‘Suddenly’ no display output
Hi,
My trusty Mac mini might not be so trustworthy as I thought. My machine’s specs are 2.3 ghz i7, with 16Gb RAM and an upgraded 1 TB SSD. It never had the Fusion Drive. I bought it new from an Apple Authorised Dealer and they did the memory upgrade before I purchased the Mac. Maybe they also changed the Fusion Drive to a different drive type, but that is not something that I had asked for. Not that it matters now because I have upgraded the drive to the SSD as above and I did that about two years ago. The Mac has been running well since.
A few weeks ago, the Mac started running a little bit slower, or that’s what it seemed like. I monitored it for a couple of days and then one day it started getting really slow. As I hadn’t rebooted it for a while, I decided to shut it down and reboot.
Except that when I rebooted, the screen was completely blank. I tried to reboot again, but I got the same result. I rebooted it a few more times and I continued to get the same blank screen.
I found an old Dell monitor with only a VGA connection on it and I scrounged around and found the adapter to get the VGA monitor connected to my Mac mini. Another reboot. Same result as before - blank screen.
I’m wondering if it is possible to use the HDMI port to connect to a monitor, and would that bypass the ‘display card’? My assumption is probably the worst case scenario where the ‘display card’ has had it, and I think that I’ve read somewhere that the display function is inbuilt on the motherboard.
I don’t want to lose my Mac mini!
Thanks for sharing your expertise and knowledge.
