メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 8 Daughterboard Replacement
必要な工具と部品
  1. OnePlus 8 Daughterboard Replacement, Heat the rear glass: 手順 1、 1の画像 1
    • Power off your phone and unplug any cables.
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and internal battery, so proceed with care.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus 8 Daughterboard Replacement, Insert an opening pick: 手順 2、 3の画像 1 OnePlus 8 Daughterboard Replacement, Insert an opening pick: 手順 2、 3の画像 2 OnePlus 8 Daughterboard Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    • Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
    • Insert an opening pick into the gap.
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: 手順 3、 3の画像 1 OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: 手順 3、 3の画像 2 OnePlus 8 Daughterboard Replacement, Slice the bottom edge adhesive: 手順 3、 3の画像 3
    • Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus 8 Daughterboard Replacement: 手順 4、 3の画像 1 OnePlus 8 Daughterboard Replacement: 手順 4、 3の画像 2 OnePlus 8 Daughterboard Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick under the bottom edge of the rear glass, into the gap you just created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: 手順 5、 3の画像 1 OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: 手順 5、 3の画像 2 OnePlus 8 Daughterboard Replacement, Slice the left edge adhesive: 手順 5、 3の画像 3
    • If you have trouble slicing, reheat the iOpener and apply it to the edge for two minutes to soften the adhesive.
    • Insert a third opening pick under the bottom left corner of the rear glass.
    • Slide the opening pick up the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  6. OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: 手順 6、 3の画像 1 OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: 手順 6、 3の画像 2 OnePlus 8 Daughterboard Replacement, Slice the top edge adhesive: 手順 6、 3の画像 3
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  7. OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: 手順 7、 3の画像 1 OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: 手順 7、 3の画像 2 OnePlus 8 Daughterboard Replacement, Slice the right edge adhesive: 手順 7、 3の画像 3
    • Insert a fifth opening pick under the top right corner of the rear glass.
    • Slide the opening pick down the right edge to slice the remaining adhesive.
    FixBotに聞いてみる
    コメントを追加
  8. OnePlus 8 Daughterboard Replacement, Remove the rear glass: 手順 8、 3の画像 1 OnePlus 8 Daughterboard Replacement, Remove the rear glass: 手順 8、 3の画像 2 OnePlus 8 Daughterboard Replacement, Remove the rear glass: 手順 8、 3の画像 3
    • Remove the rear glass.
    • If the rear glass still feels stuck to the frame, slide an opening pick around the entire perimeter until the rear glass separates completely.
    • During reassembly:
    • Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    FixBotに聞いてみる
    コメントを追加
  9. OnePlus 8 Daughterboard Replacement, Unfasten the motherboard cover: 手順 9、 1の画像 1
    この手順で使用する道具:
    • A white sticker may cover a screw on the right edge of the motherboard cover. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  10. OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: 手順 10、 3の画像 1 OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: 手順 10、 3の画像 2 OnePlus 8 Daughterboard Replacement, Pry up the motherboard cover: 手順 10、 3の画像 3
    • The motherboard cover is secured by tight clips.
    • Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
    • Twist the spudger to release the clips.
    • Lever the motherboard cover up until you can grip it with your fingers.
    FixBotに聞いてみる
    コメントを追加
  11. OnePlus 8 Daughterboard Replacement, Remove the motherboard cover: 手順 11、 2の画像 1 OnePlus 8 Daughterboard Replacement, Remove the motherboard cover: 手順 11、 2の画像 2
    • Remove the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  12. OnePlus 8 Daughterboard Replacement, Disconnect the battery cable: 手順 12、 2の画像 1 OnePlus 8 Daughterboard Replacement, Disconnect the battery cable: 手順 12、 2の画像 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    FixBotに聞いてみる
    コメントを追加
  13. OnePlus 8 Daughterboard Replacement, Unfasten the loudspeaker: 手順 13、 1の画像 1
    この手順で使用する道具:
    • A white sticker may coversa screw on the top right corner of the loudspeaker. Pierce through it with the tip of your screwdriver or use tweezers to remove it.
    • Use a Phillips driver to remove the seven 3.3 mm-long screws securing the loudspeaker.
    FixBotに聞いてみる
    コメントを追加
  14. OnePlus 8 Daughterboard Replacement, Pry up the loudspeaker: 手順 14、 2の画像 1 OnePlus 8 Daughterboard Replacement, Pry up the loudspeaker: 手順 14、 2の画像 2
    • The loudspeaker is secured with plastic clips.
    • Insert an opening pick underneath the center of the loudspeaker's top edge.
    • Pry up to release the clips securing the loudspeaker, levering it up until you can grip it with your fingers.
    FixBotに聞いてみる
    コメントを追加
  15. OnePlus 8 Daughterboard Replacement, Remove the loudspeaker: 手順 15、 2の画像 1 OnePlus 8 Daughterboard Replacement, Remove the loudspeaker: 手順 15、 2の画像 2
    • Remove the loudspeaker.
