メインコンテンツにスキップ
Patching a Bicycle Tire Inner Tube
Brett Hartt
Brett Hartt とその他 5 人の作成者
最終更新日: June 4, 2019
見積もりなし
中レベル
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
  • Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
  • When applying the rubber cement to the hole the thinner the layer the better, for faster drying.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Patching a Bicycle Tire Inner Tube, Inner Tube: 手順 1、 1の画像 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  2. Patching a Bicycle Tire Inner Tube: 手順 2、 2の画像 1 Patching a Bicycle Tire Inner Tube: 手順 2、 2の画像 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  3. Patching a Bicycle Tire Inner Tube: 手順 3、 1の画像 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  4. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 手順 4、 2の画像 1 Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 手順 4、 2の画像 2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  5. Patching a Bicycle Tire Inner Tube: 手順 5、 1の画像 1
    • Mark the hole with a marker, and completely deflate the tire.
  6. Patching a Bicycle Tire Inner Tube: 手順 6、 1の画像 1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  7. Patching a Bicycle Tire Inner Tube: 手順 7、 1の画像 1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  8. Patching a Bicycle Tire Inner Tube: 手順 8、 1の画像 1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  9. Patching a Bicycle Tire Inner Tube: 手順 9、 1の画像 1
    • Apply the patch to the area.
  10. Patching a Bicycle Tire Inner Tube: 手順 10、 1の画像 1
    • Apply pressure to the patch until the rubber cement is dry.
終わりに
To reassemble your bike, follow these directions from step 6
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Brett Hartt
メンバー登録日: 04/12/10
129,827 ポイント
143のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,465のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,922
