メインコンテンツにスキップ
ハードドライブもしくはハードディスクに関する修理情報です。ハードドライブは磁気データ記憶装置です。 低コストでデータ密度が高いため、ほとんどのデスクトップ、ラップトップ、およびサーバーで使用されています。
20回答 すべてを表示
dropped external hard drive making clicking noise recovery?
I dropped my external off of my tower , it still installs drivers but it does not read , is there a way to recover the hard drive or the information ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
ベストアンサー
Sadly the click noise is the clue here: The drives mechanical part is damaged (head unit damaged).
If you must recover the data on the drive your only hope is to send the drive out to a recovery outfit that can repair the drive long enough to recovery your data. This is quite expensive!
There is nothing you can do to fix this as you need a ultra clean room and highly specialized tools. Here's a service outfit I've used and a vid which will give you an idea on what is needed: Secure Data Recovery
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
You could also use the device as a paperweight after taking it out of your current enclosure and re-purposing the enclosure with a new drive.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If the data is critical then just send it out for recovery.
Otherwise, you can try to fix it yourself.
Start by acquiring the exact same make and model hard drive in good working condition.
You will then need to open the bad drive and determine what is broken. You can harvest parts from the new drive to repair the broken one.
You may need to swap the platters from the old drive to a new drive.
There is a lot of information on how to do this but below is an example of the sort of work you are looking at.
https://www.youtube.com/watch?v=GZx-tU1_...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
If your external hard drive is no longer reading after it was dropped, there may still be a chance to recover your data. Here are some steps you can take to try and recover your hard drive or the information:
  1. Check the physical connections: Make sure the external hard drive is properly connected to your computer and check the USB port for any physical damage.
  2. Use data recovery software: You can use data recovery software such as Recuva, EaseUS Data Recovery Wizard, or TestDisk to try to recover your lost data. These programs can scan your hard drive for lost files and recover them if possible.
  3. Take it to a professional data recovery service: If you are unable to recover your data using software, you can consider taking your hard drive to a professional data recovery service. These services have specialized equipment and expertise to recover data from damaged hard drives.
However, it's important to note that dropping a hard drive can cause physical damage to the disk platters or other components, which may make data recovery impossible. Therefore, it's important to take caution and avoid doing anything that could further damage the hard drive.
I recommend reading the following blogs for more information on recovering data from damaged hard drives:
What To Do When Your External Hard Drive Fails
How to Recover Data From a Dead Hard Drive
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marco Smit さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 60
今までの合計 31,122
