はじめに
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a dead or worn-out battery in your Google Pixel 10a. All batteries have limited lifespans. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
You'll need replacement rear cover adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the mating surfaces are.
必要な工具と部品
Use a hair dryer to heat the entire rear cover until it's hot to the touch.
Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
The rear cover is secured with adhesive around the frame perimeter and near the cameras. Use this picture as a reference while you separate the adhesive.
When separating the left edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
Slide the opening pick around the entire perimeter to separate the adhesive.
この手順で使用する道具:Magnetic Project Mat$19.95
Use a Torx Plus 3IP screwdriver to remove the fifteen 5.0 mm‑long screws securing the wireless charging assembly:
Thirteen gray screws
Two silver non-magnetic screws
Use an opening pick to pry up and unclip the wireless charging assembly from the two cutouts—one near the bottom-right corner, and another on the left edge near the power button.
Use a Torx Plus 3IP screwdriver to remove the 1.9 mm‑long screw securing the battery connector cover.
Insert the point of a spudger under the top-right corner of the battery connector.
Pry up to disconnect the battery.
Throughout the repair, pry only at the instructed area (also marked by a gold line on the circuit board) to prevent damage to the delicate components near the connector socket.
Use your fingernail or a spudger to peel up the left-side button cable and flip it over the side of your phone.
Use your fingers or an opening pick to peel up a corner of the battery pull tab labeled "2".
Grab the tab with your fingers and peel it off the top of the battery.
Peel the pull tab labeled "1" completely off the top of the battery.
With both hands, firmly grab the pull tab labeled "2" as close to the left edge as possible. Brace your hands against the rest of the phone frame.
Pull up with firm, steady force until the battery separates.
If you can't loosen the battery, follow the next step for an alternate method.
Apply two or three drops of high-concentration (>90%) isopropyl alcohol to the left edge of the battery.
Tilt the left edge of the phone up to help the alcohol flow under the battery.
Wait one minute to allow the alcohol to soften the adhesive.
Use the flat edge of an opening pick to pry up the left edge of the battery until it separates.
Peel and remove the battery and its plastic liner from the phone.
Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filters) to remove any adhesive residue from the battery well.
Remove the thin liner from the top edge of the back of the battery.
Bend the left button cable over the edge so it'll be out of the battery's way.
Hold the battery above its recess and use your finger to press and connect the battery press connector.
Don't try to force the connector into place. If you're having trouble, reposition it and try again.
With one hand, steady the battery over its recess.
With the other hand, pull the liner from the underside of the battery to expose the adhesive.
Carefully lay the battery in its recess.
Hook the left edge of the battery connector cover in place, then lay the cover down flat.
Use your finger to fold the left button cable onto the battery and press it in place.
Lay the wireless charging assembly onto the frame.
Use your fingers to press around the perimeter to engage all of its clips.
Stop if the assembly feels like it won't clip in. Check if anything underneath it may be out of place.
Power on your phone and check all functions.
Run a diagnostics test with the built-in Pixel Diagnostic tool.
Fully power off your phone before you continue with reassembly.
Use your fingers, spudger, or tweezers to remove the adhesive from the frame perimeter.
If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
Use some high concentration (>90%) isopropyl alcohol and a lint-free cloth (or coffee filter) to remove any adhesive residue.
Inspect the adhesive blocks surrounding the rear cameras. If they're clean and unwrinkled, you can reuse them and skip down three steps.
Use the point of a spudger to pry up and remove the seven adhesive blocks surrounding the rear cameras.
Inspect the interior adhesive blocks on the rear cover. If they're clean and unwrinkled, you can reuse them and skip down two steps.
Use a spudger to scrape and remove the interior adhesive blocks from the rear cover.
Without peeling any liners, hold the rear cover adhesive over the phone to figure out how it'll sit on the frame. Use the camera cutout to help with orientation.
Make sure the rear cover camera cutouts are clean. Carefully wipe them with a lint-free cloth if needed.
Remove any lens caps or liners from the rear cameras. Make sure the lenses are clean. Gently wipe them with a lint-free cloth if needed.
Lay the rear cover over the frame.
Firmly press around the perimeter to secure the adhesive.
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
