メインコンテンツにスキップ
Google Pixel Fold Base Front Camera Replacement
必要な工具と部品
  1. Google Pixel Fold Base Front Camera Replacement, Safety Precautions: 手順 1、 1の画像 1
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel Fold Base Front Camera Replacement, Heat the bottom edge: 手順 2、 1の画像 1
    • Lay the phone down on a clean, smooth surface so the back glass is facing up.
    • Heat an iOpener and apply it to the bottom edge of the back glass for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the displays and/or internal batteries, so proceed with care.
  3. Google Pixel Fold Base Front Camera Replacement, Anti-Clamp instructions: 手順 3、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Anti-Clamp instructions: 手順 3、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Anti-Clamp instructions: 手順 3、 3の画像 3
    この手順で使用する道具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Unfold your phone completely and slide the Anti-Clamp arms over the left edge of the back glass, below the Google "G" logo.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Make sure the suction cup on the inner screen isn't touching the bezel, as it won't stick properly.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface. If the glass if cracked, use packing tape to help the suction cups adhere.
  4. Google Pixel Fold Base Front Camera Replacement: 手順 4、 3の画像 1 Google Pixel Fold Base Front Camera Replacement: 手順 4、 3の画像 2 Google Pixel Fold Base Front Camera Replacement: 手順 4、 3の画像 3
    • Place an object under your phone, like a box or a stack of books, so it rests level while between the Anti-Clamp's arms.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, detach the suction cups and realign the arms.
  5. Google Pixel Fold Base Front Camera Replacement: 手順 5、 1の画像 1
    • Insert an opening pick into the gap under the back glass.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. Google Pixel Fold Base Front Camera Replacement, Insert an opening pick: 手順 6、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Insert an opening pick: 手順 6、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Insert an opening pick: 手順 6、 3の画像 3
    • Apply a suction cup to the back glass, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back glass and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back glass.
  7. Google Pixel Fold Base Front Camera Replacement, Separate the bottom adhesive: 手順 7、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the bottom adhesive: 手順 7、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Separate the bottom adhesive: 手順 7、 3の画像 3
    • Don’t insert the opening pick deeper than 3.5 mm when separating the back glass adhesive, as you risk damaging internal components.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom left corner before continuing.
  8. Google Pixel Fold Base Front Camera Replacement, Heat the left edge: 手順 8、 1の画像 1
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
  9. Google Pixel Fold Base Front Camera Replacement, Separate the bottom left adhesive: 手順 9、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the bottom left adhesive: 手順 9、 2の画像 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Google Pixel Fold Base Front Camera Replacement, Separate the left adhesive: 手順 10、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the left adhesive: 手順 10、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Separate the left adhesive: 手順 10、 3の画像 3
    • Insert a second opening pick at the bottom left corner.
    • Slide the opening pick toward the top left corner to separate the adhesive.
    • Leave the opening pick in the top left corner before continuing.
  11. Google Pixel Fold Base Front Camera Replacement, Heat the top edge: 手順 11、 1の画像 1
    • Apply a heated iOpener to the top edge of the back glass for two minutes.
  12. Google Pixel Fold Base Front Camera Replacement, Separate the top left adhesive: 手順 12、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the top left adhesive: 手順 12、 2の画像 2
    • Rotate the opening pick around the top left corner to separate the adhesive.
  13. Google Pixel Fold Base Front Camera Replacement, Separate the top adhesive: 手順 13、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the top adhesive: 手順 13、 2の画像 2
    • Insert a third opening pick in the top left corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
  14. Google Pixel Fold Base Front Camera Replacement, Heat the right edge: 手順 14、 1の画像 1
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
  15. Google Pixel Fold Base Front Camera Replacement, Separate the top right adhesive: 手順 15、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the top right adhesive: 手順 15、 2の画像 2
    • This sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the back glass.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  16. Google Pixel Fold Base Front Camera Replacement, Separate the right adhesive: 手順 16、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the right adhesive: 手順 16、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Separate the right adhesive: 手順 16、 3の画像 3
    • Insert a fourth opening pick in the top right corner.
