Why the not detecte earphone
My phone is not detecting earphone when i plug in
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
@michael45594 could be a bad headphone jack or a bad board. I would go ahead and replace the Sub board (charging board) which holds the headphone jack. Use something like this guide Samsung Galaxy A12 Disassembly to change it. Step 6 shows you the removal.
When you order a replacement, make sure that you get a charging board that it appropriate for your Version of the A12.
このアンサーは役に立ちましたか?
I ran across a video showing the charging board replacement (which also contains the earphone jack) that you might find useful.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 57
