Why won’t my system read cartridges
Every time I try and play a cartridge game, it never works I also hear this grinding sound, I have no idea why this is happening, can someone please help
You can try replacing the cartridge slot. The grinding might be coming from thing on the pins or in the slot itself.
このアンサーは役に立ちましたか?
Before replacing the slot, you could try a trick to clean the card reader pins first.
hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 341
2 件のコメント
it makes the grinding when on and sitting on a flat surface?
there are no real moving parts in the console so it seems like the grinding would be coming from the speakers probably.
Logixal さんによる
No, it’s when I put a cartridge in on any surface
John Bitzas さんによる
