メインコンテンツにスキップ
Samsung Galaxy S24 Ultra Rear Cameras Replacement
必要な工具と部品
  1. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Prepare your phone for disassembly: 手順 1、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Prepare your phone for disassembly: 手順 1、 2の画像 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Heat the right edge: 手順 2、 1の画像 1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Insert an opening pick: 手順 3、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Insert an opening pick: 手順 3、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the right adhesive: 手順 4、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the right adhesive: 手順 4、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the right adhesive: 手順 4、 3の画像 3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Heat the bottom edge: 手順 5、 1の画像 1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the bottom adhesive: 手順 6、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the bottom adhesive: 手順 6、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the bottom adhesive: 手順 6、 3の画像 3
    • Insert a second opening pick next to the first one, near the bottom of the right edge.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 7、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 7、 2の画像 2
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Heat the left edge: 手順 8、 1の画像 1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the left adhesive: 手順 9、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the left adhesive: 手順 9、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the left adhesive: 手順 9、 3の画像 3
    • Insert a third opening pick next to the second one, near the left side of the bottom edge.
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 10、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 10、 2の画像 2
    • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
    • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
    • Leave the pick inserted near the power button to prevent the adhesive from resealing.
  11. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Heat the top edge: 手順 11、 1の画像 1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the top adhesive: 手順 12、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the top adhesive: 手順 12、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the top adhesive: 手順 12、 3の画像 3
    • Insert an opening pick in the gap at the top of the right edge.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  13. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 13、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 13、 2の画像 2
    • Slide the pick along the top edge to separate the adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
  14. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the remaining adhesive: 手順 14、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the remaining adhesive: 手順 14、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the remaining adhesive: 手順 14、 3の画像 3
    • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the cameras.
  15. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the back cover: 手順 15、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the back cover: 手順 15、 2の画像 2
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the wireless charging coil: 手順 16、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the wireless charging coil: 手順 16、 2の画像 2
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the wireless charging coil and loudspeaker screws: 手順 17、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the wireless charging coil and loudspeaker screws: 手順 17、 2の画像 2
    • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Four screws securing the wireless charging coil
    • Six screws securing the loudspeaker
  18. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the coil adhesive: 手順 18、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Separate the coil adhesive: 手順 18、 2の画像 2
    • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
  19. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 19、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 19、 2の画像 2
    • Use an opening pick to separate the tab from the frame.
  20. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the wireless charging coil and loudspeaker: 手順 20、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the wireless charging coil and loudspeaker: 手順 20、 2の画像 2
    • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
    • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
    • Pry up to unclip the loudspeaker from the frame.
  21. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 21、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 21、 2の画像 2
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  22. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the battery: 手順 22、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the battery: 手順 22、 2の画像 2
    • Use a spudger to pry up and disconnect the battery press connector.
  23. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the earpiece speaker: 手順 23、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the earpiece speaker: 手順 23、 2の画像 2
    • Use a spudger to pry up and disconnect the earpiece speaker press connector.
  24. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the earpiece speaker screws: 手順 24、 1の画像 1
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
  25. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the earpiece speaker: 手順 25、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the earpiece speaker: 手順 25、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the earpiece speaker: 手順 25、 3の画像 3
    • Insert the pointed end of a spudger under the bottom edge of the earpiece speaker, under the engraved arrow.
    • Pry up with the spudger to unclip the speaker and remove it.
    • During reassembly, insert the top edge of the earpiece speaker into the frame first before pressing down and clipping it back in.
  26. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the interconnect cables: 手順 26、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the interconnect cables: 手順 26、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the interconnect cables: 手順 26、 3の画像 3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the motherboard.
  27. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 27、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 27、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 27、 3の画像 3
    • Use a spudger to pry up and disconnect both interconnect cable press connectors from the daughterboard.
  28. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the interconnect cables: 手順 28、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the interconnect cables: 手順 28、 2の画像 2
    • Grab and remove the interconnect cables from the phone.
