minutes up there in the warning
    Sandro Krumbein - 返信
  14. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 14、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 14、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 14、 3の画像 3
    • 2番目の開口ピックを1番目に差し込んだ開封ピック付近に挿入し、iPadの端に沿って接着剤を剥がしながら下側に動かします。
    You guys really need to show how it's done when your iPad isn't perfect like the one pictured above.. C'mon..
    Scott S - 返信
    This is for BATTERY REPLACEMENT not CRACKED SCREEN REPLACEMENT!!
    Corey Barcus -
    How do you slide the picks when the glass is broken? Even with the glass taped, it pulls away from the tape rather than the housing. I've just further shattered the glass with my attempts.
    chrisweiler - 返信
    With my shattered screen, I was able to remove it using the suction cup slightly and a metal pry, had to break the edge glass some for removal also but it didn’t do damage. More layers of shipping tape helped to make the screen stay together better and come off more intact.
    Jackson Taylor - 返信
  15. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 15、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 15、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 15、 3の画像 3
    • 続けて接着剤を剥がしながら、開口ピックディスプレイの横から下に向かって動かしていきます。
    • 開口ピックが接着剤に絡まり動かなくなった場合は、ピックをiPadの横に沿って"回転させながら"接着剤を剥がしていきます。
    This gives a false illusion to the difficulty of these repairs when you guys make guides using perfect devices. What about devices with dinged corners? A reader is gonna slap on a new screen and shatter it the second they apply pressure thinking it will fit into a dented corner lol
    Scott S - 返信
  16. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 16、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 16、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 16、 3の画像 3
    • 1番最初に差し込んだピックを手に取り、iPadの上部端に向かってスライドして動かします。
    • フロントガラスを通して開口ピックの先端が見えたら、びっくりしないでください。ーピックを少しだけ外側へ引いてください。ほとんどの場合は問題ありませんが、奥まで差し込みすぎないように注意してください。液晶ディスプレイ上に接着剤が付いてしまった場合、取り除くのが難しいためです。
    I managed to get a couple of fingerprints on the LCD.
    What's the best way to clean 'em off?
    What's the safest way?
    Mike McIntosh - 返信
    What I’ve read, and seems to work, is gentle circular pressure with a very clean, dry microfiber cloth. Lacking that, use a TINY drop of water ON THE CLOTH, not on the LCD. Small amounts of alcohol can be used, in my experience, but only if the above don’t work, and with better results if used in small amounts and applied to the cloth, not the LCD.
    Bonnie Baxter - 返信
    Can confirm. Microfiber with a little isopropyl worked great to clean off any adhesive or fingerprints from mine. Thanks for the tip.
    Robert -
    If you dare to use alcohol on your device, at least use isopropyl alcohol, not ethanol!!!
    Pierre-Aurélien - 返信
  17. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 17、 1の画像 1
    • iOpenerを再び温め、iPadの上部端、正面カメラの上に置きます。
    • 修理作業中、iOpenerを温めすぎないようにご注意ください。前の作業から少なくとも10分間置いて温めてください。
    • 形を自由に変化できるiOpenerをお持ちの場合は、上部左端と上部先端を同時に温めるよう曲げてください。
  18. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 18、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 18、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 18、 3の画像 3
    • 開口ピックをiPadの左端上部にスライドさせて接着剤を剥がします。
    I broke the screen glass of my ipad just right when I moved the guitar pick towards the upperleft corner of the screen as depicted in your instructions. (Whereas my ipad screen was in perfect condition : no scratches, not broken at all...). There must be something wrong here. Be advised: move the pick towards the corner with caution !!!
  19. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 19、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 19、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 19、 3の画像 3
    • 開口ピックをiPadの上部端に沿ってスライドさせます。カメラの手前で止めます。
    • 3番目の画像はフロントカメラがiPadのどの位置に内蔵されているかを示したものです。
    • 開口ピックを正面カメラ上にスライドしないでください。レンズ上に接着剤を伸ばしてしまうとカメラにダメージを与えてしまいます。次の手順は正面カメラを傷つけないで作業を進めるためのアドバイスを記しています。
  20. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 20、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 20、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 20、 3の画像 3
    • ピックを少し外側に向かって引き出し、上部端に残っているわずかな先端を正面カメラ上部に沿って動かします。
    At this point I’d use paper tape on the margins of the screen to mask off areas where you should use caution with the pick. Its just a visual reminder not to run the picker too deep in these areas. They are: the camera lens, lower right hand side and where the two antenna are along the base. Step 6 third image highlights these areas.
    Rusty - 返信
  21. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 21、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 21、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 21、 3の画像 3
    • 正面カメラを過ぎた位置でiPadの中に開口ピックの先端を残して作業を止めます。
    • 2番目のピックを取り出して、正面カメラの左側に差し込みます。それからiPadの左端に向かって接着剤を剥がしながらスライドします。
  22. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 22、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 22、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 22、 3の画像 3
    • 先ほどの(1番目の)ピックをiPadの奥まで差し込み、正面カメラの右側から角に向かってスライドします。
  23. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 23、 1の画像 1
    • iPadの角に3本のピックを残したまま、正面パネルの接着剤が再び付着するのを防ぎます。
    • iOpenerを再度温め、iPadの残りのサイド端にーボリュームボタンとロックボタンに沿って、これを置きます。
  24. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 24、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 24、 2の画像 2
    • iPadの上部右端周辺に開口ピックをスライドさせて接着剤を剥がします。
    • このピックを接着剤が再び付着しないよう残し、新しいピックを次の手順で使用します。
  25. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 25、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 25、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 25、 3の画像 3
    • 新しい開口ピックを差し込み、これをiPadの右端の真ん中までスライドさせます。動かしながら接着剤を剥がします。
    • iPadの下部からディスプレイケーブルが装着されています。ここでiPadの下から4.5インチあたりの位置で作業を止めます。
    Why there’s such an obsession with not damaging the cables is beyond me. Be careful, so as not to damage what the cables are connected to. But the cables are part of the replacement digitizer, so if you nick or even slice through them (like I did with the one closest to the bottom) don’t worry about it.
