Blink Video Doorbell Lens Replacement
はじめに
手順 1 に進むThe Blink Video Doorbell is a doorbell to provide extra security to your residence by giving you an accessible view whenever necessary. The lens is an essential part of the device’s camera. It allows you to view images with sharpness, composition; therefore, determining image quality. Refer to the troubleshooting page if there are issues with the camera which could be connected to causes such as battery failure, software failure, and frozen screen. If you need to take out the lens, use this guide to remove and replace the lens.
必要な工具と部品
ツール
もっと見る
Push the opening key into the small opening with the two gray buttons on the bottom of the device.
Push the device up from the mount and slide it off.
Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
