メインコンテンツにスキップ
Samsung Galaxy Note10+ 5G Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Note10+ 5G Battery Replacement, Heat the rear cover: 手順 1、 1の画像 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy Note10+ 5G Battery Replacement, Insert an opening pick: 手順 2、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Insert an opening pick: 手順 2、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Samsung Galaxy Note10+ 5G Battery Replacement, Begin to slice the adhesive: 手順 3、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Begin to slice the adhesive: 手順 3、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Begin to slice the adhesive: 手順 3、 3の画像 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Samsung Galaxy Note10+ 5G Battery Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Slice around the perimeter of the phone: 手順 4、 3の画像 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Samsung Galaxy Note10+ 5G Battery Replacement, Lift off the rear cover: 手順 5、 2の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Lift off the rear cover: 手順 5、 2の画像 2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
  6. Samsung Galaxy Note10+ 5G Battery Replacement, Lift up the metal cover: 手順 6、 1の画像 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  7. Samsung Galaxy Note10+ 5G Battery Replacement: 手順 7、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement: 手順 7、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement: 手順 7、 3の画像 3
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  8. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the battery: 手順 8、 2の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the battery: 手順 8、 2の画像 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  9. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the wireless charging coil: 手順 9、 2の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the wireless charging coil: 手順 9、 2の画像 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  10. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the wireless charging coil: 手順 10、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the wireless charging coil: 手順 10、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the wireless charging coil: 手順 10、 3の画像 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
  11. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker screws: 手順 11、 1の画像 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
  12. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker: 手順 12、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker: 手順 12、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the loudspeaker: 手順 12、 3の画像 3
    • Use a pair of tweezers to remove the loudspeaker.
  13. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the interconnect cables: 手順 13、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the interconnect cables: 手順 13、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the interconnect cables: 手順 13、 3の画像 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
  14. Samsung Galaxy Note10+ 5G Battery Replacement: 手順 14、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement: 手順 14、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement: 手順 14、 3の画像 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
  15. Samsung Galaxy Note10+ 5G Battery Replacement: 手順 15、 1の画像 1
    • Remove the main interconnect cable.
  16. Samsung Galaxy Note10+ 5G Battery Replacement: 手順 16、 2の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement: 手順 16、 2の画像 2
    • Don't try to remove the secondary interconnect cable. The cable is connected to the side 5G mmWave antenna.
    • Use a spudger or your fingers to gently fold the secondary interconnect cable away from the battery.
  17. Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the display cable: 手順 17、 2の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Disconnect the display cable: 手順 17、 2の画像 2
    • Use the pointed end of a spudger to disconnect the display cable connector from the motherboard.
  18. Samsung Galaxy Note10+ 5G Battery Replacement, Loosen the battery adhesive: 手順 18、 2の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Loosen the battery adhesive: 手順 18、 2の画像 2
    • Apply a few drops of high concentration (90% or greater) isopropyl alcohol underneath the battery at the tear-shaped indents near the corners of the battery well.
    • Wait for a minute for the isopropyl alcohol to penetrate and weaken the battery adhesive before you proceed to the next step.
  19. Samsung Galaxy Note10+ 5G Battery Replacement, Remove the battery: 手順 19、 3の画像 1 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the battery: 手順 19、 3の画像 2 Samsung Galaxy Note10+ 5G Battery Replacement, Remove the battery: 手順 19、 3の画像 3
    • Apply a suction cup to the back of the battery.
    • Pull up on the suction cup with strong, steady force to begin to separate the battery from the frame.
    • If this is difficult, apply a few more drops of isopropyl alcohol underneath the battery, let it sit for two minutes, and try again.
    • Insert the point of an opening pick into the gap created between the battery and frame.
    • Don't insert the opening pick more than halfway or you risk damaging the fingerprint sensor underneath.
    • Pull up on the suction cup to remove the battery.
    • The battery will come out without much force once the isopropyl alcohol has adequately penetrated the battery adhesive.
    • When you're reassembling your phone, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
2 の人々がこのガイドを完成させました。
Arthur Shi
メンバー登録日: 01/03/18
252,821 ポイント
526のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 185
今までの合計 4,539
