メインコンテンツにスキップ
Dell Inspiron 3501 SSD Replacement
Clay Eickemeyer
Clay Eickemeyer とその他 2 人の作成者
最終更新日: February 15, 2023
15 - 30 分
中レベル
Use this guide to replace the SSD in your Dell Inspiron 3501.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
必要な工具と部品
修理キット
キットには、この修理ガイドを完了するために必要な全ての部品とツールが含まれています。
パーツ
ツール
もっと見る
  1. Dell Inspiron 3501 SSD Replacement, Unfasten the back cover: 手順 1、 2の画像 1 Dell Inspiron 3501 SSD Replacement, Unfasten the back cover: 手順 1、 2の画像 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 SSD Replacement, Unclip the front corners: 手順 2、 2の画像 1 Dell Inspiron 3501 SSD Replacement, Unclip the front corners: 手順 2、 2の画像 2
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 SSD Replacement, Unclip the sides: 手順 3、 2の画像 1 Dell Inspiron 3501 SSD Replacement, Unclip the sides: 手順 3、 2の画像 2
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 SSD Replacement, Remove the back cover: 手順 4、 3の画像 1 Dell Inspiron 3501 SSD Replacement, Remove the back cover: 手順 4、 3の画像 2 Dell Inspiron 3501 SSD Replacement, Remove the back cover: 手順 4、 3の画像 3
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
  5. Dell Inspiron 3501 SSD Replacement, Disconnect the battery: 手順 5、 2の画像 1 Dell Inspiron 3501 SSD Replacement, Disconnect the battery: 手順 5、 2の画像 2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 SSD Replacement, Unfasten the SSD cover: 手順 6、 2の画像 1 Dell Inspiron 3501 SSD Replacement, Unfasten the SSD cover: 手順 6、 2の画像 2
    • Use your Phillips screwdriver to remove the 4 mm-long screw securing the silver SSD shield.
    • Use your Phillips screwdriver to loosen the captive screw.
  7. Dell Inspiron 3501 SSD Replacement, Remove the SSD cover: 手順 7、 2の画像 1 Dell Inspiron 3501 SSD Replacement, Remove the SSD cover: 手順 7、 2の画像 2
    • Lift the SSD cover straight off the SSD to remove it.
  8. Dell Inspiron 3501 SSD Replacement, Remove the SSD: 手順 8、 3の画像 1 Dell Inspiron 3501 SSD Replacement, Remove the SSD: 手順 8、 3の画像 2 Dell Inspiron 3501 SSD Replacement, Remove the SSD: 手順 8、 3の画像 3
    • Grip the edges of the SSD near the screw indent.
    • Pull the SSD straight out from its socket and remove it.
    • If it feels stuck, gently wiggle it side to side as you pull.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Clay Eickemeyer
メンバー登録日: 09/19/22
82,171 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,483のガイドは作成済み
1ガイドコメント
Thank you very much
jAnitH PrAmoDYa - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 51
今までの合計 1,598
