メインコンテンツにスキップ
How to Replace the Adhesive for Your Motorola Phone
必要な工具と部品
  1. How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: 手順 1、 3の画像 1 How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: 手順 1、 3の画像 2 How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: 手順 1、 3の画像 3
    • Use the flat end of a spudger or your fingernail to scrape and remove the old adhesive from the phone body and back cover.
    • Pay attention to areas around the cameras and outer edge of the phone. Any remaining chunks will prevent your part from aligning properly.
  2. How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: 手順 2、 2の画像 1 How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: 手順 2、 2の画像 2
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to any remaining adhesive.
    • Use a microfiber cloth to remove the remaining adhesive.
    • If you are having trouble removing the adhesive, apply a few drops of alcohol to the adhesive and scrape it with a spudger.
  3. How to Replace the Adhesive for Your Motorola Phone, Remove the protective film: 手順 3、 1の画像 1
    • Remove the clear protective film from the new adhesive.
  4. How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: 手順 4、 2の画像 1 How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: 手順 4、 2の画像 2
    • Be very careful during this step! The adhesive is very sticky, and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Before placing the adhesive on the frame, use the cameras to ensure the adhesive's proper alignment.
    • Lay the adhesive on the frame.
    • Press down firmly on the adhesive along the perimeter of the midframe to secure it to the phone.
  5. How to Replace the Adhesive for Your Motorola Phone: 手順 5、 2の画像 1 How to Replace the Adhesive for Your Motorola Phone: 手順 5、 2の画像 2
    • Grab the blue protective film's pull tab on the top of the phone and pull towards the bottom of the phone.
    • Pull carefully so the adhesive does not separate from the phone.
  6. How to Replace the Adhesive for Your Motorola Phone, Put the back cover on: 手順 6、 1の画像 1
    • If your phone has a rear fingerprint sensor, make sure to secure it in its cutout on the back cover before proceeding.
    • Align the back cover over the back of the phone.
    • Press down firmly for one minute along the perimeter of the back cover and camera bezel to secure it with the new adhesive.
ゴール
作成者
2人の作成者と共同で作成されました。
Spencer Day
メンバー登録日: 09/14/22
149,505 ポイント
995のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,619のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 41
今までの合計 1,722