    Blair Miller - 返信
    Keep in mind that some people are here to open an intact display to replace internal components! In those cases, keeping the cables un-harmed is quite important ;)
    Sam Goldheart -
    My digitizer WAS ok and I was only replacing the battery I wasn't careful enough when coming around the side with the pics and got a hold of the cable just enough with the pic to pull it off the underside of the panel. The battery replacement went great other than now I have to replace the digitizer. :(
    BE CAREFUL WITH THIS STEP!!!
    Dylan Bouterse - 返信
    And if you are replacing the digitizer, you have to reuse the fingerprint sensor home button. I sliced through mine and now I’ll not have fingerprint sensor. Each home button is matched to the main board and if switched out you will loose that sensor ability.
    David - 返信
    Like others, I damaged my digitizer cable while doing a battery replacement. It would be a good idea to use some blue tape to mark the spots to avoid during the glue slicing procedure.
    donprius - 返信
    I also damaaged the digitizer cable while doing a battery replacement. Use just the tip of the opening pick.
    Dean Gross - 返信
    People need to realize iFixit routinely duplicates instructions for more than one type of repair/replacement. However, all of the comments are combined, which leads to confusion.
    laura moon - 返信
  26. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 26、 1の画像 1
    • 開口ピックを挟んだままで、iOpener を再び温めてiPadのホームボタン端の上に置きます。
  27. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 27、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 27、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 27、 3の画像 3
    • 左側中央に差し込んでいる開口ピックを左側下部の角に向かって、接着剤を剥がしながらスライドしていきます。
    • 左側下部の角でピックを残したまま止めます。これ以上こじ開けないでください。iPadにピックを挟んだままにします。
    • 3番目の画像はiPadの下部分に装着されている2本のアンテナとホームボタンの様子です。
    • 次の手順ではこれらのコンポーネントにダメージを与えないために、どこからこじ開ければよいのかを教示しています。iOpenerを温めて、指定された場所をこじ開けてください。
  28. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 28、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 28、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 28、 3の画像 3
    • 接着剤が再付着しないように、開口ピックを左側下部の角に挟んだままにします。
    • 新しいピックを手に取り、左側アンテナの上をゆっくりと滑らせます。ホームボタン手前で止めます。
    • iPadの中央に向けて、外側のエッジのみをピックでスライドさせます。中央から外側に向かってピックを戻さないでください。この方向に動かすとアンテナにダメージを与えてしまうことがあります。
    • 開口ピックを2回以上スライドする必要がある場合は、左端外側から中央に向かってピックを再挿入して、作業を継続してください。
    • 次の手順に移る前に、ピックを中央付近で挟んだままにします。
  29. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 29、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 29、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 29、 3の画像 3
    • 再び新しい開口ピックを手に取り、前回の手順で止めたピックの右側に差し込みます。
    • ホームボタンと右側のアンテナ上をスライドさせます。接着剤を剥がすため、ピックの先端のみを使って動かします。
  30. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 30、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 30、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 30、 3の画像 3
    • 接着力が弱くなるため、開口ピックを右側下部の端に挿入します。左側に開口ピックをスライドして、ホームボタンの手前で止めます。
    • 左側のアンテナと同様に、外側の端から中央に向かってスライドします。中央から外側に向けて動かすと、アンテナを傷つけてしまうことがあります。
    This step needs a BIG CAVEAT to not insert the pick far enough to damage the home button/touch ID cable, as it is DIRECTLY above where you’re directing people to insert the pick. I just ruined a ribbon cable by following this guide too closely.
    tabormeister - 返信
    Sadly only after damaging my home button flex cable, I read your comment. There should be a big warning here as it is very easy to tear this cable.
    Bouke - 返信
    I also damaged the home button cable. Check the placement of the cables in steps 37-44.
    Paul Klein - 返信
  31. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 31、 1の画像 1
    • iOpenerを再び温めて、iPadの音量コントロール側の端に沿って配置します。
  32. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 32、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 32、 2の画像 2
    • この手順では特に慎重に作業を進めてください。時間をかけてゆっくりと、接着剤が温かく柔らかくなっているか確認します。開封ピックを使って接着剤全体を剥がします。必要に応じて、作業を止めて iOpenerを再び温めることも考慮してください。
    • 音量コントロールの反対側の両角にはピックを挟んだままにします。ガラスを持ち上げるように、ピックを少しひねります。ディスプレイケーブルの端に沿って留められた接着剤が剥がれます。
    • かなりの接着力が残っている場合は、ピックをそのままの場所に残して iOpenerを再び温め、問題の箇所に当てます。
    You will end up having to scrape the outter ledge to remove the old screen. I bled and got glass shards everywhere. Good luck!
    Travis Dixon - 返信
    That won't happen if you use gloves and protective glasses!
    tanner85 - 返信
  33. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 33、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 33、 2の画像 2
    • ディスプレイケーブルの端に沿って、接着剤をゆっくりと剥がしながら、ディスプレイを上げていきます。
    This is very tricky if the screen is cracked (which I would assume most people are replacing the screen because of a crack). Use duct tape to try and secure the shards as much as possible, but be prepared for shards flying everywhere. Search for videos on cracked screen removal, there’s a good ifixit one. Maybe they can link it here? I finally was able to get it all by using a heat gun and metal spudger/razor like the guy in the video.
