メインコンテンツにスキップ
任天堂スイッチは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
20回答 すべてを表示
Switch not outputting via HDMI
My Switch stopped working with my TV overnight - there was no power outage or anything, it just stopped displaying anything via HDMI.
I’ve seen similar threads where users suggested power cycling the TV, trying different ports etc. but that doesn’t seem to be the case here since I’ve tried it on another TV and my PC monitor with no success. I’m sure that the dock is okay - a different console works perfectly fine on my dock while my Switch doesn’t work with a different dock either, I’ve also tried a USB C hub with HDMI output which didn’t work too.
Is there anything else I can try before sending it off to a repair shop? My console is already nearly 7 years old (Mario Odyssey version) but works perfectly fine, apart from the TV output. If the console is indeed faulty, what could be the cause? I’m guessing it’s going to be a way more serious repair than just replacing the USB C port since it charges without issues.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
8 件のコメント:
Have you tried a seprate HDMI cable for that port?
さんによる
Both the original Nintendo one, other cables that work with my Xbox for example and even a completely new one - no luck.
さんによる
Have you tried a factory reset?
さんによる
Yup, didn’t help either
さんによる
Maybe a solder joint cracked? Take a look at the charging port and P13 chip, reflow them if you're able. (The port has extra pins tucked under it, so it requires hot air)
さんによる
3件以上のコメントを表示
コメントを追加
1 件の回答
I would check for shorts along the m92 chip and the video chip. If any of the capacitors are shorted that means the chip has a short which could cause this. I think it’s more likely the video chip since I believe that’s what determines if the usbc acts as a video output or a charger. I’m not entirely sure because I haven’t been working with switches for too long but that is what I would recommend. Hope you can get it to work!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 244