    • Slide the opening pick toward the bottom right corner to separate the adhesive.
  17. Google Pixel Fold Base Front Camera Replacement, Separate the bottom right adhesive: 手順 17、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Separate the bottom right adhesive: 手順 17、 2の画像 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  18. Google Pixel Fold Base Front Camera Replacement, Reposition the back glass: 手順 18、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Reposition the back glass: 手順 18、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Reposition the back glass: 手順 18、 3の画像 3
    • Don't fully remove the back glass yet, as it's still connected to the phone by a cable.
    • At this point, the back glass should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Swing the left edge of the back glass up and over the right edge of the phone.
    • Lay the back glass to the right side of the phone before continuing.
  19. Google Pixel Fold Base Front Camera Replacement, Unfasten the middle bracket: 手順 19、 1の画像 1
    この手順で使用する道具:
    FixMat
    $31.41
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the two 2.8 mm‑long screws securing the middle bracket.
  20. Google Pixel Fold Base Front Camera Replacement, Remove the middle bracket: 手順 20、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Remove the middle bracket: 手順 20、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Remove the middle bracket: 手順 20、 3の画像 3
    この手順で使用する道具:
    • Use tweezers, or your fingers, to pull the middle bracket toward the left edge of the phone and release its clip.
    • Remove the middle bracket.
    • During reassembly, reinsert the middle bracket clip under its slot in the frame before aligning the screw holes.
  21. Google Pixel Fold Base Front Camera Replacement, Disconnect the back glass cable: 手順 21、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Disconnect the back glass cable: 手順 21、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the back glass cable from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  22. Google Pixel Fold Base Front Camera Replacement, Remove the back glass: 手順 22、 1の画像 1
    • Remove the back glass.
  23. Google Pixel Fold Base Front Camera Replacement, Reassembly information: 手順 23、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Reassembly information: 手順 23、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    • During reassembly:
    • If you're reusing your back glass, use tweezers to remove big chunks of adhesive from the perimeter of the back glass.
    • Repeat for any adhesive on the frame.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace the back glass adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the back glass to the frame.
  24. Google Pixel Fold Base Front Camera Replacement, Reposition the graphite sheet: 手順 24、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Reposition the graphite sheet: 手順 24、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Reposition the graphite sheet: 手順 24、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    • The graphite sheet is very fragile. Be gentle peeling the graphite sheet in this step, especially if you're reusing it.
    • The graphite sheet is lightly adhered to the logic board.
    • Peel the bottom of the graphite sheet toward the top of the phone until you can access the bottom bracket.
    • Use your hands, or tape with light adhesive, to keep the graphite sheet out of the way.
    • If you completely removed your graphite sheet, follow this guide to replace it.
    • If you don't have custom cut adhesive strips for the antenna, use double-sided tape, like Tesa Tape, to secure the graphite sheet to the logic board.
  25. Google Pixel Fold Base Front Camera Replacement, Remove the screw cover: 手順 25、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Remove the screw cover: 手順 25、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Remove the screw cover: 手順 25、 3の画像 3
    この手順で使用する道具:
  26. Google Pixel Fold Base Front Camera Replacement, Unfasten the bottom bracket: 手順 26、 1の画像 1
    • Use a Torx Plus 3IP driver to remove the five 3.1 mm‑long screws securing the bottom bracket.
  27. Google Pixel Fold Base Front Camera Replacement, Remove the bottom bracket: 手順 27、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Remove the bottom bracket: 手順 27、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Remove the bottom bracket: 手順 27、 3の画像 3
    • Use tweezers, or your fingers, to pull the bottom bracket toward the bottom edge of the phone and release its clip.
    • Remove the bottom bracket.