    Janie Hughes - 返信
  34. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 34、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 34、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 34、 3の画像 3
    • フロントパネルのガラスを固定したままで、開口ピックを使って最後の接着剤を切り離します。
    • ディスプレイケーブルにダメージを与えたり、切断しないように作業は十分注意しながら行ってください。
    Detailed pictures that better indicate the difference between the remaining adhesive and the two mylar cables (the very cables you are trying to avoid damaging!) would be much appreciated. On my unit the two were VERY hard to distinguish.
    dlcatftwin - 返信
    This step does not need to be performed here. I cut this adhesive once I had removed the lcd and display cables. This makes it much easier to avoid damaging anything. Just prop the glass up on something while you perform steps 31 - 42, then cut remaining adhesive and remove.
    Robert - 返信
    The front camera has a black bezel cover but it is attached to the broken glass digitizer. Peel it off and save it. I plan to tack glue it to the camera instead of gluing it back to the new digitizer glass. It has two alignment bumps so maybe it doesn’t need gluing to either side but I found it on the ground when it came off of the the broken digitizer. I almost tossed it as part of the broken glass.
    Robin - 返信
  35. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 35、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 35、 2の画像 2
    • 全ての接着剤が外れたら、本を開く状態のようにガラスパネルを開いて作業台上で休めましょう。
    • 再装着の間は、ケースに残っている接着剤の残りをガラスクリーナなどイソプロピルアルコールで綺麗に拭き取ってください。(そしてフロントガラスを再利用する際はこれも綺麗に拭き取ります)プレカットされた接着ストリップディスプレイ用接着剤の装着方法を参照して、接着剤を交換します。
    • 再組み立て時に、フロントガラスとiPadのフレームの間にフレックスケーブルを挟み込むのは簡単です。 フレックスケーブルに注意し、ゆっくりと折りたたんでフレームの下に押し込みます。 フレックスケーブルの折り目が平らになる程度に押さえ込まれると、修理が不可能になる程度、損傷してしまう可能性があります。
    my replacement digitizer has rigid flex with adhesive tape where the connectors extend. how does this “fold” back inside the frame?
    David - 返信
    Same here. I removed the adhesive tape, but now what?
    Dvi -
    It looks like I have the same or similar question: the “hinge” part of the digitizer cables (the flap portion) looks like it is supposed to tuck into the crevice between the LCD panel and the side of the aluminum body - my replacement (from iFixit) has sticky contact on the upper side of this flap, making me think that its supposed to adhere to the side of the LCD panel, but the instructions do not make this clear - is my assumption correct?
    dlcatftwin - 返信
    Or, does the flap adhere to the underside of the front panel’s right edge?
    dlcatftwin - 返信
    I attempted to put this protrusion underneath the LCD, and it kept coming up above the LCD. As there were no instructions, I put it as best as I could underneath the LCD as I cannot imagine that it folds up against itself?
    Dvi - 返信
    I tried to put it ‘inside’ the case but was not able to - at the end, I just glued it against the front glass.
    I must have done something wrong with the new home-button assembly as the fingerprint sensor does not work anymore - However, I am not going to go through that repair again so passcode it is.
    Michael Berneis - 返信
    My screen from ifixit had the rigid flaps with adhesive also. I removed adhesive and adhered it to the new glass, it worked fine and solved the problem with the flaps not pushing down.
    Jackson Taylor - 返信
    if there is adhesive glue on the inside of the digitizer and the top of the LCD what do you recommend to clean it.
    scprillwitz - 返信
    Isopropyl alcohol (and certainly not ethanol!!!)
    Pierre-Aurélien -
    Don’t throw away your old screen until you take the home button off of it! My screen was shattered and I kind of have a phobia of broken glass, so I bundled it all up and threw it into the trash can immediately. Next day when I went to continue the job I was sad that my roommate had finally taken out the trash for once and my home button was halfway to the dump by then.
    Sparky - 返信
    Cleaning with isopropyl alcohol is not really working well. I am using it with a qtip. Is there a certain way you recommend in order to actually the adhesive off?
    Brooke Parkhouse - 返信
    Yes, the flap seemed to want to be attached to the glass, not go down the slot. All went together well, except that my home button doesn’t work. I suspect the connections wasn’t right, although I did my best to (gently but firmly) push it in. Too late to do anything about it now.
    Mussollini - 返信
    I got my repair kit yesterday, had a go at it today on my iPad Air 1 (A1474). I’ve opened up phones before (the kind that open up easily), but first time dealing with a glued-together device. Anyway I got there, and now I’m putting things back together. I have a question regarding the pre-cut adhesive to hold the glass back on. Is it meant to be applied to the glass, or the frame?
    SHL - 返信
    Ok never mind - I just looked at the digitizer for this iPad and saw that the adhesive is preapplied to the glass, which confirms my suspicions. Now I can proceed and bring this repair to a conclusion.
    SHL -
    And it’s done! Doing the battery calibration now, but I’m relieved that the battery is working. I did turn on the iPad prior to removing the blue strips on the adhesive to make sure it was working before committing to fix the glass in place.
    To reiterate the point, the adhesive strips go on the glass. The way they are packaged with the clear plastic makes it go very smoothly.
