メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
Xbox One S startet nicht
Hello everyone,
My Xbox One S won't start anymore. The issue appeared suddenly without any external influence.
Error description:
When I press the button, the button lights up, and it beeps as usual, but then nothing happens. Normally, the fan should start, and the Xbox should boot up.
You can repeat the process endlessly, but nothing happens.
Steps checked and actions taken so far:
  • Replaced the power supply (installed a new one).
  • Tried a different power cable.
  • Completely disassembled the motherboard and discovered oxidation on the copper edge on the back. This was carefully sanded off, all rust spots removed, and the entire board cleaned. No short circuits or missing capacitors detected. (I'm considering covering the copper edge with a thin layer of solder, but I couldn’t find any interruptions so far.)
  • Checked and repaired the hard drive using a computer, as Windows detected errors. (Later I learned you shouldn't do that but however the failure started already before)
  • Tested with another hard drive. (1tb HDD formatted with XBOX HDD Tools script)(you hear by clicking the start button that the HDD gets shortly power)
  • Ordered a new fan in case it's defective and preventing the Xbox from starting.
Does anyone have any other ideas why the Xbox won't start?
Thank you!
Valentin
______________________________________________________________________________________
Hallo zusammen,
Meine Xbox One S startet nicht mehr. Das Problem trat plötzlich auf, ohne äußere Einwirkung.
Fehlerbeschreibung:
Wenn ich den Knopf drücke, leuchtet der Knopf auf und es piept wie gewohnt, aber dann passiert nichts. Normalerweise sollte der Lüfter starten und die Xbox hochfahren.
Man kann den Vorgang endlos wiederholen, aber es passiert nichts.
Bisher geprüft und unternommen:
  • Das Netzteil wurde ausgetauscht (ein neues eingebaut).
  • Ein anderes Netzkabel wurde verwendet.
  • Die Platine wurde komplett ausgebaut, und auf der Rückseite wurde Oxidation am Kupferrand entdeckt. Diese wurde vorsichtig abgeschliffen, alle Roststellen wurden beseitigt, und die Platine wurde vollständig gereinigt. Es wurden keine Kurzschlüsse oder fehlende Kondensatoren festgestellt. (Ich überlege, den Kupferrand mit einer dünnen Lötzinnschicht zu überziehen, aber bisher konnte ich keine Unterbrechung feststellen.)
  • Die Festplatte wurde am Computer überprüft und repariert, da Windows Fehler erkannt hatte. (Später habe ich gelernt, man sollte das nicht tun. Aber wie auch immer, der Fehler war ja bereits vorher da.
  • Eine andere Festplatte wurde testweise eingebaut (1 tb HDD formattiert mit XBOX HDD Tools skript) (Man hört bei drücken des Startknopfes auch, dass sie kurz Strom bekommt)
  • Ein neuer Lüfter wurde bestellt, falls dieser defekt sein sollte und die Xbox dadurch nicht startet.
Hat jemand sonst noch eine Idee, warum die Xbox nicht mehr startet?
Vielen Dank!
Valentin
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi Valentin!
Usually this indicated a problem with the HDD.
Please try another HDD completely formatted and put it in. It should at least display an error.
If this is the case, it's the HDD which is broken. Then indeed use a known working (or new) HDD formatted with the Xbox HDD script.
It's also possible that the SATA cable is broken or the power connector, please check those out too.
Off course it's possible that something else died on the motherboard. If the above all failed, then check the motherboard again...
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Hi Koppie,
Thank you for your input!
What you described is what I already tried but without success. I Tested with another hard drive. (1tb HDD formatted with XBOX HDD Tools script) but same behaviour.
Today the new fan arrived and I installed it but still Xbox is not starting.
Any other ideas ?
Thanks in advance
Valentin
さんによる
Hmm, the next step is the HDMI IC, HDMI port or the HDMI filters.
It does look like something died there. I would try to replace the HDMI IC first (also check the port first, if it looks fine, it should be fine).
さんによる
It could be something with the HDD - I just measured the voltage at the pins for the HDD while pressing power button. But I measured 0 voltage over yellow colour against black - gnd.
Over blue and red i measure a short peak voltage around 5 v for 1 sec after pressing the power button then it falls back to 0V. Also the fan starts for a second.
But the yellow cable at the HDD power supply I should also see a voltage change while pressing the power button, usually 12v right?
But however, it still everything stops running after milliseconds after presssing the power button.
But my knowledge is now at the edge. No idea how to find out why i have no voltage at the pin for yellow cable for HDD
さんによる
So far I know, yellow is 12V and red is 5V. Did you tried other cables..? Anyway, still probably motherboard related. Must be some component that failed there (maybe a capacitor?).
さんによる
I measured directly on the Mainboard at the pins. So already before the cables I don't see voltage on 12 volt pin when pressing the button.
Any one else have the same problem ?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Valentin Jost さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 41
