はじめに
Use this guide to replace the battery in your OnePlus 9 5G.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
It isn't mandatory to remove the daughterboard cover and the interconnect cable in order to replace the battery. However, doing so reduces the risk of damaging surrounding components. If you're experienced in repairs and decide not to do so, deal with the interconnect cable like with the charging port cable in step 25 of this guide.
You'll need replacement adhesive for the battery and the rear glass in order to complete this repair.
Note: Retaining water resistance after the repair depends on how clean the mating surfaces are and how accurately the adhesive is reapplied. Your device will lose its factory-given IP (Ingress Protection) rating, however, only the T-Mobile versions of the OnePlus 9 5G offer an IP rating.
必要な工具と部品
Prepare an iOpener and apply it to the rear glass for at least three minutes to loosen the adhesive underneath.
Apply a suction handle to the rear glass, as close to the bottom edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick underneath the bottom edge of the rear glass.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick underneath the bottom left corner of the rear glass.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the top left corner of the rear glass.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth and final opening pick underneath the top right corner of the rear glass.
Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
Carefully slide an opening pick underneath the bottom edge of the flash assembly.
Use your opening pick to pry up the flash assembly.
Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
Insert a spudger underneath the bottom right edge of the motherboard cover.
Pry upwards to loosen the motherboard cover and create a gap.
Use a pair of tweezers or your fingers to remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
Use a Phillips screwdriver to remove the five 3.8 mm-long screws securing the daugtherboard cover.
Insert the point of a spudger underneath the top right edge of the daughterboard cover.
Pry upwards to loosen the daughterboard cover.
Use a spudger to disconnect the interconnect cable from the motherboard by prying the connector straight up from its socket.
Slide one arm of a pair of tweezers underneath the metal bracket covering the interconnect cable.
Use your tweezers to lift and unhinge the metal bracket.
Remove the metal bracket.
Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
Use a pair of tweezers or your fingers to remove the interconnect cable.
Use a spudger to disconnect the charging port cable by prying the connector straight up from its socket on the bottom edge of the motherboard.
Grab and lift the right pull tab to remove the right side of the battery from its recess.
Use a pair of blunt nose tweezers to peel the left pull tab off of the battery until you can grip it with your fingers.
Grab and lift the left pull tab to remove the left side of the battery from its recess.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our OnePlus 9 5G answers community for help.
6 の人々がこのガイドを完成させました。
5 件のコメント
The produce you sale, OnePlus 9 5G Battery - BLP829, have the cable upside down. It's shown on your picture. The smooth side show face up, but it faces down. There is no way to install it! I'm looking to return the battery.
Jijun Wang - 返信
I had the same issue, and additionally, the BPL829 is a few mm to tall to fit in the LE2115, even though the description says it is compatible. I got to the point I was ready to put the new battery in, and noticed the connector was facing the wrong way. I tried to fit it in anyway to see if I could make it work, and the new battery won't even fit in the slot. Very disappointed.
I had this same problem and asked about it in the forum. Top suggestion was to use the Oppo BLP821. I ordered one off the least-sketchy looking ebay seller for it, and it fits and functions perfectly. I am guessing the reason the T-Mobile variant is different, is because it's IP rated.
Zed -
Just installed mine with the Oppo BLP821 battery - the cable was maybe 2mm further across than the OEM battery but there was enough slack in the cable to move it.
Just FYI, I did not need to remove the daughterboard or cables - the two cables which run over the battery could easily be bent out of the way. This simplifies the process and makes it significantly quicker.
Thank you for the Description.
Ive installed the battery BLP827. The installtion was easy, some cables or screws were at a different place. The hardest part was to open the backplate. The glue was so strong that it it broke even though I was very patient and equally heated the phone.
I took a cutter knive to make the start of the opening.