    There are 2 oversize pieces of plastic sandwiching the adhesive sections. These keep the strips in their original shape free of dust off until you are ready to use them. Once you remove these, there is another clear plastic strip which has an inside edge that matches the adhesive section’s inside edge. This plastic allows you to position the adhesive accurately on the glass while keeping your fingers away from it. This is especially important on the right side where the digitizer cables are. Once you remove this clear plastic, there is still the blue film with pull tabs. You can leave these on to do a power up test, then remove them. …cont
    SHL -
    … After doing the power on check, you can also check that all the buttons work, home button, camera, speakers etc. Then I turned it off (probably wasn’t necessary), removed the blue strips and pressed the glass in. For this last step I suggest lining up the left edge of the glass with its corresponding edge in the aluminum shell, and then gently pressing down on the right side. ALSO: while doing this last step, look carefully at the right side for the ribbon cables there. In my case (reusing original digitizer), they were protruding just a smidge, so I used the spudger to just nudge it a bit and they got into place, and then I pressed the right side down. I then pressed down all around the edges of the glass.
    SHL -
    quick question... if this is a replacement, why are we worrying about the digitizer cables? My glass is shattered pretty bad on the to the left of the home button where he says to work. So I can't apply suction cup there. I don't understand the need to be concerned about the cables if the digitizer is going to be trashed...
    Michael M - 返信
    I'd like to add when at this stage and you notice some of the old black adhesive may be hanging off the digitizer DO NOT remove any of it. Wait until you have to thing fully removed. It's way too easy to tear one of the cables if you try removing it now.
    Lindsey W - 返信
    I would clarify a detail for this step...Before turning the screen like a book page, LOOK CAREFULLY at the state of the Home button cable... Despite I turned the screen slowly, the cable resulted cut... Now I will have to order a home button group. Sigh!
    Migraz - 返信
    I would like to clarify a detail of this step. BEFORE turning the screen like a book page, LOOK CAREFULLY at the home button cable... You risk to cut the cable during the turning operation.
    Migraz - 返信
  36. iPad Air Wi-Fiモデルの左側アンテナの交換, LCD: 手順 36、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, LCD: 手順 36、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換, LCD: 手順 36、 3の画像 3
    • 液晶ディスプレイのネジを覆っているテープを全て取り出します。
  37. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 37、 1の画像 1
    • 液晶ディスプレイに留められた次のプラスネジを取り外します。
    • 4.0 mm ネジー3本
    • 4.8 mm ネジー1本
    Use the provided replace screen case's square compartments to place your screws into as you remove them. Really helpful and you likely won't mess up.
    Travis Dixon - 返信
    I tape a stripe of double sided tape on my workbench. You can place the screws on the tape on the location where the screw would be if it was in the screen assembly. In this step, your screws would be in the four corners of the tape stripe, with the longest screw (4,8mm) in the upper left corner. The other screws from the next steps can also be placed on the tape this way.
    Brecht Bocket - 返信
    **I believe you mean the “top Right corner” Is where the longer screw goes.. not left.
    Amanda Felske -
    ! went to Office World bought 4 packs of bluetac stuck them on a sheet of paper to give approximately size and shape of iPad put it in a flat cardboard box
    John Smith - 返信
    Where can I buy these screws please ?
    Anthony Roberts - 返信
  38. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 38、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 38、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 38、 3の画像 3
    • 液晶ディスプレイをを完全に取り外さないでください。幾つかのケーブルがホームボタン上でiPadに繋がっています。正面カメラの端から持ち上げてください。
    • スパッジャーの平面側の先端を使って、液晶ディスプレイを指で掴めるぐらいの高さまで押し上げます。
    • 本のページをめくるように、iPadの液晶ディスプレイをひっくり返ます。カメラ付近から持ち上げて、ホームボタン上を軸にひっくり返します。
    • 液晶ディスプレイケーブルにダメージを与えないように注意しながらディスプレイをひっくり返します。
    • ディスプレイケーブルが作業ができるように、液晶ディスプレイを開いたままにします。
    • 液晶ディスプレイを、柔らかくて防塵機能のついた清潔な表面上に置きます。
    Got a cracked screen from toddler stepping on the iPad. My repair went well, everything worked. Except I scratched the LCD. It seems to scratch easily.
    At this step, be careful when folding over the screen, as it may scratch on the aluminum frame (third picture). When they say “soft lint free surface” that is needed, specifically where the LCD meets the frame. Place a thin cloth like sunglass cleaning cloth over the edge of the frame.
    Cobus de Beer - 返信
    Thank you, very much, for this tip.
    rcrandall85 -
    At this step, possibly depending on date of manufacture, there may be black silicone present on/around the four screws that mount the display. It needs to be carefully scraped away and the two screw mount holes at the top of the screen pried up and away from the chassis. Between the chassis and the plastic portion of the mounting frame, there is a slim sheet of metal. Be sure to pry this off WITH the mounting frame. It is part of it. DO NOT try to separate it.
    rcrandall85 - 返信
  39. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 39、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 39、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 39、 3の画像 3
    この手順で使用する道具:
    Battery Blocker
    $3.99
    • ロジックボードにバッテリーコネクターを留めている2.3 mm プラスネジを1本外します。
    • ショートのリスクを減らすために、バッテリーブロッカーまたは改造した開口ピックを挿入してバッテリーの接続を外せます。
    • バッテリーブロッカーを使って、バッテリーを絶縁する際は、作業にご注意ください。バッテリーコンタクトは簡単に破損してしまい、取り返しのできないダメージをもたらすことがあります。
    • ロジックボードのバッテリーコネクターの下にバッテリーブロッカーを差し込み、作業中、この状態のままにしておきます。
    • ロジックボードの下にバッテリーブロッカーをはめ込むのが難しい場合は、トランプを使って バッテリーを外してみることもできます。
    Not having the isolation pick, I used 2 thin guitar picks instead, which did the job fine.
    goodcyning - 返信
    I couldn't disconnect the battery connector - I applied some force, nothing happened and I was afraid of applying too much force - so I just left it connected and I was very careful not to short out any terminals with metal tools. I completed the repair without any other issues and the iPad now seems to be working fine.
