メインコンテンツにスキップ
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
20回答 すべてを表示
The status indicator light is on once connected to power
My mac mini i7 cannot send video signal to monitor (black screen). I found the indicator light will immediately on (white) once I connected this Mac mini to power. Press the power button for 10 seconds, I can turn off the Mac min and the light also turned off. the light will be on if unplug and replug in .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Have you tried anything specifically yet to fix this? This could be as simple as a bad cable. How are you connecting your Mac to the monitor?
さんによる
I have two Mac mini, the other one is i5 I used the same hdmi cable. mini i5 is working well. I connected this working min i5 to the same power supply, the indicator light won't turn on until I press the power button.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Given your symptoms I’m suspecting the I/O logic within the CM246 platform controller has failed, I’ve seen this before as the video wake line still functions which is what you are seeing.
Sadly, this system will need a new logic board.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, Dan. Could you tell me the name of logic board and where I can find it ?
thanks,
さんによる
@yuan24263 - This series has soldered storage, as such each version has a different P/N. Review this listing to find the one you either have now or if storage is a bit thin jump up to a larger version. 2018 Mac Mini Logic Boards
さんによる
コメントを追加
回答を追加する
yuan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 93
