メインコンテンツにスキップ
Motorola Moto G Play (2021) Screen Replacement
必要な工具と部品
  1. Motorola Moto G Play (2021) Screen Replacement, Remove the SIM card tray: 手順 1、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the SIM card tray: 手順 1、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the SIM card tray: 手順 1、 3の画像 3
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
    • The SIM card may fall out.
    • Grab and remove the SIM card tray from the phone.
    • Reinsert the SIM card tray with the SIM card recess facing the screen.
  2. Motorola Moto G Play (2021) Screen Replacement, Heat the left edge: 手順 2、 1の画像 1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the left edge of the cover for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Moto G Play (2021) Screen Replacement, Insert an opening pick: 手順 3、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Insert an opening pick: 手順 3、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction cup to the back cover, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  4. Motorola Moto G Play (2021) Screen Replacement, Slice the right adhesive: 手順 4、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Slice the right adhesive: 手順 4、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Slice the right adhesive: 手順 4、 3の画像 3
    • Slide your opening pick back and forth along the left edge to slice through the adhesive.
    • Leave the pick in at the bottom left corner to prevent the adhesive from resealing.
  5. Motorola Moto G Play (2021) Screen Replacement, Slice the bottom adhesive: 手順 5、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Slice the bottom adhesive: 手順 5、 2の画像 2
    • Insert and slide a second opening pick to the bottom right corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
    • Repeat this process for the right and top edges of the cover.
  6. Motorola Moto G Play (2021) Screen Replacement, Dislodge the fingerprint reader: 手順 6、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Dislodge the fingerprint reader: 手順 6、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Dislodge the fingerprint reader: 手順 6、 3の画像 3
    • The fingerprint reader is connected to the motherboard by a fragile cable. You must free it before pulling the cover off.
    • Grab and lift the bottom edge of the cover.
    • As you lift the back cover, press and unstick the fingerprint reader from it.
  7. Motorola Moto G Play (2021) Screen Replacement, Remove the back cover: 手順 7、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the back cover: 手順 7、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Grab and remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  8. Motorola Moto G Play (2021) Screen Replacement, Reposition the fingerprint reader: 手順 8、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Reposition the fingerprint reader: 手順 8、 2の画像 2
    • Flip the fingerprint reader to the left, away from the phone.
    • Don't fold or sharply bend the ribbon cable.
  9. Motorola Moto G Play (2021) Screen Replacement, Unfasten the motherboard cover: 手順 9、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Unfasten the motherboard cover: 手順 9、 2の画像 2
    • Use your Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the motherboard cover.
  10. Motorola Moto G Play (2021) Screen Replacement, Pry the motherboard cover: 手順 10、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Pry the motherboard cover: 手順 10、 2の画像 2
    • Insert the pointed end of a spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry the cover upward until you can grab it with your fingers.
  11. Motorola Moto G Play (2021) Screen Replacement, Remove the motherboard cover: 手順 11、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the motherboard cover: 手順 11、 2の画像 2
    • Grab the bottom edge of the motherboard cover and remove it from the frame.
  12. Motorola Moto G Play (2021) Screen Replacement, Disconnect the battery: 手順 12、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the battery: 手順 12、 2の画像 2
    • Use the pointed end of your spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  13. Motorola Moto G Play (2021) Screen Replacement, Disconnect the fingerprint reader: 手順 13、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the fingerprint reader: 手順 13、 2の画像 2
    • Use the pointed end of your spudger to pry and disconnect the fingerprint reader's press connector.
    • The gold arrow indicates the direction to pry from.
  14. Motorola Moto G Play (2021) Screen Replacement, Remove the fingerprint reader: 手順 14、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the fingerprint reader: 手順 14、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use your fingers or tweezers to remove the fingerprint reader.
    • Be careful while handling the fragile ribbon cable.
  15. Motorola Moto G Play (2021) Screen Replacement, Disconnect the antenna cables: 手順 15、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the antenna cables: 手順 15、 2の画像 2
    • Use the pointed end of your spudger to pry and disconnect the gray antenna cable.
    • Pry on the metal head of the connector only. Avoid lifting the cable itself as much as possible.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  16. Motorola Moto G Play (2021) Screen Replacement: 手順 16、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement: 手順 16、 2の画像 2
    • Repeat the previous step for the black antenna cable.
  17. Motorola Moto G Play (2021) Screen Replacement, Disconnect the board cable: 手順 17、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the board cable: 手順 17、 2の画像 2
    • Use the pointed end of your spudger to pry and disconnect the board cable's press connector.
  18. Motorola Moto G Play (2021) Screen Replacement, Disconnect the display: 手順 18、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the display: 手順 18、 2の画像 2
    • Use the pointed end of your spudger to pry and disconnect the display's press connector.