    Peter Gray - 返信
    Mine was missing. Made one with scissors but still didn't do the trick. I just worked with the batteries still plugged in.
    Travis Dixon - 返信
    Couldn’t get the battery terminal disconnected so I continued with repair. I didn’t short anything but now it won’t do anything. It worked before, just a cracked glass to replace. Any solutions?
    Tech-ER - 返信
    Why do you say you didn’t short anything? Your result would seem to suggest otherwise
    John Marx -
    I don’t know if it applies to the iPad Air, but I saw elsewhere in my researches in reference to a iPad mini (or was it an iPod mini?) that disconnecting the LCD and/or digitizer with the battery still connected will blow a “fuse” for the backlight. Might yours still be working, just with no screen illumination whatsoever? Dunno. Just a thought.
    It apparently can be repaired, but is no longer a DIY job.
    Tim -
    try lifting the board and not blocking the connector. If you block the connector there are pins that could be damaged.
    Bryan Cruse - 返信
    A replacement of the battery connector is required if pins are bent should you get power on or charge issue after battery disconnection. This can be replaced with the right tools and low melt solder to remove the connector and replace.
    Best method to disconnect battery is to carefully lift the logic board near the battery connector enough to slip a piece of thin plastic or paper between the batter connector and the logic board battery connector and pins.
    Failing to isolate battery so can result in blown back light or touch filters or diodes in backlight circuit.
    At the very least run down the battery flat prior to repair but you are really best to isolate battery.
    markduff - 返信
    From a repair point of view. This connector is a royal pain. For assembly it's great, well, nearly great.
    This connector is SOLDERED to the motherboard side. Never lever this on the motherboard side, I will call it the right hand side. It will break leaving it's soldered pins behind. Yes I did it.
    The pins, on the battery side of this connector, just rest on the batteries plated pads. They are kept under tension by the screw. It should be noted though that removal of the screw will not disconnect the connector pins from the battery pads. Natural tension is still present.
    I suggest strongly that you take a look at the battery connector online to see the nature of the pins and you will see that some are quite delicate.
    The tools purpose is to raise the battery side of the connector ; the left side, so there is some clearance between the pins and the batteries pads. If you have seen a picture of this connector then you will realise the potential of damage to this connector and will have a better idea of what to do.
    Biskwit2 - 返信
    Contd.
    Lifting the connector and simultaneously sliding a thin piece of card or plastic under the pins should be done carefully. In fact, to minimise damage I just slid it under ONE of the main battery pins, plus or minus, which are in the middle and quite robust compared with the tiddlers on the side of the connector.
    The second point, the battery and the motherboard have protection circuitry. When I broke my connector the battery dropped to 0.5V at the terminals. Connecting the charger, when all the connections were sound and not shorted raised it from the dead back to over 3.2V
    Biskwit2 - 返信
    I replaced the battery, and got things hooked backup. For the test, the screen came on, digitizer seemed to be functioning fine. But I couldn’t get it to charge. I used the i-fixit battery blocker by using my spooger to put a little up pressure on the board, and then sliding the blocker in. I don’t think I damaged the pins, but its possible. This is a friends ipad, and its obviously been dropped a few times. I started eye balling the charging port, it LOOKS ok, but looks can be deceiving. When plugged in, even trying different cables, the ipad is not showing the charging symbol. Some of the comments here seem to imply, if I damaged the battery connection pins, I would still get a charging symbol. My question is, if I damaged those battery connector pins, would the ipad show the charging icon or not? Should I be looking at replacing the charging port?
    Mike Lindsay - 返信
    If you gently use the plastic opening tool as shown in step 94 to lift the board slightly it makes it MUCH easier to slide the battery blocker in.
    Kevin - 返信
  40. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 40、 1の画像 1
    • ディスプレイケーブルのブラケットから 1.4 mmプラスネジを3本取り出します。
    Be careful when re-installing screws on reassembly. I mistakenly put the longer screw from the battery connector in the outboard hole, and wound up twisting off the lug that is only lightly soldered to the metal below. Still have 2 screws and system seems to work fine.
    Brian Anderson - 返信
  41. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 41、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 41、 2の画像 2
    • スパッジャーの平面側先端を使って、ディスプレイケーブルのブラケットをロジックボードからまっすぐ引き上げます。
    • ディスプレイケーブルコネクターはブラケットの底面に接着されています。ブラケット下の奥までスパッジャーを押し込まないでください。コネクターにダメージを与えてしまうことになります。
    bough my digitizer from ebay and have everything done up to this step. The screwdriver the kit came with said to be a #000 but it stripped the screw on the plate... I have tried rubber bands, tape and paper to no avail...anyone got an idea on how to remove the screw. Also I am currently studying in St. Kitts and they lack some products found in the US.
    originalpaintballpanda2 - 返信
    I'm sure you've moved past this by now, but I've had some success with stripped screws using a comparable, if slightly larger flathead screwdriver. The screwdrivers that come in those kits tend to suck quite a lot... iFixit actually has a guide for stripped screws: ネジ山が潰れたネジを取り出す方法
    goodcyning -
    Does anyone know where I could purchase a replacement display cable bracket?
    gwarren - 返信
    Note:Be rly carefule with unplugin homebutton-connection.
