メインコンテンツにスキップ
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33回答 すべてを表示
How can I fix droids back ground lighting?
ddroid got dropped in a bucket of water 1 month later turned it on and it worked sound mic everything even touch responsive only thing that doesnt it seems is the light for the screen.. only can see it if holded to a light and angled right... doesnt make sense cuz bottom symbols light up brightly? anything i can do to replace or fix it i dont want to buy a new motorola too much $$$...
oh and yes i even turned brightness up all the way....(took a long time though)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hey there. It sounds like you might have a broken backlight, a problem that could be fixed by first checking to make sure that all the cables are securely connected, and, if necessary, replacing the LCD. iFixit has a guide to help you out with this process. Take a look on ebay, amazon, or some other retail vendor to find a replacement part.
Good Luck, and let us know how it works out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,294
