メインコンテンツにスキップ
Dell Chromebook 5190 WLAN Card Replacement
Brian
Brian とその他 2 人の作成者
最終更新日: June 20, 2022
35 - 40 分
中レベル
This guide will aid you in replacing your Dell Chromebook 5190 WLAN card.
The Dell Chromebook 5190 was released alongside its sister model Dell Chromebook 5190 2-in-1. This guide will focus on the 5190 model that lacks a touchscreen.
If your laptop is having trouble or failing to connect Wi-fi, the WLAN card may be the issue. Make sure to check the troubleshooting page first. If the same problem persists, then you will need to replace the WLAN card.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Dell Chromebook 5190 WLAN Card Replacement, Battery: 手順 1、 1の画像 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 WLAN Card Replacement: 手順 2、 3の画像 1 Dell Chromebook 5190 WLAN Card Replacement: 手順 2、 3の画像 2 Dell Chromebook 5190 WLAN Card Replacement: 手順 2、 3の画像 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 WLAN Card Replacement: 手順 3、 2の画像 1 Dell Chromebook 5190 WLAN Card Replacement: 手順 3、 2の画像 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 WLAN Card Replacement: 手順 4、 2の画像 1 Dell Chromebook 5190 WLAN Card Replacement: 手順 4、 2の画像 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 WLAN Card Replacement: 手順 5、 2の画像 1 Dell Chromebook 5190 WLAN Card Replacement: 手順 5、 2の画像 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 WLAN Card Replacement: 手順 6、 3の画像 1 Dell Chromebook 5190 WLAN Card Replacement: 手順 6、 3の画像 2 Dell Chromebook 5190 WLAN Card Replacement: 手順 6、 3の画像 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: 手順 7、 2の画像 1 Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: 手順 7、 2の画像 2
    • Unscrew and remove the M2x3 screw.
    • Remove the metal bracket.
  8. Dell Chromebook 5190 WLAN Card Replacement: 手順 8、 1の画像 1
    • Remove WLAN antennas.
  9. Dell Chromebook 5190 WLAN Card Replacement: 手順 9、 1の画像 1
    • Slide the WLAN card away from the motherboard.
終わりに
作成者
2人の作成者と共同で作成されました。
Brian
メンバー登録日: 02/10/22
97 ポイント
1ガイドが承認済み
チーム
Gateway, Team 1-3, Pee Spring 2022 Gateway, Team 1-3, Pee Spring 2022人のメンバー
GCC-PEE-S22S1G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 146