    The plug-connection (Homebutton) is not similar to the plug connections the basic-plugs got.
    The homeputton-plug-connection is sensetiv and cant unplug easly.
    IPad - 返信
  42. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 42、 1の画像 1
    • 液晶ディスプレイを取り出します。
    Andddddd continue this iFix folks! It's not a matter of working backwards. Most people must have cracked screens and end up having to rip the screen off and won't have a chance to inspect connections.
    Travis Dixon - 返信
    He is far from complete…..if lcd is being replaced its probably because top screen is busted too. He didn’t show anything about how to remove the cables for that.
    B. A. Computer Services - 返信
    If the battery blocking method is outdated and dangerous, why not show us the new, safer method? Just a thought.
    hdrjunkie - 返信
    There is a separate guide for replacing the outer glass ;)
    Gerald Bowen - 返信
  43. iPad Air Wi-Fiモデルの左側アンテナの交換, フロントパネルアセンブリ: 手順 43、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, フロントパネルアセンブリ: 手順 43、 2の画像 2
    • ホームボタンのリボンケーブルコネクターを覆っているテープを外します。
    I totally skipped steps 39-98 I didn’t see any need to remove all these components and the logic board just to get the battery out. I gently pried up the board where the battery connector goes in, slipped it out, and slipped in the new one.
    Seth Childers - 返信
    That is a great tip. There is plenty of space inside the case to lever out the battery without taking out all of the components. I laid the iPad on top of a large bean bag, heated for 3 minutes in the microwave. After 4-5 minutes, I was able to lever out the battery with the spudger and the credit cards. It came out after a few minutes of careful levering and cramming the credit cards under the battery. I unscrewed the earphone connector and carefully taped it back to the iPad housing with paint tape to have more room to maneuver.
    Jonathan Koehler -
    I second this.
    Just be careful to make sure you don’t squish or tear any wires or anything else surrounding when you’re fighting with the batteries, and it’s still way easier than removing everything else in there first.
    I’ll add one bit, though. The hole in the battery connector that accepts the screw through the logic board also apparently slips over a pin in which the screw seats. I couldn’t see that. So when I got the last bit of battery adhesive to let go, the pin tore out the battery connector hole. Since I was replacing the battery, it wasn’t a problem, but did produce a little conductive piece that I had to fish out before putting anything back together. Wouldn’t want that little torn out piece running around in there to short something out later.
    Also, that pin will locate the battery correctly, so that in one of the last steps of reassembly, the battery connection screws together properly. Make sure you find it before the battery adhesive grabs on to the back of the case.
    Tim -
    Careful removing the tape. The home button has a zif connector and if you aren’t careful the tape can rip the zif flap right off. You might have to hold it down while you pull it off or pull the tape from a different direction to make sure you dont tear the zif tab off.
    Sarah Ybarra - 返信
  44. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 44、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 44、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 44、 3の画像 3
    • スパッジャーの平面側先端を使って、ホームボタンのリボンケーブルZIF コネクター上にあるタブを上向きに引き上げます。
    • ホームボタンのリボンケーブルをZIF コネクターから水平に外します。
    I got through the repair, only to have the new screen give me problems that I can not find solutions to any where. The digitizer is working on its own without my input, it will start apps, switch windows, etc. I have pulled up the new screen and checked my ribbons and cables seem to be fine. ANY IDEAS??
    Moses Roman - 返信
    Moses Roman
    Same exact problem that I have. I think it has something to do with the glass touching the ipad. Something like on the iPad mini, where you had to cover some areas beside the home button.
    I would love to see a real solution, as im stuck with unhappy customers and frustrated me :)
    Bilal Kinali - 返信
    I had mine replaced TWICE by a local repair shop. Soon noticed both times that the iPad would soon go haywire after a few minutes use with random clicks, ghost typing, opening apps, etc.
    The iPad Air's such a poor quality, un-durable product anyway. I only had my screen replaced in the first place because it cracked with no apparent drop or trauma and Apple wouldn't replace.
    daviddesignbristol - 返信
    I have also the same issue, does anyone know what the problem is?
    Please give us some feedback.
    Elektromic - 返信
    Have seen this with multiple repairs where the digitizer was replaced. In each case it was a problem with the digitizer cables where it gets tucked under the glass near the edge of the frame. Not yet sure if they are badly made digitizers or if the cable gets damaged trying to tuck it under frame during installation.
    RayM - 返信
    To avoid the digi sending the ipad crazy. In the same way you tape the copper/silver edges on the back of the glass for the iPad Mini. You tape all the way around, making sure not to dirty the protective cover when placing back down after taping one edge.
    Make sure all the metal surround is cover by tape, but careful not too go over the edges too much. It will be visible when using the device.
    Like i said earlier, the real skill is not too dirty the screen when lifting the protective sheet.
    Have fun!
    Josh - 返信
    Thanks man, I'll give it a try. Any idea what kind of tape should I buy?
    Luis Tamborrell -
    Kapton tape otherwise known as heat tape or polyamide tape
    Neil Davis -
    Just fitted the screen, the digitizer works, display all good but I had a message saying I could not use touch ID and the home button doesn’t work at all…is this expected?
    Paul Kelly - 返信
    I break the ZIF connector. Is tat touch connecter.?
    aiyathurai Aathee - 返信
    How do you take the ribbon cable off from the home button site???
