The brush isn’t spinning on the bottom
I gotta carpet piece tangled in it and when I got it loose I noticed the brush isn’t spinning anymore. I cleaned everything out but it still isn’t working, is there a drive belt for the brush head?
お持ちのデバイス用の修理ガイドとパーツ一覧とアンサーフォーラムにアクセスする。
If your Dyson Ball Animal vacuum cleaner is no longer sucking up dirt, dust, and debris when using the standing vacuum, see the Dyson Ball Animal Has Loss Of Suction problem page for possible problems and solutions.
If your Dyson Ball Animal vacuum cleaner’s brush bar refuses to turn, see the Dyson Ball Animal Brush Bar Won’t Turn problem page for possible problems and solutions.
Use this guide to take it apart and clean it out and see if it's put back together correctly.
このアンサーは役に立ちましたか?
I called Dyson and found that the motor turning the bar burned out. I replaced the whole assembly for under $100.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 20
今までの合計 6,137
