メインコンテンツにスキップ
Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
Jasmin
Jasmin とその他 人の作成者
最終更新日: January 9, 2020
20 秒
とても簡単
The removal of the battery is one of the easiest tasks on the Packard Bell EasyNote TJ65-CU-030GE. It is strongly recommended to remove the battery before conducting repairs on the laptop. No tools are needed.
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 手順 1、 2の画像 1 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: 手順 1、 2の画像 2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 手順 2、 3の画像 1 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 手順 2、 3の画像 2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: 手順 2、 3の画像 3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jasmin
メンバー登録日: 02/17/16
407 ポイント
1ガイドが承認済み
チーム
iFixit EU Team iFixit EU Team人のメンバー
Staff
39 メンバー
1,138のガイドは作成済み
4 件のコメント
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - 返信
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - 返信
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
I’m trying to switch on my pc but it says diagnosing pc then it goes on and say attempting repairs I don’t know what to do
Anelisiwe - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 24
過去 30 日: 102
今までの合計 8,098
