The WiFi feature can be turned on but cannot connect
The WiFi feature can be turned on but cannot connect to the WiFi provider
Hi @nedy5765
Try using the phone's WiFi as close as possible to your network router i.e. <10cm and check if you can connect.
If you can it may be a loose antenna connection in the phone.
Here's the ifixit Samsung Galaxy A10 Screen Replacement guide that may help.
In the image in Step.11 you can see the two antennas (white and blue wires) connected at one end of the phone. The travel down the side of the phone to be connected at the board at the other end (not shown).
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 91
