メインコンテンツにスキップ
2018年10月26日発売。モデル番号はA1984, A2105, A2106, A2108。オプションとしてGSM もしくは CDMA / eSIM, nano-SIM もしくは dual-SIM / 64, 128もしくは 256 GB /カラーバリエーションはブラック、ホワイト、ブルー、イエロー、コーラル、レッドがあり。(正しい発音は"iPhone 10 R"です)
20回答 すべてを表示
iPhone XR U3300 Charging IC Overheating
Hello, I have an iPhone XR which I replaced the charging IC U3300 on it since it was overheating, but even after replacing U3300 the IC is still overheating. Any ideas? Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well with a bit of common sense, you will realize its not the Charging IC itself that has gone bad. It is some other small component on the charging IC line that is causing it to heat up. If you have a thermal camera its the best time to put it to use and find that bad cap.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
I tried looking for a component on the charging IC line which may have gone bad using the rosin smoke method, however the only thing that heats up right away is the charging IC itself, only in one area. I am confident it is the pad C1 on the chip. Do you think that the small component that may be causing this is not getting hot?
さんによる
Yes, this type of short wont be detectable using rosin smoke method. I've had numerous of them and now finally ordered a Thermal Camera. It's a priceless tool imho.
さんによる
It seems no component is getting hot on the charging IC line, do you think it could be related to another line? It just seems strange to me that only one pad on the IC is getting hot.
さんによる
What pad is it?
さんによる
The pad is C1
さんによる
コメントを追加
回答を追加する
Colby Morris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 260
