メインコンテンツにスキップ
任天堂の最初の3DSモデルは日本で2014年10月に発売され、北米では2015年9月に発売されました。Newニンテンドー3DSは改良された3D機能、Cスティックと新ZLボタン、ZRボタンが特長です。
20回答 すべてを表示
Why is the touch screen glitching?
I have just purchased a faulty, used New Nintendo 3DS (so no chance of warranty repair), and I'm trying to figure out what to do with it. The touch screen is acting as if it's being pressed constantly, until I apply gentle pressure to the back left of the console. I have tried using a toothbrush to get any residue between the seams of the screen, and also loosened a few screws at the back, to no avail. I am wondering whether to do a full teardown and see if there is anything else I can loosen, also I have seen a method used on a 2DS with a similar issue which involves a small piece of electrical tape being applied to one side to alleviate pressure, would it help in this case? Failing the above, do I need to replace the digitiser? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi claire! I believe you problem doesn't have anything to do with anything being to tight. That said I am 80% certain of that. The issue your having has something to do with the digitizer but if your able to fix the problem with a piece of electrical tape then I wouldn't take the whole DS apart but If the tape doesn't work then if I were you I would actually do a full teardown to get to the motherboard and actually see if there is corrosion and if there is corrosion clean it with a tooth brush and isopropyl alcohol 90% and up. Now if there is no corrosion then I would replace the digitizer and see if that solves your issue.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Claire Brooks さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 17
今までの合計 999
