メインコンテンツにスキップ
Wiiリモコンは、2006年11月19日に発売された任天堂Wiiゲームコンソールのオリジナルコントローラーです。オリジナルのWiiリモコンのモデル番号は、RVL-003です。
How to fix bad connection to Nunchuck and Motion plus?
I can't play games like the arrow (Wii sports resort) because my nunchuck has a bad connection with the motion plus. Sometimes nunchuck isn't recognised, sometimes its start the game and then lost connection or the arrow shoots by itself.
How to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
1件のコメント
The lights light up but can't play or get started
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
I've been able to succesfully repair a disconnecting nunchuck where the problem was a broken cable (broken inside , outside rubber tube wasn't showing any signs of damage.)
1. First you need to unscrew both the connector and the nunchuck itself to see bare cable connection with nunchuk electronic board or connector. There are 5 (or six) smaller colored cables inside the main cable.
2. Then use voltage meter to check if both ends of every colored cable are connected. Two of my nunchuck have one cable showing no reading - this is the cable you need to reconnect.
3. Now you can replace an entire cable (much hassle) or, like me, bypass the one cable that doesn't connect. I, have put the new cable on the outside , soldered to both ends it is should to connect. Then screw nunchuk and the controller.
Now, the finished thing has two cables (5-string one and single string one), I used small masking tape to tape them together every 10 or 15 cm apart. This will look bad but, hey, it works.
Other solution - buy the original replacement. I've tried Chineese knock offs (they cost $3,5 with shipping) but the joystick is so loose just after a month that is not worth it. I've found new original ones on ebay equivalent where I live going for ~$12 (in old circa 2006 packaging, but they are the same thing as those in Wii U packaging)
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Sorry but I can't find the product on e-bay. Could you post the link please?
さんによる
I said "ebay equivalent where I live", so it is not the same place.
Us official Nintendo store has them for $20
http://www.ebay.com/itm/Nunchuk-Game-Con...
さんによる
Oh sorry! I didn't read with attention. Where are you from?
Anyway the better option is to buy a new nunchuck, don't is?
さんによる
Can you make an iFixit page going into detail on how to fix this issue?
さんによる
コメントを追加
回答を追加する
Everton Nucci Fernandes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 64
今までの合計 16,131