  19. Motorola Moto G Play (2021) Screen Replacement, Unfasten the motherboard: 手順 19、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Unfasten the motherboard: 手順 19、 2の画像 2
    • Use your Phillips screwdriver to remove the two 2.5 mm-long screws securing the motherboard.
  20. Motorola Moto G Play (2021) Screen Replacement, Lift the motherboard: 手順 20、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Lift the motherboard: 手順 20、 2の画像 2
    • Insert the pointed end of your spudger between the bottom left edge of the motherboard and the frame.
    • Lift the motherboard from its recess.
    • Be sure the loose cables don't catch on the motherboard as it's removed.
  21. Motorola Moto G Play (2021) Screen Replacement, Remove the motherboard: 手順 21、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the motherboard: 手順 21、 2の画像 2
    • Grab the motherboard by its bottom corners and remove it.
    • During reassembly, make sure no cables or connectors become trapped underneath the motherboard.
  22. Motorola Moto G Play (2021) Screen Replacement, Clean the thermal paste: 手順 22、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Clean the thermal paste: 手順 22、 2の画像 2
    • Follow this guide to remove excess thermal paste and prepare the frame and motherboard for reassembly.
  23. Motorola Moto G Play (2021) Screen Replacement, Unfasten the loudspeaker: 手順 23、 1の画像 1
    • Use your Phillips screwdriver to remove the eight 3.8 mm-long screws securing the loudspeaker.
  24. Motorola Moto G Play (2021) Screen Replacement, Pry the loudspeaker: 手順 24、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Pry the loudspeaker: 手順 24、 2の画像 2
    • Insert your spudger between the top right corner of the loudspeaker and the frame.
    • Pry up to release the loudspeaker.
  25. Motorola Moto G Play (2021) Screen Replacement, Remove the loudspeaker: 手順 25、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the loudspeaker: 手順 25、 2の画像 2
    • Grab the loudspeaker with your fingers and remove it.
  26. Motorola Moto G Play (2021) Screen Replacement, Disconnect the board cable: 手順 26、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the board cable: 手順 26、 2の画像 2
  27. Motorola Moto G Play (2021) Screen Replacement, Disconnect the antenna cables: 手順 27、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Disconnect the antenna cables: 手順 27、 2の画像 2
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • Free the cable from the retaining clip.
    • During reassembly, be sure to secure the cable to the clip in the daughterboard.
  28. Motorola Moto G Play (2021) Screen Replacement: 手順 28、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement: 手順 28、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement: 手順 28、 3の画像 3
  29. Motorola Moto G Play (2021) Screen Replacement, Unfasten the daughterboard: 手順 29、 1の画像 1
    • Use your Phillips screwdriver to remove the 2.5 mm-long screw securing the daughterboard.
  30. Motorola Moto G Play (2021) Screen Replacement, Reposition the antenna cables: 手順 30、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Reposition the antenna cables: 手順 30、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Reposition the antenna cables: 手順 30、 3の画像 3
    • Move the black and gray antenna cables away from the daughterboard.
  31. Motorola Moto G Play (2021) Screen Replacement, Remove the daughterboard: 手順 31、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the daughterboard: 手順 31、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the daughterboard: 手順 31、 3の画像 3
    • Grip the top edge of the daughterboard.
    • Lift and remove the daughterboard from its recess.
    • Be sure not to catch on any loose cables.
  32. Motorola Moto G Play (2021) Screen Replacement, Soften the adhesive: 手順 32、 1の画像 1
    • Apply highly-concentrated isopropyl alcohol (over 90%) to the vibration motor's flex cable.
    • Alternatively, use a heated iOpener, hair dryer, or heat gun to soften the adhesive.
    • Use caution to not overheat the battery or surrounding components.
  33. Motorola Moto G Play (2021) Screen Replacement, Reposition the vibration motor: 手順 33、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Reposition the vibration motor: 手順 33、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Reposition the vibration motor: 手順 33、 3の画像 3
    • Insert the point of your spudger between the motor counterweight and the frame.
    • Pry the motor out of its recess and flip it over.
    • Don't fold the flex cable.
  34. Motorola Moto G Play (2021) Screen Replacement, Remove the vibration motor: 手順 34、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the vibration motor: 手順 34、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the vibration motor: 手順 34、 3の画像 3
    この手順で使用する道具:
    購入する
    • The vibration motor's flex cable is very fragile. Work slowly to prevent tearing the cable.
    • Use tweezers to grab and peel the base of the flex cable from the frame.
    • If the cable feels stuck or re-adheres, apply more isopropyl alcohol or heat.
    • Remove the vibration motor from the frame.
