メインコンテンツにスキップ
北米で2010年3月に発売されたニンテンドー DSiの大型版モデルです。ほとんどの修理作業はドライバー一本と開口ツールのみで完了できます。
Top screen has lines and is faded
My XL was dropped and now the top screen is really faded and has lines on half the screen. Bottom screen works fine and sound does too. Only problem is the top screen. Took it apart but what do I need to look out for?
Thanks
Michelle
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
最も参考になった回答
Here is the Guide and the part is available here and many other places As for hard to replace, it does depend on your skills and comfort level.
Replace a damaged or malfunctioning 4.2" 256 x 192 Upper LCD panel compatible with the Nintendo DSi XL portable gaming console.の画像
製品
Nintendo DSi XL Upper LCD
$84.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You cannot really fix this problem, the only thing that you can do is replace the top screen. If it was dropped the screen was probably smashed (inside LCD) and there is nothing you can do other than replace it.
Sorry for the inconvenience.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Would it be hard to replace? And would it be cheaper to send it Nintendo to fix? They charge me $80 to fix.
さんによる
コメントを追加
The top LCD is not a great DIY project unless you're used to handling small ribbon cables. If you aren't careful, you'll tear the new ribbon as you're installing it. New LCDs are $10-$20 on ebay. Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have the same problem!!!!! don't want to send on it in or replace
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
jala mcfadden, what problem do you have with your DSi and what did you try to fix it?
さんによる
jala the only place you can put your contact information id in your profile.
さんによる
コメントを追加
Yeah one day i decided i wanted to play on my Dsi XL and I struggled to pick it up from my desk and when i finally got it i opened it and the top screen was like halfway blacked out and random color lines were on it too i have know idea how to fix it plus its not even mine
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
have heard that the ribbons can be replaced but it needs specialized equipment like Z axis tape (this is for the lines only/blank problem, and a subset of those) but the glass is normally the cause.
I have a very expensive camera here with this fault, internal cable went bad but its a special sort of tape more expensive than standard Z axis as used in ipad repairs, chibitronics kits etc.
This works fine if the alignment is spot on for relatively large pitch connectors however like calculator panels!
If you have a good ribbon and screen then try https://www.adafruit.com/product/1656 might do the trick but alignment needs to be finer than a human hair.
Best done under a microscope or better still screen+camera.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michelle さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 30
今までの合計 8,864