    BP Thompson - 返信
    Pull the ribbon horizontally out, not up
    Rusty - 返信
  45. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 45、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 45、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 45、 3の画像 3
    • スパッジャーの平面側先端を使ったり、指の先を使って、丁寧に2つのデジタイザーケーブルコネクターをソケットからまっすぐ引き上げます。
    • iPadを傷つけないように、コネクターのみ接触してください。ロジックボード上のソケットには触らないでください。
    What are those connectors for because i kinda half broke the left one on the screen on the glass frame and now the lcd wont turn on
    SuperCow_man - 返信
  46. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 46、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 46、 2の画像 2
    • 背面ケースに留められた接着剤からホームボタンのリボンケーブルをゆっくりと丁寧に剥がします。
    THIS PICTURE IS PERFECT AND PERTANANT TO THE NEXT STEP REGARDING “GHOST OR PHANTOM TOUCH” - See that foam around the edges? For some reason, the ifixit replacement digitizer doesn’t come with it (but it does come with new adhesive applied already.) With your screen, also purchase their “tesa tape” : Tesa 61395 Tape / 4 mm - it comes in different widths fyi. I choose 4mm as advised by a staff member.
    scottgogos - 返信
    On the replacement screen I received from you, the home screen ribbon cable does not fully seat inside the Zif connector like the original and will not lock in place as a result. It seems too fat. Any tips to make it work?
    Greg DeCelle - 返信
    I can’t think of any reason for that other than it’s the wrong display for your model, or it’s defective. Double-check the model very carefully and make sure you ordered/received a compatible part. If you ordered from iFixit, contact customer support directly for returns or exchanges. Good luck!
    Jeff Suovanen -
    I didn’t receive any of the two sided tape…I assume it needed to be ordered separately??
    So, when I removed the glass, the bottom cable tore and I have to replace it. The video is not as clear regarding replacement. The old button had a round rubber gasket but the new one does not. No inst. how to re-use it. I can’t attach and keep in place the new button.
    Michael Goss - 返信
    In a previous repair, i broke the zif, what you want to do is hold it down while removing the tape, otherwise it will pull the parts up with it.
    Since it was broke i put a piece of electrical tape on top for the pressure the zif would push down, then another piece from the screw hole to the bend in the cable, so it does not come loose when putting back together.
    Neil Rogers - 返信
  47. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 47、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 47、 2の画像 2
    この手順で使用する道具:
    Polyimide Tape
    $9.99
    • フロントパネルアセンブリを取り外します。
    • 組み立てている間に、きれいな画面を保つためにフロントパネルアセンブリの内側の埃や指紋をふき取ってください。
    • もしも画面をタッチしていないにも関わらず反応してしまう等の不具合が新しい画面で生じるようであれば、カプトン(ポリアミド)テープのような非常に薄い絶縁テープをパネルの裏のオレンジで囲まれた部分に貼ることで解決することが出来ます。iFixitのパネルは適切な絶縁が施された状態で出荷されているため、テープを追加で貼る必要はありません。
    • 適切な絶縁が行われていないと、デジタイザーのこれらの部分が他の部品に触れタッチ入力に不具合を生じる可能性があります。
    • 絶縁テープは裸眼では見ることはできず、多くのiPadで見られる粉塵防止用のものとは異なります。
    In your conclusion, which doesn't have a comments area, you say to reverse the procedure - simple enough, BUT what about the sticky adhesive residue along the edges of the (a) the just-remove-glass (if re-using) and (b) along the 'inside' edges of the iPad chassis? Typically Apple says to remove the adhesive residue (careful) with alcohol wipes (lint free & 98% isopropyl). Thanks for the instructions!
    Joe Kazura - 返信
    the hardest part of this repair for me is actually aligning the ribbons (especially on the aftermarket version) so they don't jumble and cause the glass to mush away from the adhesive leaving a gap. Would would be very helpful to see how to fold the ribbon cables back on the aftermarket digitizers. They are slightly different than the originals, or at least they appear different. This repair is super useful but we could really use a step 44 because re-assembly has a sequence and a folding technique.
    TJ Hellmuth - 返信
    The ribbon cable is a little tricky to figure out. But if you look closely at the old ( Broken) screen you will see they stick to the underside of the screen thin the remaining ribbon slides down into the ipad between the display and ipads frame.
    I used a heat gun and suction cups to loosen screen.
    This was a very good ifix ii
    Rowell - 返信
    Reassemble huh? What about how to move the home button to the new panel?
    xsubguy - 返信
    This is what I need too!
    Sarah Ybarra -
    It is not as simple as reverse disassembly steps, the ribbon cables need to be tucked into the pocket on the side of the iPad. There is tape on them that has to adhere to the side of the digitizer too. Mine did not make it all the way down into the gap, and stuck on the other adhesive, now I have a gap by these two cables. To tuck these into this area is difficult at best. I now need to remove the glass, hoping it does not shatter and purchase more tape.
    Other than this the task was not bad.. BTW: YES People use the capton tape
    Randall Hooper - 返信
    I’ve read that people are putting glue at each corner. I haven’t figured out what glue. One person said Glue Dot 1” 16lb, another said rubber cement, 1 video shows 5 min epoxy… Heard that some sort of glue (not super glue) needs to be used to avoid the glass lifting later on. And to use 3m red tape along the edges. I’ve been searching for which glue because I still have an ipad air to do screen replacement on.
    tsolorio - 返信
    Would be helpful if the tape were listed in the master supplies for the guide. I got the whole kit overnighted, but then had to wait a week to get the tape from Amazon (since I wasn’t going to shell out another $50 for overnight shipping). Otherwise, it’d be nice to know if the displays through iFix it included the foam or not—mine didn’t.
