メインコンテンツにスキップ
スマートウォッチ「Fitbit Versa 2」の修理用マニュアル。2019年9月に発売されました。
20回答 すべてを表示
My button on the side has stopped working
The ‘back’ and on button depresses still but doesn’t actually do anything. Can anyone help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
I have similar issue with the buttons and looking for solution. Any help appreciated. Thanks
さんによる
According to what I have found there are many potential issues with this device that may be causing your problem. Start here and maybe you will find the answer
https://www.androidauthority.com/fitbit-...
さんによる
How can I contact you
さんによる
コメントを追加
2件の回答
最も参考になった回答
My wife's Versa 2 had the same fault...button not stuck, moving, but having no effect. After trying all the suggested online cleaning fixes with no success, I went ahead and removed the screen using a razor blade to have a good look inside. The central operating pin of the left button had pierced the switch pad of the tiny circuit board behind. I could still make the switch work by levering on the pad edges. I managed to repair by cutting a thin rectangular metal shim (from the same blade used to open the watch) of correct width to drop in between the button pin and the switch pad. Button then worked once more as the shim spread out the contact area across the pad. I glued the screen back on with contact adhesive after removing all the old residue. An almost free fix, and should last some time.
Before...
...And after
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Wow! She's lucky to have your expertise. I don't think I have the precision to pull off a procedure like that!!
さんによる
Haha thanks Rachel, but not really all that skilled. The razor blade steel was so thin it cut easily with strong scissors, so it was just a miniature fitting job. Must admit I struggled to see parts without the aid of a jeweller's eyeglass...my bifocals weren't up to it :)
さんによる
Amazing! Thank you for this tip and photos! I’m back in business!
さんによる
thank you for this. My wife's watch had exactly the same problem, and I followed your instructions and it is now working again!
さんによる
Hey Ray! This helped me a lot too! Just wanted to say thank you so much for sharing this. Was thinking of so many ideas and scouring the Internet for others.. yours actually helped for me! My versa 2 isn’t perfect but it’ll do now 👍
さんによる
コメントを追加
I just got my button to work. I soaked the watch in distilled water and then used the bristles of a soft toothbrush to poke into the teeny opening around the sides of the button. My guess is that dead skin and soap and dust get in there to gum it up. It took a few times, but it worked! Good luck!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
You put the eletric part of the watch in water? I just want to clarify, I seem to have the same issue!
さんによる
I never even wear my watch in the shower. I think submerging it in water to soak would give me too much anxiety. I definitely need to figure out a way to fix this issue, but I am not sure it can be soaking.
さんによる
コメントを追加
回答を追加する
viney68 さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 54
過去 30 日: 201
今までの合計 9,009