  29. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the display cable: 手順 29、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the display cable: 手順 29、 2の画像 2
    • Use a spudger to pry up and disconnect the display cable press connector from the motherboard.
  30. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 30、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 30、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 30、 3の画像 3
    • Use a spudger to pry up and disconnect the display cable press connector from the daughterboard.
    • Remove the display cable.
  31. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the lower antenna: 手順 31、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the lower antenna: 手順 31、 2の画像 2
    • Use a spudger to pry up and disconnect the lower antenna press connector from the motherboard.
  32. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the stylus port: 手順 32、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the stylus port: 手順 32、 2の画像 2
    • Use a spudger to pry up and disconnect the stylus port press connector from the motherboard.
  33. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the upper antenna: 手順 33、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the upper antenna: 手順 33、 2の画像 2
    • Use a spudger to pry up and disconnect the upper antenna press connector from the motherboard.
  34. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the fingerprint scanner: 手順 34、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the fingerprint scanner: 手順 34、 2の画像 2
    • Use a spudger to pry up and disconnect the fingerprint scanner press connector from the motherboard.
  35. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the front camera: 手順 35、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the front camera: 手順 35、 2の画像 2
    • Use a spudger to pry up and disconnect the front camera press connector from the motherboard.
  36. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the motherboard screws: 手順 36、 1の画像 1
    • Use a Phillips screwdriver to remove the two screws securing the motherboard:
    • One 4.0 mm-long screw to the left of the top camera.
    • One 3.5 mm-long screw to the left of the bottom camera.
  37. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the motherboard: 手順 37、 3の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the motherboard: 手順 37、 3の画像 2 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the motherboard: 手順 37、 3の画像 3
    • Use your finger or a spudger to lift the top of the motherboard.
    • Remove the motherboard.
    • Be careful not to catch on any loose cables.
    • During reassembly, be sure all press connectors are above the motherboard when reinserting it.
  38. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the rear cameras: 手順 38、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Disconnect the rear cameras: 手順 38、 2の画像 2
    • Flip over the motherboard to expose the rear camera press connectors.
    • Use a spudger to pry up and disconnect the primary telephoto camera press connector.
  39. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 39、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 39、 2の画像 2
    • Use a spudger to pry up and disconnect the secondary telephoto camera press connector.
  40. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 40、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 40、 2の画像 2
    • Use a spudger to pry up and disconnect the main camera press connector.
  41. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 41、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 41、 2の画像 2
    • Use a spudger to pry up and disconnect the ultrawide camera press connector.
  42. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the rear cameras screw: 手順 42、 1の画像 1
    • Use a Phillips screwdriver to remove the 3.5 mm‑long screw securing the cameras to the camera assembly housing.
  43. Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the cameras: 手順 43、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement, Remove the cameras: 手順 43、 2の画像 2
    • Flip the cameras over so the lenses are facing up.
    • Lift and remove the primary telephoto camera from the camera assembly housing.
  44. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 44、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 44、 2の画像 2
    • Lift and remove the secondary telephoto camera from the camera assembly housing.
    • This camera is secured by a small amount of adhesive around its alignment pin.
  45. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 45、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 45、 2の画像 2
    • Insert the flat end of a spudger between the bottom of the ultrawide camera and the metal camera assembly housing.
    • Make sure the spudger is between the cable and metal camera assembly housing, not between the cable and the camera itself.
    • Pry the camera free of the adhesive holding it in the camera assembly housing.
  46. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 46、 2の画像 1 Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 46、 2の画像 2
    • Remove the ultrawide camera from the camera assembly housing.
  47. Samsung Galaxy S24 Ultra Rear Cameras Replacement: 手順 47、 1の画像 1
    • You're now left with the rear cameras for replacement.
終わりに
ある他の人がこのガイドを完成しました。
Spencer Pennington
メンバー登録日: 09/09/23
17,094 ポイント
113のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,526のガイドは作成済み
コメント 1 件
I'm still waiting for you guys to sell the oem main camera sensor 🥲
Angel Landis Mercedes - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 68
過去 30 日: 283
今までの合計 1,500
