メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
20回答 すべてを表示
Xbox one S turns on then off.
Xbox beeps, lights up then shuts off.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
5 件のコメント
How do I check the Power Supply?
さんによる
well how do I know if its the Power Supply or something else?
さんによる
@daveparker Its usually a failing power supply when an Xbox shuts off moments after being turned on. The only other thing besides a (inexpensive) PSU replacement is a board level issue.
さんによる
Im having the same issue. Ive tested all mosfets and seem ok. No short on any of the 12v rails, yet showing short on nearly every cap after mosfets. Assuming the APU is dead and has shorted internaly. Will test with another psu and get back.
さんによる
コメントを追加
4件の回答
最も参考になった回答
We get people asking about their Xbox powering off 1-5 seconds here all the time. It’s almost always the PSU that has gone bad. Replacing the PSU should help.
Xbox One S Power Supply
Xbox One Sの電源ブロック交換
Replace a malfunctioning or burned out power supply module for an Xbox One S video game console.の画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Why was this answer made a comment?
さんによる
Because it is more of a guess than an answer. At least you could get the OP to test the PSU before suggesting to replace it. Sometime things can be fixed and must not always be replaced. That is why this place is called iFixit not iReplace it.
Chalk it up as shortsightedness and a mistake on my part since your answers are always outstanding. Have a Happy Thanksgiving !
さんによる
@oldturkey03 I have never used a multimeter so I couldn't really assist with testing of the PSU. Happy Thanksgiving to you too!
さんによる
コメントを追加
Try using a blow dryer on the top vent for a bit, then try turning it back on. Found that fix on another website.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I bought a new power supply, installed it but my Xbox one s, still turns on then 5 seconds turns back off. Anybody have good answers in what else it could be.
さんによる
Do you have any solution? I have the same problem, still turns on then 5 seconds turns back off
さんによる
コメントを追加
I can’t use my controller to turn it on when I try to hold the power button but that does not work I looked on YouTube but that did not work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Usually the problem occurs when water reaches the fans or the psu (power supply) or it overheats because of the safety lock that occurs when a lot of dust is in the fan, but the most common case is when the psu is faulty or isn’t plugged in properly. Try unplugging it then plugging it back in or try replacing the psu. If it still doesn’t work replace the fans that has a high chance of working. If you tried all this and it still didn’t work contact Microsoft. I had the same problem myself. Hope This Helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
xxGamerMLGxz さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 22
今までの合計 18,741
