メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
Broken IR Sensor Broken
Hello, I was trying to install an SSD in to my late 2012 Mac mini using the ifixit guide. However I was cheating and not taking the logic board out. I could not seat the ssd hard drive at all, so I decided to try and take the logic board out - not realising you need a tool to take the board out. However I started by taking the IR sensor out, but I think I have broken it off the logic board. Is this sensor essential? Does anyone have any tips if I can still install the hard drive to fit in properly?
Update (04/12/2022)
Also I found a ‘Y’ shaped bracket under the hard drive. Would you know what it’s for?
Thanks in advance.
Update (04/11/2022)
Hello everyone, just an update on the Mac mini - I got the IR sensor soldered, the Mac booted up fine. When I tried to install a fresh copy of Catalina the ssd was not visible. Also I don’t think Bluetooth was working. I took the Mac back the person who soldered the cable, to see what the problem was. He said the cable connecting the ssd to the motherboard may be broken and the Bluetooth cable could be broken too -he would have a look. Went back today and he hadn’t been able to fix it. When the ssd is screwed to the grill on the bottom it disconnects the cable from the motherboard. Does anyone have any idea how I can stop this? Do I need to get a new cable? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Please post a few pics so we can see what's damaged and where it came from iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
2件の回答
Well, it only looks like you yanked the board connector off the logic board. The cable connector appears to be just fine!
You'll need to resolder the connector back down. Fully remove the logic board and pull the drive tray out so you can inspect the cable held within it and carefully remove the board connector from the cable connector. You'll also want to inspect the pads which your images hide to make sure they are still present. Then its just a matter of resoldering the connector back down (make sure you make note which way it goes!
The metal piece you found is the slide latch which holds the AC outlet. Review Step 20 in this guide Mac mini Late 2012のアウターケースの交換 and reference Step 24 on how to remove the drive tray
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi there, thanks for the reply. I’ve never soldered anything in my life, so I might need to put in for repair. I tried Apple, they sent details for a company that could repair it, but it is classed as vintage now so they won’t touch it. I will try the local shop that fixes computers and phones. Once again thanks.
さんによる
@Cannaefixamac - Its in a tight space, so not the best job for a first time. Show them your pictures this is not hard for someone with some skills and the correct tools to fix.
さんによる
コメントを追加
最も参考になった回答
Make a tool with a wire coat hanger and some pliers. Easy.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Cannaefixamac さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 5
今までの合計 279
