メインコンテンツにスキップ
Acer Chromebook cb3-532-c47c Display Assembly Replacement
Jerry Wheeler
Jerry Wheeler とその他 人の作成者
最終更新日: July 1, 2022
見積もりなし
中レベル
コミュニティメンバーによる寄稿ガイド
This procedure is not necessary if you're just replacing the LCD panel; it is only used if you need to replace the entire display assembly, including the LCD, top cover, front bezel and hinges, along with the associated antennas and camera.
必要な工具と部品
ツール
もっと見る
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: 手順 1、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: 手順 1、 2の画像 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 手順 2、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: 手順 3、 1の画像 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: 手順 4、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: 手順 4、 2の画像 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: 手順 5、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: 手順 5、 2の画像 2
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: 手順 6、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: 手順 6、 2の画像 2
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 手順 7、 3の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 手順 7、 3の画像 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: 手順 7、 3の画像 3
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: 手順 8、 1の画像 1
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 手順 9、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 手順 9、 2の画像 2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: 手順 10、 1の画像 1
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: 手順 11、 2の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement: 手順 11、 2の画像 2
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 手順 12、 3の画像 1 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 手順 12、 3の画像 2 Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: 手順 12、 3の画像 3
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jerry Wheeler
メンバー登録日: 03/21/22
72,350 ポイント
71のガイドは作成済み
チーム
Oregonians Oregonians人のメンバー
Community
8 メンバー
191のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 10
今までの合計 357
