メインコンテンツにスキップ
This is a, 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H), notebook PC the unit weighs 6.6 lbs. It was released in 2006 and comes standard with a 80 GB hard drive.
Why do I struggle to connect ot WiFi?
My notebook struggles with Wifi connection. If it is connected the signal is always weak. I can be right next to a laptop that has full Wifi strength and I can't connect at all. Sometimes the signal goes in and out, when there is no change with the router or even if I stay in a stationary position.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
You may or may not have a broken or faulty WiFi card, or the antenna may be disconnected.
Here is a link to our repair page.
HP Compaq Presario V6000
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You can try disconnecting and re-connecting the WiFi Card on your laptop's motherboard.
Another thing to do is:
Go into Device Management (type devmgmt.msc in Run window) -> Double click on Network Adapters ->
Uninstall the 802.11 g/b driver (uncheck the option that asks if you want to remove it from your system) then click the top-right most icon that says Scan for Hardware Changes.
Now try connecting to your network.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
PJ Andress さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 301
