メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
20回答 すべてを表示
tv will not keep turned on, restarts all the time
As soon as i turn Samsung Television model PS59D6900D tv on in starts going in to a ever lasting restart circle,in turn it on and in seconds in turns off then turns on by its self
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@bri29 unplug your set and remove the back. Take some good pictures of all off your boards and post those with your question. In particular your main and power board. that will allow us to see what you see. Use this guide for that
さんによる
コメントを追加
3件の回答
ベストアンサー
@bri29, Ross, I am not a TV repairman, Unplug the TV for a couple hours and then reconnect. Did a bit of searching on your issue and possibly bad on board/manual power switch or faulty board/capacitors. See the video links below to perhaps solve your TV's issue. If your TV happens to be under warranty still return for repair/replacement/refund. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=fbcCVv_a...
https://www.youtube.com/watch?v=H0cG3lzj...
http://www.instructables.com/id/Samsung-...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
See my answer on this here:
There are an estimated 12 million units with this issue, mine included. Class action law suit on it also:
My Samsung smart tv keeps turning on and off
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had that problem which was fixed by disabling "Digital text" in the menu options.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
problem is that it dont stay on long to get to menu,just got time to pull menu up then turns off
さんによる
Hi, I only had a problem on two channels so picked a working channel before accessing the menu. If you have a working channel, try that one to get into the menu. Hope that helps.
さんによる
コメントを追加
回答を追加する
ross さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,111
