メインコンテンツにスキップ
Nintendo 3DS Back Cover Replacement
David Hodson
David Hodson とその他 10 人の作成者
最終更新日: March 17, 2025
5分
簡単
Removing the back cover to access the battery and internals of the Nintendo 3DS.
必要な工具と部品
ツール
  1. Nintendo 3DS Back Cover Replacement, Loosen the rear screws: 手順 1、 1の画像 1
    この手順で使用する道具:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Back Cover Replacement, Remove the rear cover: 手順 2、 2の画像 1 Nintendo 3DS Back Cover Replacement, Remove the rear cover: 手順 2、 2の画像 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
終わりに
19 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
152,712 ポイント
127のガイドは作成済み
2 件のコメント
Anybody know where to buy replacement back covers for this original 3DS model? I’m finding that a lot of used 3DS’s from this era have 3rd party battery packs and the original cover is lost.
CORED3SIGN - 返信
コメントを追加
統計データ:
過去 24時間: 27
過去 7 日: 165
過去 30 日: 518
今までの合計 30,204
