メインコンテンツにスキップ
5G搭載スマートフォンGoogle Pixel 6aの修理ガイド情報です。2022年7月に発売。
Glue for screen seam and plastic frame
Hello everyone, I'm going to change a battery on my phone. Looks like battery is very isdegraded and the screen is detached from the plastic frame, please check Figure 1 below. I've pre-read documentation, how to de-assembly the phone, and noticed that I will have to pry under plastic frame (Step 2 - Screen removal information).
I'm going to detach screen and then detach plastic frame. And of course I will need to glue the screen and this frame.
Which glue is applicable in that case? I heard about P7000, but decided to ask, if it's applicable for such case.
Figure 1
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @pavel80282
In the ifixit guide that you linked, scroll down to kit contents. It shows that Google Pixel 6a Display Adhesive - Genuine is available from ifixit.
This custom cut adhesive film secures the display panel to the frame of a Google Pixel 6a smartphone.の画像
製品
$3.99
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
Please check the documentation. My case is red - screen seam, and it was detached by degraded battery. I have case with detached screen from plastic frame, and probably this Display Adhesive is not applicable for glue the screen and plastic frame.
さんによる
@pavel80282
Maybe I'm wrong but it states "This custom cut adhesive film secures the display panel to the frame of a Google Pixel 6a smartphone".
さんによる
A bit wrong. On the side Pixel 6a has 2 seams, first right under display, and second under plastic frame. And if you check the whole documentation, this adhesive must be placed UNDER the plastic frame (How to Replace the Adhesive for Your Google Pixel 6a) . The screen must be TOGETHER with this plastic frame. My goal is glue display and this plastic frame.
さんによる
@pavel80282
My mistake. Apologies.
Never heard of P7000 glue.
There's B7000 which is a clear glue and T7000 which is black but basically they're the same.
Some say that T7000 is better because it doesn't allow light from the LCD to get through. Don't know personally if this is correct.
さんによる
No worries.
Which of these can be used in my case? Maybe you heard about some special instruction, how to do that?
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Pavel さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 99