    Micah Sledge - 返信
    Second the concern about the foam. I bought the full repair kit, but was surprised there wasn’t already polyimide tape on the digitizer or in the kit. At least mention that it needs to be purchased extra.
    Ronny Barlow - 返信
    @baron9 The displays we sell have the proper insulation and don’t require any tape. That note is more for folks who use our guides while buying the parts from somewhere else. (They tend to complain here, even though it’s the part that’s at fault, not the guide.) I’ve updated the instructions to try to make things a little more clear. Sorry about that!
    Jeff Suovanen -
    My digitizer kit from ifixit also looks like it is missing the polyimide tape on the digitizer. Can someone confirm that i do not need to get the tape with the original ifixit kit and just slap the digitizer on there?
    Alex -
    what is the difference between the right and left antenna?. My right antenna is damage and cant find a replacement. Can I use only the left one?
    Daniel C - 返信
    I did not realize that aftermarket screens (besides the one ifixit sells) do not come with adhesive strips. Well worth the time to figure out what kind of adhesive you’re going to use to re-adhere the glass before you begin. Stopping while you’re so close to the end of the repair (or having to open the ipad up again after the screen doesn’t stick back down) is slightly frustrating.
    Robert - 返信
    I used a b-7000. 48 h cure time.
    Jean masaoka -
    Thank you for your guide, it helped me fix my son’s iPad!
    Bill - 返信
    Just wanna say thank you. I replaced my LCD and digitizer today…. took a LOT longer to get that adhesive off than I expected. And the IOpener busted in my microwave despite following all directions (eg only 30 sec at a time, out for at least 10 min before reheating. So that sucked. Turns out the rice in a sock worked pretty well too.
    GC Mitts - 返信
    Regarding assembly: even with carefully tucking the ribbon cables down the side while reassembling, it’s still hard to get that area to stick down.
    Gary Wolfe - 返信
    Some advice when reassembling that I have learned in the hard way.
    One good hint is to those who buy replacement parts that are not exactly the original ones. Some of the parts come with a 3M adhesive tape on the tab of the flex cables (I guess original parts are already folded and glued). I would strongly recommend to be very careful when you try to glue it on the front panel and maybe watch a video on how to fold it properly, so as not to fold or pinch the flex cable on an unrepairable way. Also, some of the low cost parts come with a very strong protection sticker on the front glass. It is advisable that you peel off the sticker before reassembling the ipad in order to not end up ruining the glue that was supposed to hold the front panel .
    Jean masaoka - 返信
  48. iPad Air Wi-Fiモデルの左側アンテナの交換, 左側アンテナ: 手順 48、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換, 左側アンテナ: 手順 48、 2の画像 2
    • iPadの端付近にある右側のアンテナケーブルの下にスパッジャーを差し込み、アンテナケーブルコネクターの接続を外すため、上向きに押し出して外します。
    Haven't you switched iPad models from step 43 to step 44? The arrangement of the connectors on the top of the motherboard looks distinctly different. I know that is probably not relevant to removal of the antenna, but it is a bit confusing. I'm not even sure that steps 1 to 43 all use the same model - to be specific, the two digitizer cable connectors are in some cases parallel and identical, and in others they appear parallel but different, and in some it even appears that the identical connectors are perpendicular to each other,, with something else in the position where the upper digitizer cable would connect on the other model…perhaps some pictures are of the Wi-Fi only model and some are the LTE model? But I don't see any SIM connectors on any of the boards…I'm confused.
    Bonnie Baxter - 返信
  49. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 49、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 49、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 49、 3の画像 3
    • 右側アンテナケーブルの周辺は2つの大きなテープで覆われています。
    • 背面ケースからテープを上向きにして剥がします。
  50. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 50、 2の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 50、 2の画像 2
    • iPadの端から一番遠いコネクターの左側アンテナケーブル下にスパッジャーを差し込みます。上向きに押し上げてアンテナケーブルコネクターの接続を外します。
  51. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 51、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 51、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 51、 3の画像 3
    この手順で使用する道具:
    • 背面ケースに留められている左側のアンテナケーブル周辺に巻かれたテープが6箇所あります。
    • ピンセットを使って、アンテナケーブルを伝いながらそれぞれのテープを丁寧に剥がしていきます。
  52. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 52、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 52、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 52、 3の画像 3
    • 内蔵スピーカーに留められたアンテナケーブルに接続しているブラケットがあります。接着剤はアンテナを取り出すためには切断しなければなりません。
    • 開封ピックを内蔵スピーカーとアンテナケーブルブラケットの間に丁寧に差し込みます。
    • 接着剤を切断するため、ピックを右側にスライドします。
    • ブラケットの下に留められたテープを剥がすため、ブラケットをスピーカーから押し出して離します。
  53. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 53、 1の画像 1
    • 次の#000プラスネジを外します。
    • 1.4 mmネジー2本
    • 2.3 mm ネジー1本
  54. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 54、 3の画像 1 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 54、 3の画像 2 iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 54、 3の画像 3
    • アンテナとスピーカーアセンブリの間にスパッジャーの平面側先端を差し込みます。
    • アンテナに留められたフォーム製接着剤を切断するため、ホームボタンの角に向かってスパッジャーをスライドします。
  55. iPad Air Wi-Fiモデルの左側アンテナの交換: 手順 55、 1の画像 1
    • iPadから左側のアンテナを取り出します。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
9 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
6人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
471,711 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,529のガイドは作成済み
2 件のコメント
Great guide, thanks again
Mark - 返信
Beautiful steps. I followed these steps and manages to fix my right antenna.
My only problem now, my iPad keeps going on and off. What could be the issue?
maboke.mahlo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 67
今までの合計 27,437
