メインコンテンツにスキップ
The Acer Aspire One 722 model #P1VE6 is a netbook that was released in July 2008.
14回答 すべてを表示
Power port used on asprie one 722
Will mu laptop still work with the power port plug not plugged into mother board
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
I don't know your laptop, but looking at the DC-In jack power plug cable it appears that it only there to connect the charger to the motherboard, so you should be able to start the laptop on the battery.
Update (03/26/2017)
Hi Jeff Lee
If your battery is low do not try to charge it out of the laptop as doing it this way will bypass the battery management circuitry (and protections). Wait until the new DC-In jack spare part arrives and is installed before charging the battery. Also do not run the battery flat in the meantime.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Any answers on my other ?
さんによる
Hi Jeff,
If the battery is low or not holding its' charge (how old is it?) that might be one reason, that is why I asked in my comment to your other question to try it on the charger , but if it cannot charge properly or even run on the charger due to a faulty DC-In socket then that will have to wait until it is fixed before it can be disregarded as the problem and then other causes sought.
さんによる
Thanks alot i will try that
さんによる
コメントを追加
回答を追加する
Jeff Lee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 367
