メインコンテンツにスキップ
Alcatel Fierce 4 Display Replacement
Mckenzie Dalley
Mckenzie Dalley とその他 3 人の作成者
最終更新日: August 13, 2021
20分
中レベル
多くの画像が必要
空欄の手順
This guide will show you how to replace the display of an Alcatel Fierce 4 phone.
 A display replacement could be helpful if your screen is cracked or not working properly. Common problems that could mean that a display replacement is necessary is flickering, blank screen and unresponsiveness from touch input.
 Before you replace your display it's recommended that you make sure to rule out other problems. A screen will not turn on if the phone has a battery issue in which it will not hold a charge. To make sure this isn't a battery issue plug your phone to a wall outlet and verify that the screen still does not turn on or remains unresponsive. A detailed troubleshooting guide can also be found at (Alcatel Fierce 4 Troubleshooting).
Be aware that replacing the display is moderately difficult and it should only be done while the phone is powered off. The connections from the screen to the phones motherboard are very delicate, disconnect cables with caution as you could further damage the phone if not careful.
必要な工具と部品
ツール
もっと見る
  1. Alcatel Fierce 4 Display Replacement, Battery: 手順 1、 1の画像 1
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Alcatel Fierce 4 Display Replacement: 手順 2、 2の画像 1 Alcatel Fierce 4 Display Replacement: 手順 2、 2の画像 2
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Alcatel Fierce 4 Display Replacement: 手順 3、 1の画像 1
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Alcatel Fierce 4 Display Replacement: 手順 4、 2の画像 1 Alcatel Fierce 4 Display Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Alcatel Fierce 4 Display Replacement: 手順 5、 1の画像 1
    • Remove the motherboard from the phone.
  6. Alcatel Fierce 4 Display Replacement: 手順 6、 1の画像 1
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Alcatel Fierce 4 Display Replacement, Display: 手順 7、 1の画像 1
    • Replace with new display assembly.
終わりに
作成者
3人の作成者と共同で作成されました。
Mckenzie Dalley
メンバー登録日: 11/04/19
73 ポイント
1ガイドが承認済み
チーム
Idaho State University, Team S1-G1, Watkins Fall 2019 Idaho State University, Team S1-G1, Watkins Fall 2019人のメンバー
ISU-WATKINS-F19S1G1
3 メンバー
2のガイドは作成済み
0ガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 335
