Battery Pack
ツール
以前、このデバイスの修理に使われていた一般的な工具です。修理過程において全部の工具が必要とは限りません。
Background and Identification
The Artisan PH-BT2020 is rectangular and has four main buttons on the top of the device for rewind, skip, play, and Bluetooth voice controls. There is also a small logo on the front face of the speaker. A microphone for Bluetooth interactions is included inside of the speaker.
The back of the device features an ON/OFF switch, a Micro USB charging port, and an Auxiliary port. There is also an LED light on the back that will turn red to indicate whether or not the speaker is charging. The LED will turn blue when in “pairing mode”. This device can play music while charging simultaneously.
The speaker is covered in tiny holes on the front face and the left and right sides to let sound escape. The underneath also has holes, as well as rubber feet on the left and right sides, covering up the screws.
Portable Bluetooth connectivity allows you to stay connected within up to 30 feet. This speaker also features a built in passive subwoofer. It claims a battery life of up to 8 hours. Ships in multiple different colors.
Technical Specifications
- Lithium Ion battery
- Part Number BT2020
- Weight 522g
- Manufacturer: Photive