    • During reassembly, reinsert the bottom bracket clip under its slot in the logic board before aligning its screw holes.
  28. Google Pixel Fold Base Front Camera Replacement, Disconnect the base battery: 手順 28、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Disconnect the base battery: 手順 28、 2の画像 2
    • There are two batteries you need to disconnect, one for each half of the phone.
    • Use the point of a spudger to pry up and disconnect the base battery cable press connector.
  29. Google Pixel Fold Base Front Camera Replacement, Remove the tape: 手順 29、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Remove the tape: 手順 29、 2の画像 2
    • Peel the grey conductive tape off the bottom interconnect cable.
  30. Google Pixel Fold Base Front Camera Replacement, Disconnect the flip battery: 手順 30、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Disconnect the flip battery: 手順 30、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Disconnect the flip battery: 手順 30、 3の画像 3
    • Use a point of a spudger to pry up and disconnect the flip battery and bottom interconnect press connectors.
    • You have to disconnect both cables to keep the battery connector from accidentally touching the logic board.
  31. Google Pixel Fold Base Front Camera Replacement, Reassembly information: 手順 31、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Reassembly information: 手順 31、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Reassembly information: 手順 31、 3の画像 3
    • During reassembly, the next two steps demonstrate how to replace the flip battery and bottom interconnect cable conductive tape.
    • Peel off the new conductive tape from its liner and apply the sticky side to the bottom interconnect connector, making sure to bridge the logic board.
  32. Google Pixel Fold Base Front Camera Replacement: 手順 32、 3の画像 1 Google Pixel Fold Base Front Camera Replacement: 手順 32、 3の画像 2 Google Pixel Fold Base Front Camera Replacement: 手順 32、 3の画像 3
    • Use a spudger, or your fingers, to press down the conductive tape and adhere it.
    • Use tweezers, or your fingers, to pull on the tab and expose the tape.
  33. Google Pixel Fold Base Front Camera Replacement, Unfasten the top bracket: 手順 33、 1の画像 1
    • Use a Torx Plus 3IP screwdriver to remove the two 2.8 mm‑long screws securing the top bracket.
  34. Google Pixel Fold Base Front Camera Replacement, Remove the top bracket: 手順 34、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Remove the top bracket: 手順 34、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Remove the top bracket: 手順 34、 3の画像 3
    • Pull the top bracket toward the left edge of the phone to release its clips.
    • Remove the top bracket.
    • During reassembly, insert the top bracket clips under their slots in the frame before aligning the screw holes.
  35. Google Pixel Fold Base Front Camera Replacement, Disconnect the front camera: 手順 35、 2の画像 1 Google Pixel Fold Base Front Camera Replacement, Disconnect the front camera: 手順 35、 2の画像 2
    • Insert the point of a spudger under the bottom right corner of the front camera press connector.
    • Don't insert the spudger anywhere else, as you risk breaking surface-mounted components.
    • Pry up and disconnect the front camera press connector.
  36. Google Pixel Fold Base Front Camera Replacement, Heat the front camera: 手順 36、 1の画像 1
    • The front camera is mildly adhered to the frame.
    • Heat an iOpener and apply it to the front camera for two minutes.
  37. Google Pixel Fold Base Front Camera Replacement, Remove the front camera: 手順 37、 3の画像 1 Google Pixel Fold Base Front Camera Replacement, Remove the front camera: 手順 37、 3の画像 2 Google Pixel Fold Base Front Camera Replacement, Remove the front camera: 手順 37、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    • Grab the front camera by the neck of its connector, as close to the camera body as possible.
    • Don't press down on the press connector's pins, as you may bend them.
    • Pull straight up to separate the adhesive and remove the front camera.
    • During reassembly, if your adhesive is still sticky and intact, you can reuse it. Otherwise, follow this guide to replace it with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the front camera to the frame.
終わりに
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
作成者
2人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
213,038 ポイント
1,040のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,623のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 44
今までの合計 580
