メインコンテンツにスキップ
1.7GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.6 GHz)3MB L3キャッシュ
20回答 すべてを表示
My MacBook air does not turn on?
My macbook air 11" Mid 2012 suddenly does not turn on anymore.
Tried pressing the power button on for 10 secs, released and tried again - no luck
Tried resetting SMC, pressed and held Shift + Control+ Option+ Power buttons. Released the keys at the same time. Then tried turning on the Mac.
Tried resetting NVRAM.
Do not hear fan or any sounds, seem completely dead. When I connect the power adapter the light on the magsafe turns green, but still no sound or power or boot.
Looking for suggestions and next steps.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
8 件のコメント
Did you get your system wet at some point (spill or sat it down on a wet surface)?
さんによる
Not that I can think of, don't see any wet areas in the bottom or top. How do I verify that there was no wet areas.
さんによる
You could open the bottom cover and look for red dots if you see them it was wet at some point.
さんによる
Does this model have a battery test button?
さんによる
I did not see a battery test button. I was trying to get the bottom out but was not sure which IfIxit bit to use ?, T3 ?
さんによる
3件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
Assuming you didn't get your system wet it doesn't sound good here. Most likely the CPU has crapped out.
I would visit an Apple store to see what they say, at least get a free estimate on what the costs will be.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Karthik Krishnamoorthy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 457
