Bose speaker not charging
My bose portable speaker is not starting after its battery reduced last night.
I hv tried changing cables also(Type C) still its not starting.
please suggest
この質問は役に立ちましたか?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
please suggest
この質問は役に立ちましたか?
hariom gangwar not quite sure what you mean by this “battery reduced “ but I’ll assume you mean the battery went down and did not longer work. Since you already tried a different cable I suggest that you change the battery. IF nothing else it will provide you with a known-well starting point for further troubleshooting. Let us know which Bose speaker this is so we can try and help you further if needed.
このアンサーは役に立ちましたか?
It is recently released bose portable speaker bought 1 months back.
Its battery was low last to last night approx 1-2 % and we left it for changing at night.next day onwards its not starting
@hariom gangwar since this is only 1 month old, return it and have them fix it under warranty. After all, you paid for that.
Mine is out of warranty. It’s not been charged for a couple years due to moving. What do I do?
It is a Bose sound link Bluetooth speaker ||| or 3
I’ve had it on the charger for over an hour I still have no light coming on. I understand it needs to be charged extensively but if you could tell me how long before I might see a power light emerge?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 2,175
1件のコメント
I've got a powercolor 2. The battery ran completely out, and now it will not take a charge or turn on (no lights turn on).
If I plug it into the computer, the computer will detect it and "set it up", however, when I try to run the Bose updater, it fails because the speakers won't communicate with the computer.
There is a popular solution if you search for it - keeping the power button pressed while plugging it into a computer and then unplugging it and letting go, then plugging it back in and pressing the power again, but this does not work for me.
I used them recently and they worked for a number of hours without a charge, so I think the battery is fine, and a quick search online shows this is not an uncommon problem for these speakers. Just want to know what to try next.
Thank you in advance!
CVarricchio さんによる