    FixBotに聞いてみる
    コメントを追加
  16. OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: 手順 16、 3の画像 1 OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: 手順 16、 3の画像 2 OnePlus 8 Daughterboard Replacement, Eject the SIM card tray: 手順 16、 3の画像 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press firmly to eject the tray.
    FixBotに聞いてみる
    コメントを追加
  17. OnePlus 8 Daughterboard Replacement, Remove the SIM card tray: 手順 17、 2の画像 1 OnePlus 8 Daughterboard Replacement, Remove the SIM card tray: 手順 17、 2の画像 2
    • Remove the SIM card tray from the phone.
    • A thin rubber gasket provides water and dust protection. If this gasket is damaged or missing, replace the gasket (or the entire tray) to maintain water resistance and protect your phone's internal components.
    • When inserting a SIM card into the tray, make sure it's oriented properly within the tray before reinserting the tray into the phone.
    FixBotに聞いてみる
    コメントを追加
  18. OnePlus 8 Daughterboard Replacement, Disconnect the antenna board cable: 手順 18、 2の画像 1 OnePlus 8 Daughterboard Replacement, Disconnect the antenna board cable: 手順 18、 2の画像 2
    • Use a spudger to disconnect the antenna board cable from the daughterboard by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  19. OnePlus 8 Daughterboard Replacement, Disconnect the fingerprint reader cable: 手順 19、 2の画像 1 OnePlus 8 Daughterboard Replacement, Disconnect the fingerprint reader cable: 手順 19、 2の画像 2
    • Use a spudger to disconnect the fingerprint reader cable from the daughterboard by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  20. OnePlus 8 Daughterboard Replacement, Disconnect the interconnect cable: 手順 20、 2の画像 1 OnePlus 8 Daughterboard Replacement, Disconnect the interconnect cable: 手順 20、 2の画像 2
    • Use a spudger to disconnect the interconnect cable from the daughterboard by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  21. OnePlus 8 Daughterboard Replacement, Disconnect the black antenna cable: 手順 21、 2の画像 1 OnePlus 8 Daughterboard Replacement, Disconnect the black antenna cable: 手順 21、 2の画像 2
    • Use the pointed end of a spudger to disconnect the black antenna cable by prying the connector straight up from its socket on the motherboard.
    • Pry only on the metal heads of the connectors. Avoid prying on the cables themselves.
    • To reconnect antenna cables, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
    FixBotに聞いてみる
    コメントを追加
  22. OnePlus 8 Daughterboard Replacement, Unclip the black antenna cable: 手順 22、 2の画像 1 OnePlus 8 Daughterboard Replacement, Unclip the black antenna cable: 手順 22、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers or your fingers to lift the black antenna cable out of its clip on the daughterboard.
    FixBotに聞いてみる
    コメントを追加
  23. OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: 手順 23、 3の画像 1 OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: 手順 23、 3の画像 2 OnePlus 8 Daughterboard Replacement, Disconnect and unclip the white antenna cable: 手順 23、 3の画像 3
    • Use the pointed end of a spudger to disconnect the white antenna cable by prying the connector straight up from its socket on the motherboard.
    • Use a pair of tweezers or your fingers to lift the white antenna cable out of its clip on the daughterboard.
    • During reassembly, make sure the antenna cables are pushed into their channels on the right edge of the phone before pressing them into their respective clips.
    FixBotに聞いてみる
    コメントを追加
  24. OnePlus 8 Daughterboard Replacement, Unfasten the daughterboard: 手順 24、 1の画像 1
    • Use a Phillips driver to remove the single 3.3 mm-long screw securing the daughterboard.
    FixBotに聞いてみる
    コメントを追加
  25. OnePlus 8 Daughterboard Replacement, Pry up the daughterboard: 手順 25、 2の画像 1 OnePlus 8 Daughterboard Replacement, Pry up the daughterboard: 手順 25、 2の画像 2
    • Insert the point of a spudger under the top right corner of the daughterboard.
    • Pry up the daughterboard.
    FixBotに聞いてみる
    コメントを追加
  26. OnePlus 8 Daughterboard Replacement, Remove the daughterboard: 手順 26、 3の画像 1 OnePlus 8 Daughterboard Replacement, Remove the daughterboard: 手順 26、 3の画像 2 OnePlus 8 Daughterboard Replacement, Remove the daughterboard: 手順 26、 3の画像 3
    • Use a pair of tweezers or your fingers to remove the daughterboard.
    • Before reinstalling the daughterboard, make sure all cables that connect to it are out of the way.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Manuel Haeussermann
メンバー登録日: 07/13/22
25,958 ポイント
71のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
30,155のガイドは作成済み
1件のガイドコメント
I have conducted small Board match main board and it shows " Board A" match failed. What is board A?
Kaushal Kharolia - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 44
今までの合計 1,617
