はじめに
Use this guide to remove or replace the screen on your Motorola Edge 5G UW (2022).
This guide is for the official Motorola replacement part.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Note: Follow this guide to replace a screen that's pre-installed in a new frame (a.k.a. chassis). You'll need to transplant all of your phone's internals to the new screen. If you are replacing the display panel only, follow this guide.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive to complete this repair. If you bought an iFixit Fix Kit it will include extra Camera Cover Adhesive, Fingerprint Sensor Cable Adhesive, and Antenna Bracket Adhesive that are not necessary for this specific model.
必要な工具と部品
Heat an iOpener and apply it to the back cover's left edge for two minutes.
Apply a suction cup to the back of the phone, as close to the bottom left corner as possible.
Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the midframe on the left edge.
Insert an opening pick into the gap.
Slide the pick along the left edge of the phone to slice the adhesive securing the back cover to the frame.
Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
There's a significant amount of adhesive to the right of the cameras that secures the back cover to the motherboard cover.
Apply a heated iOpener to the right of the cameras for two minutes.
Insert an opening pick between the back cover and motherboard cover on the top right edge.
Gently pull up on the back cover while sliding the opening pick back and forth along the right side of the cameras to slice the adhesive.
Lift the back cover from the phone and remove it.
This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
Follow this guide to replace the back cover adhesive.
Use a Phillips screwdriver to remove the 13 4 mm screws securing the motherboard cover.
Insert a spudger between the motherboard cover and midframe on the top right edge of the phone.
Pry up with the spudger to release the clips securing the motherboard cover.
Gently pull the motherboard cover up and away from the phone and remove it.
Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
Use a Phillips screwdriver to remove the six 4 mm screws that secure the daughterboard cover.
Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
Use tweezers to grip the top and bottom of the white antenna's coaxial connector, as close to the connector head as possible.
Lift straight up to disconnect the cable.
Use a Phillips screwdriver to remove the 3 mm screw securing the daughterboard.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the vibration motor and its contact pad to loosen the adhesive securing them.
Let the isopropyl alcohol soak for one minute.
Use the pointed end of a spudger to pry up and disconnect the display's press connector.
Use the pointed end of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
Use the pointed end of a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
Use the pointed end of a spudger to pry up and disconnect the button assembly cable's press connector.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the 5G mmWave antenna.
Wait one minute for the isopropyl alcohol to penetrate the adhesive.
Insert the pointed end of a spudger under the 5G mmWave antenna on the side closest to the center of the phone.
Pry up with the spudger to detach the antenna.
Remove the antenna.
Apply a suction cup to the battery.
Pull up on the suction cup with strong, steady force to separate the battery from the frame.
Continue to pull up on the suction cup with a strong, steady force while sliding the opening pick back and forth to slice the adhesive.
Continue this process until the battery separates from the midframe.
If necessary, cut the adhesive blocks to fit into contours of the cable channel. The adhesive doesn't need fit the contours perfectly.
Peel the adhesive blocks from the adhesive sheet.
Place the adhesives in the board cable channel. Space them evenly through the channel.
Peel any remaining plastic liners to expose the adhesive.
Use tweezers or your fingers to remove the foam strip from the battery's bottom edge.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
ある他の人がこのガイドを完成しました。
コメント 1 件
I have the Motorola One 5GWUWace can I change to the Motorola edge, my screen is cracked sir.In your opinion which is the best Motorola phones? Thanks for your time.
