Why wont my 2ds xl charge?
I replaced the battery on my “New Nintendo 2ds xl” due to the device not charging. Now the charging light will turn on for a little while and then will suddenly turn off. Any suggestions?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 29
What was the original issue? Did the orange light also came up with the old battery? Or not at all? It's possible that your replacement battery is faulty.
koppie007 さんによる
Before I changed the battery it had the same issue with not charging and the light acted the same. The new battery has great reviews so I dont think thats the issue but it very well could be. Is there anything else you think the problem might be if the battery isnt the problem?
zacharywillner@gmail.com さんによる
Someone did had the same issue here: Orange LED turns on for 5 seconds then shuts off when plugged in
It could be a Fuse, but then you do need to take the motherboard out and do a continuity test with your multimeter!
koppie007 さんによる
Youre the goat. Thank you
Trying to do my best hahaha
koppie007 さんによる