  35. Motorola Moto G Play (2021) Screen Replacement, Remove the earpiece speaker: 手順 35、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the earpiece speaker: 手順 35、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the earpiece speaker: 手順 35、 3の画像 3
    • Insert the pointed end of your spudger between the right edge of the earpiece speaker and the motherboard.
    • Pry up on the speaker and remove it
    • During reassembly, ensure that the raised side of the connectors are toward the bottom of the device.
  36. Motorola Moto G Play (2021) Screen Replacement, Remove the proximity sensor bracket: 手順 36、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the proximity sensor bracket: 手順 36、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the proximity sensor bracket: 手順 36、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use tweezers to grab and remove the proximity sensor bracket from its recess.
    • The rubber gasket is lightly adhered to the frame.
  37. Motorola Moto G Play (2021) Screen Replacement, Reposition the graphite film: 手順 37、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Reposition the graphite film: 手順 37、 2の画像 2
    • Fold the graphite heat dispersion film toward the top of the battery.
  38. Motorola Moto G Play (2021) Screen Replacement, Soften the battery adhesive with heat: 手順 38、 1の画像 1
    • Heat an iOpener and apply it to the left edge of the screen for about two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  39. Motorola Moto G Play (2021) Screen Replacement, Soften the adhesive with isopropyl alcohol: 手順 39、 1の画像 1
    • Additionally, you may use highly-concentrated isopropyl alcohol (over 90%) to further loosen the adhesive securing the battery.
    • Apply the isopropyl alcohol into the gaps between the sides of the battery and the frame.
  40. Motorola Moto G Play (2021) Screen Replacement, Pry the battery: 手順 40、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Pry the battery: 手順 40、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Pry the battery: 手順 40、 3の画像 3
    • Place a suction handle on the center of the battery.
    • Insert an opening pick between the right edge of the battery and the frame.
    • Use a steady force to pull on the suction handle and simultaneously pry with the pick.
    • Don't use excessive force on the battery. Slow, consistent pressure is all that is required to free it from the frame.
    • Apply more heat or isopropyl alcohol if the battery readheres.
  41. Motorola Moto G Play (2021) Screen Replacement, Remove the battery: 手順 41、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the battery: 手順 41、 2の画像 2
    • Remove the battery from its recess.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Use this guide to install a battery with custom-cut adhesives, or use this guide to install a battery with an adhesive sheet.
  42. Motorola Moto G Play (2021) Screen Replacement, Remove the antenna cables: 手順 42、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the antenna cables: 手順 42、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the antenna cables: 手順 42、 3の画像 3
    • Grab and remove the black antenna cable from its recess in the frame.
    • During reassembly, leave 5 mm of slack on the upper ends of the antenna cables.
  43. Motorola Moto G Play (2021) Screen Replacement: 手順 43、 2の画像 1 Motorola Moto G Play (2021) Screen Replacement: 手順 43、 2の画像 2
    • Grab and remove the gray antenna cable from its recess in the frame.
  44. Motorola Moto G Play (2021) Screen Replacement, Remove the foam strip: 手順 44、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the foam strip: 手順 44、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the foam strip: 手順 44、 3の画像 3
    • Use your tweezers to peel and remove the foam strip from the bottom of the battery recess.
  45. Motorola Moto G Play (2021) Screen Replacement, Soften the board cable's adhesive: 手順 45、 1の画像 1
    • Heat an iOpener and apply it to the board cable for two minutes.
    • The iOpener may stick to the residue left over from the battery. Clean the surrounding surface with highly-concentrated isopropyl alcohol (over 90%) to prevent this.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  46. Motorola Moto G Play (2021) Screen Replacement, Remove the board cable: 手順 46、 3の画像 1 Motorola Moto G Play (2021) Screen Replacement, Remove the board cable: 手順 46、 3の画像 2 Motorola Moto G Play (2021) Screen Replacement, Remove the board cable: 手順 46、 3の画像 3
    • Grab the upper end of the board cable.
    • Peel and remove the cable from the frame.
  47. Motorola Moto G Play (2021) Screen Replacement: 手順 47、 1の画像 1
    • The screen is all that remains.
終わりに
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
70,402 ポイント
453のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,074のガイドは作成済み
2 件のコメント
Excellent presentation. After looking at my broken phone for five months after it took a hundred mile trip stuck under the car hood being smashed over and over by the wiper arm, I decided to take the plunge.
Removing the battery was my biggest challenge, I was a bit concerned about getting the battery too hot, then got real concerned when I pried a little too hard because the glue wasn't softened enough, a little more heat gun and it cooperated.
Thanks for the concise instructions.
Larry Seppala - 返信
please who can help in fix the motorola g 2021
Abdulsalam Hammed - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 37
過去 30 日: 170
今までの合計 5,112
