メインコンテンツにスキップ
TicWatch E3 Battery Replacement
必要な工具と部品
  1. TicWatch E3 Battery Replacement, Power down your watch: 手順 1、 2の画像 1 TicWatch E3 Battery Replacement, Power down your watch: 手順 1、 2の画像 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. TicWatch E3 Battery Replacement, Loosen the adhesive: 手順 2、 1の画像 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. TicWatch E3 Battery Replacement, Insert an opening pick: 手順 3、 3の画像 1 TicWatch E3 Battery Replacement, Insert an opening pick: 手順 3、 3の画像 2 TicWatch E3 Battery Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
    • Push the opening pick to create a gap between the back cover and the watch frame.
  4. TicWatch E3 Battery Replacement, Pry up the back cover assembly: 手順 4、 3の画像 1 TicWatch E3 Battery Replacement, Pry up the back cover assembly: 手順 4、 3の画像 2 TicWatch E3 Battery Replacement, Pry up the back cover assembly: 手順 4、 3の画像 3
    • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
    • Pry upward to loosen the back cover assembly.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
  5. TicWatch E3 Battery Replacement, Free the back cover assembly: 手順 5、 2の画像 1 TicWatch E3 Battery Replacement, Free the back cover assembly: 手順 5、 2の画像 2
    • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
    • Avoid straining or tearing the sensor or battery cables.
  6. TicWatch E3 Battery Replacement, Open the watch: 手順 6、 2の画像 1 TicWatch E3 Battery Replacement, Open the watch: 手順 6、 2の画像 2
    • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
  7. TicWatch E3 Battery Replacement, Disconnect the battery cable: 手順 7、 2の画像 1 TicWatch E3 Battery Replacement, Disconnect the battery cable: 手順 7、 2の画像 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. TicWatch E3 Battery Replacement, Disconnect the sensor cable: 手順 8、 2の画像 1 TicWatch E3 Battery Replacement, Disconnect the sensor cable: 手順 8、 2の画像 2
    • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
  9. TicWatch E3 Battery Replacement, Remove the back cover assembly: 手順 9、 2の画像 1 TicWatch E3 Battery Replacement, Remove the back cover assembly: 手順 9、 2の画像 2
    • Remove the back cover assembly.
  10. TicWatch E3 Battery Replacement, Loosen the battery adhesive: 手順 10、 1の画像 1
    • Apply a heated iOpener to the back cover for 2 minutes to loosen the adhesive underneath the battery.
  11. TicWatch E3 Battery Replacement, Free the battery cable: 手順 11、 3の画像 1 TicWatch E3 Battery Replacement, Free the battery cable: 手順 11、 3の画像 2 TicWatch E3 Battery Replacement, Free the battery cable: 手順 11、 3の画像 3
    • Reposition the battery and sensor assembly cables by folding the battery cable to the left and then the sensor cable to the right side of the back cover assembly.
    • Do not bend the cables sharply to avoid cable damage.
  12. TicWatch E3 Battery Replacement, Pry up the battery: 手順 12、 2の画像 1 TicWatch E3 Battery Replacement, Pry up the battery: 手順 12、 2の画像 2
    • Insert the flat end of a spudger underneath the bottom edge of the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Pry upwards to loosen the battery.
  13. TicWatch E3 Battery Replacement, Remove the battery: 手順 13、 3の画像 1 TicWatch E3 Battery Replacement, Remove the battery: 手順 13、 3の画像 2 TicWatch E3 Battery Replacement, Remove the battery: 手順 13、 3の画像 3
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
3 の人々がこのガイドを完成させました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
172,783 ポイント
676のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
141 メンバー
17,732のガイドは作成済み
コメント 1 件
Dear Dominik thanks a lot for your useful help. Can you please tell me where I can buy a new battery for the ticwatch E3, internet doesn’t seem to help much. Thanks in advance.
Riccardo Lo Bianco - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 60
今までの合計 385
