メインコンテンツにスキップ
The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
My phone wont turn on after dropped in water
i dropped my phone in water and placed it in rice andalso tried to dry it up. I pressed the volume up, pwer and home button and a message on custom OS system appeared and then none of the buttons worked. now it turned off and wont turn on again. PLEASE HELP I just bought this phone a moth ago.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
15 件のコメント
My son dropped my phone in a bucket of water say a month ago,when I removed the phone from the water I immediately removed the Sim and SD card as I have a build in battery I could remove the battery(Samsung galaxy A5)I towel dried it and immediately put it in a 2kg pack of rice I check up on the phone every 48hrs then I dry it with the hairdrier so for 10-20 mins.so the phone just goes on when I put it on charge and it does charge but the side buttons doesn't work,and the touch is not responding.its been more than a month now,how long still?the guy @ the cell shop quoted me R1500 coz he says its my LCD.who in their right minds pays that kinda money to repair a phone?this is so depressing and I love this phone I have it just over a year now and I'm not ready to part with my phone yet,I'm not giving up on it!anybody plz plz help?
さんによる
Typing error,I meant I couldn't remove the battery as its build in.
さんによる
@neacy what phone is this? Have you checked the answer by @juax?
さんによる
My two year old pull down a kittle on his self and my phone.. it keep coming on n off showing Blu because d battery built in,I blow dry out d water then place it in d rice try couple hours n it's not charging. I don't know wat else to do please help me
さんによる
My phone is not charging I have also checked with the another charger but it's not charging up when I went to the store they said put it under the fan and make sure that it is switched off. I have done everything but it's not charging so please give me some advice . My phone name is Samsung Galaxy A30s.
さんによる
10件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
Courtesy of @oldturkey03
The very first step I would take is to disassemble your phone. Use this teardown to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You absolutely must remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide iPhoneの液体侵入ダメージの修理. It was written for a Apple iPhonebut it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair.
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
@juax awesome answer! ;-)
さんによる
Gotta give credit where the credit is due!
さんによる
コメントを追加
Putting on Rice is not the ultimate solution.It`s don`t work anymore.As fast as you open the phone and clean the pcb is the solution.Notice that the battery voltage if low then the chance of revive but if the battery is full then hard.
Wish this may help you and you recover the phone.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
I dropped my phone in the toilet and grabbed it ASAP. Then I carefully vacuumed it and dried it with a towel. Finally I put it in a bowl of rice for 24hrs it didn't work. So I'v decided to charge it. When I do charge it there is a light glowing on the screen. I don't know what else to do and I think I'v lost my phone for good can anyone please help.
さんによる
same thing happen to my device
さんによる
phone is dropped in water and and I have opened it but automatically it shut down suddenly and it is not taking charging also and shopsman is saying that its supply is gone and it can't be open
さんによる
コメントを追加
It all depends on how long it got wet, I have a Samsung galaxy A51 that i sat on top my fish tank to charge, The vibration of the air pump moved it in the back, Which is where it fell in, After I removed it I noticed the screen was froze, Once I removed the charging cable, the screen flickered then stopped, I tried rice, hair driers and everything, nothing worked, SO more than likely you may need a new one.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have an A51 it got wet for at least 2 seconds before i got it out and dried it it. The audio, touch screen, vibrations, camera and mic work perfectly fine its just the screen is blank? it glitched for a little while before just staying completely black.
さんによる
@freyahunter it needs cleaning and a new screen
さんによる
コメントを追加
回答を追加する
samsungUser さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 53
今までの合計 71,947
