メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
20回答 すべてを表示
My Samsung smart tv keeps turning on and off
Help my tv keeps turning on and off theres no damage to it at all
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
48 件のコメント
@ladylou79 start by letting us know what model your TV is. You say it turns "on and off" I assume it turns on then off but stays off. Do you have any blinking code from the front LED's? Can you turn the set immediately back on? What have you tried? We do need more information since anything else at this time will only be a guess.
さんによる
The only way to get to turn back on is to switch it off at the plug then switch it back on again it lasts for about 5 minutes
さんによる
Type ps5oc680 model ps5oc680g5k/xxu
さんによる
The tv is on, turns off by itself then restarts on its own
さんによる
Mine is doing the same thing. How do I fix it?
さんによる
43件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
@ladylou79 I looked this up earlier today because my Samsung TV started having problems turning on with the remote. Now for a while I could unplug it then plug it back in and the remote would start it. Now it's doing nothing. Seems like there is a class action law suit on them for this problem.
Samsung power defect causes some TVs to fail, and a class-action suit follows
A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the sets to fail.
https://www.cnet.com/news/samsung-power-...
I have not had the time to look up my model yet but it's a distinct possibility.
@oldturkey03 keeps up with this kind of thing and may even know the cap to replace ;-) Let's see if he'll tell us.
I'll update this later as i garner more information.
UPDATE 4/15/17
It has a red light in the lower left hand corner. No power on button. The remote stopped working. For a week or so you could unplug it, then plug it back in and it would turn on with the remote. Now it won't turn on at all. You unplug, the remote will blink the light once and nothing. Opened it up, could not find any noticeable bad caps. All the reports will say is that Samsung sometimes sends a tech out to replace two known undervalued caps. But i can find nothing so far that will tell me which ones. I really don't want to play the game with them and spend hours on the phone just to be treated like I don't know what I'm talking about, then finally have them acquiesce and do something. I'm happy to just spend ten minutes and repair the damned thing. I just want to know what caps need to be replaced before my blood pressure gets over 200 and i blow a cap.
My model # LT28D310NH
Looks like you have to do the dance with Samsung, play the game, let them pretend they don't know the problems, get you to change batteries.
If you persist long enough they may send a tech to change two capacitors.
ALL I WANT TO KNOW IS WHICH ONES TO CHANGE! BUT THEY WON'T TELL YOU.
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
You would be able to tell which capacitor is bad by looking at it. Blown caps, 99% of the time, will have a round bulge on the top instead of being flat.
さんによる
Be very careful though. Capacitors can hold a charge for a long time even after being unplugged. Discharge them by shorting out the 2 pins with a screwdriver with insulated handle.
さんによる
Also, the voltage value of new cap can be higher, but the uf rating must match the rating of old cap.
さんによる
It's one of two possible issues for me (could be either/or): See in Video #2: Testing the integrity of the power board with using my voltage meter, ground-to-STBY (standby) pin shows the problem is with the power board. There was my issue, defined. Now to find/test out which capacitor(s) (because they all look OK ) ...or.... the POWER REGULATOR could also cause this condition (the voltage drops away to zero volts from prescribed stby voltage both cases). At least I've isolated the problem to the power board as having the fault....
さんによる
I have found my TV only switches itself off and on while on an HD channel. Watching a 'normal' channel of the same broadcast has no effect.
さんによる
3件以上のコメントを表示
コメントを追加
最も参考になった回答
@ladylou79 ,Lou, Samsung has had a few issue the manual button switch panel, power supply board bad capacitors or main logic board faulty,all of which can cause TV on off issue. See links below to see how to diagnose this issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=H0cG3lzj...
https://www.youtube.com/watch?v=fbcCVv_a...
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
Video #1 showed how to eliminate a possible switch problem. Video#2 showed me how to prove my problem is confined to the power board. Great vids. Thanks
さんによる
I’m having the same issue with my Samsung un55nu6900 please help
さんによる
Wow, and now I feel like a dufis for owning 3 Samsung Smart TV's & 2 hi end Galaxy phones. My whole purpose is to be able to screen cast easily between devices.
Is Samsung still accepting class action parties?
さんによる
コメントを追加
I am not into taking things apart. I did unplug the TV for 15 min. , then replugged it. Made no difference! Then, I decided ( since nothing else was working) , to unplug cord from back of TV. I then proceeded to dust the back , especially around the connectors . Surprise! It worked! So far, so good!
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I am not into taking things apart. I did unplug the TV from wall outlet for 15min., then plugged it into wall again. No results. Next I removed the power cord from back of TV and dusted the connections, etc. Plugged it in again, & it is working fine now. Hope this helps!
さんによる
I'ma try this To I just hit the Back of the tv I stayed on a little longer
さんによる
Trish, this is exactly what happened to my boyfriend’ Samsung. Constantly turning on & off by itself. We tried unplugging at the power supply & even removing remote control batteries. NOTHING helped. Days went by. Finally as a last resort, he tried unplugging the other end of the power cord (the part of the cord that’s connected to the back of the tv). It worked!! Problem fixed :)
さんによる
@agua9 Maybe I need to beat my TV on the back.
I've had other instances where beating things on its back works pretty good. That is, if you have bail money.!
さんによる
コメントを追加
Unplug the wireless adapter. It seems to me the wireless adapter is telling the TV to switch to the smart hub but can't so it cycles on and off
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Did not work. Still cycling on/off about every 3-4 minutes.
さんによる
Is it in game mode? Just a thought. If its in game mode it will do that.
さんによる
Not in game mode. Disconnected WiFi adapter. No bad caps. Not power button or Ir board. I guess I’ll try the chips on main logic board. It’s a good thing this TV is heavy as crap. I can skip going to the gym this week.
さんによる
コメントを追加
I replaced logic board on my UF75F6300AFXZA BN4400621C. Worked for 1month then started power cycling again. Got a power board fix on eBay that changed capacitors. Worked for about 2 months. I contacted the repair service from eBay, and they told me to reverse the cable that connects the logic board to the power board. It worked for about 8months. Now the power cycling is back. I find that if I hit the tv in the back a couple times, it stays on, but will occasionally turn on and off. No more samsung televisions for me.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I just Hit My Tv in the Back And It Pop Right On Again So what's The Problem with It Haven't had this Tv 2 months yet
さんによる
I hit mine all the time to get it working
さんによる
I gave it 2 good smacks.And the d*** thing dial 911.No i'm in trouble
さんによる
コメントを追加
回答を追加する
Lou hooper さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 38
今までの合計 248,426
