メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MSI MS-1782 Cooling Assembly Replacement
必要な工具と部品
  1. MSI MS-1782 Cooling Assembly Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Cooling Assembly Replacement: 手順 2、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement: 手順 2、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement: 手順 2、 3の画像 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 手順 3、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 手順 3、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 手順 3、 3の画像 3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Cooling Assembly Replacement: 手順 4、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement: 手順 4、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement: 手順 4、 3の画像 3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Cooling Assembly Replacement: 手順 5、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement: 手順 5、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement: 手順 5、 3の画像 3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Cooling Assembly Replacement: 手順 6、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement: 手順 6、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement: 手順 6、 3の画像 3
  7. MSI MS-1782 Cooling Assembly Replacement: 手順 7、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement: 手順 7、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement: 手順 7、 3の画像 3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Cooling Assembly Replacement: 手順 8、 3の画像 1 MSI MS-1782 Cooling Assembly Replacement: 手順 8、 3の画像 2 MSI MS-1782 Cooling Assembly Replacement: 手順 8、 3の画像 3
    • Gently lift the heat sink and then pull forwards towards you.
終わりに
作成者
3人の作成者と共同で作成されました。
Joshua Pizzo
メンバー登録日: 03/08/23
438 ポイント
3のガイドは作成済み
チーム
University of New Orleans, Team 4-4, McDonald Spring 2023 University of New Orleans, Team 4-4, McDonald Spring 2023人のメンバー
UNO-MCDONALD-S23S4G4
3 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 36
今までの合計 608
